I have three A/C units which I would like to “control” via multiple input_selects.
First input_select holds the actual units
Second input_select holds the swing mode
Third input_select holds the fan mode
My goal is to create a “flexibel” automation and/or script which can control each device and each setting without creating many automation/scripts for each unit.
For example, I can set the swing mode via a boolean with this code;
- alias: Set swing mode on AC unit
platform: state
entity_id: input_boolean.ac_set_swing_mode
- service: climate.set_swing_mode
data_template:
entity_id: >
{% if is_state("input_select.ac_device", "Unit 1") %} climate.unit1
{% elif is_state("input_select.ac_device", "Unit 2") %} climate.unit2
{% elif is_state("input_select.ac_device", "Unit 3") %} climate.unit3
{% endif %}
swing_mode: "{{ states('input_select.swing_mode') }}"
This code sets the swing mode selected (in input_select.swing_mode
) at the correct unit (chosen from input_select.ac_device
by switching a boolean. No problem so far…
I want to make my automation fault proof. As for now, if somebody hits the boolean, the AC unit it switch on to set fan mode or swing mode. This is not my intent. I want the automation to run only if the selected AC unit is on (so status != “off”). Normally I would say, you need to create a condition for this, but I can’t seem to find out how.
I need a condition where the entity_id
is based on input_select.ac_device
value and status is different then off
Anybody who can help me out?
