Hello - so close but just one remaining issue to leave Homeseer. I have 3 Z-Net G3’s - yes, I know it is nuts but I have a total of ~230 nodes over a large footprint - worked well in HS and some nodes are super hard to access.
Anyhow, the question - I have successfully installed 3 instances (one for each Z-Net) of JS UI on windows - all the nodes show in those instances - I have them all on different ports to access on the windows web browser - all 3 instances I can access and see the nodes perfectly. I also configured the HA web socket on the first to 3000, the second to 3001, and the third to 3002.
Now on HA (which is on a different machine, RPI) - the 3000 port (ws//192.168.1.20:3000) connects to Zwave JS - no issue at all. Works perfect. The 3001 shows as available to add (is discovered) but when I click to add the hub, I get an error after a period of time (Failed to connect) - same issue with 3002… Fails to connect. Net is only 1 of the instances connects to HA Z-Wave JS…
Appreciate any help!
