Looking at the guide to split the configuration file it states that multiple files can be imported for the same integration if different labels are used. This seems to work for light and some other ones but not input_number.
When I try to include a configuration file with the row below and check if the configuration is valid I get the error underneath. I have tested different labels to see if there are some reserved keywords and this is for now the only place where I include a configuration for or configures input_numbers in yaml. Is this a bug or am I missing something?
If I remove the label the file imports correctly.
input_number lights: !include autolight/light_input_number.yaml
2021-08-13 23:36:09 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 206, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 144, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/core.py", line 29, in post
errors = await async_check_ha_config_file(request.app["hass"])
File "/usr/src/homeassistant/homeassistant/config.py", line 923, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 178, in async_check_ha_config_file
result[domain] = config[domain]
KeyError: 'input_number'
