Multiple instances of the same z-wave hardware seen differently in HASSIO
I have a strange issue with Fibaro Smart Implant. Recently I added 3 pcs to my HASSIO configuration and only one of these is visible in the system as it should be… Normally Smart Implant should show 17 entities on node, as reported in Z-Wave configurator. These are analog, binary, temperature or alarm sensors, switches etc. Important to me are 2 switches and 2 binary sensors. Unfortunatelly 2 pcs are showing only 7 entities (in particular 1 switch and 1 binary sensor). I tried to remove/add these nodes, reset them to factory settings, heal the network and nodes etc. but with no change. While reviewing zwcfg_0x…xml I can see that node that is properly configured has several more lines in configuration file vs the other 2. In particular for working implant many lines referes to instance 1 or 2 of some sensors, while for not working one alwas refer to only one instance. Configuration of all node parameters is exactly the same (referring to all required entities). HW version seems also to be the same (anyhow it should have 2 pairs of sensor/switch).
Any way to reinforce proper re-discovery of these 2 smart implants?
Would copy, paste, edit node numbers in zwcfg_0x…xml file correct the issue?
Any other advice how to fix this?
OK, another attempt; I removed all smart implants from my configuration and added them using OZWCP rather than Z-Wave configurator. To my surpise all 3 nodes are now listing all 17 entities!
Victory is yet partial, though… switches are working when triggered from UI, but seems no sensor is changing it’s state/trigering switch change regardless of input configuration (being mono or bistable or alarm)…
