How does one configure the system to monitor multiple hosts with the new glances integration? Before .101 all you had to do was set up multiple sensors under glances platform. Now the documentation indicates top-level configuration for only a single host.
The duplicate sensors might be due to adding the Glances instance to your configuration file while also maintaining the one you previously set up via the integrations page.
As for the missing pihole sensors, I haven’t got a clue what could be the cause of that.
If I have the Glances “Add-on” for the local Home Assistant, can remotes be added to the Add-on, or can they only be added via integrations? And it seems that integrations want the service running as a web server. The device display is very simplistic. The Add-on seems to use the full restful API, so you get the full Glances experience.
