Hi everyone!
I´m trying to upload multiples input boolean and I get and error, I can only add one input boolean, does anyone knows what I need to do or what I´m doing wrong? if I only add the first one works.
disable_security:
initial: on
icon: mdi:shield
away_mode:
initial: off
icon: mdi:car
at_home_mode:
initial: on
icon: mdi:home
day_mode:
initial: off
icon: mdi:weather-sunset-up
night_mode:
icon: mdi:weather-night
initial: off
Thanks! I have it like that in my yams, I will edit it.
here is the error I got:
2017-05-11 08:09:19 ERROR (MainThread) [homeassistant.config] Invalid config for [input_boolean]: [initial_1] is an invalid option for [input_boolean]. Check: input_boolean->input_boolean->night_mode->initial_1. (See /home/homeassistant/.homeassistant/configuration.yaml, line 116). Please check the docs at https://home-assistant.io/components/input_boolean/
Thanks it works now! I save the file in atom to be sure that was in UTF-8 cause I was using the same file and also trying different things like initial 1 and i always have errors but now is working.
