I have a number of temp sensors around the house (xaiomi zigbee connected via deconz) and i want to use them to control a single heater with them. I’d like to set up generic thermostat from each sensor, so that each room (sensor) will have individual set-points. The question is whether is is feasible? As there will be 3 generic thermostats all controlling the same heat source, will they respect the condition of each other or should i need to abstract the switch away.
For example:
Thermostat 1 is ‘on’
Thermostat 2 is ‘on’
Thermostat 1 reaches the upper limit but thermostat 2 is still below
Would the heater be turned off, would it be left on, or would there be some undesirable or unpredictable outcome.
