Multiple integrations failed to load in 2023.07 and 2023.07.1
Since upgrading to 2023.07 the following integrations are no longer loading:
  • Alarmo
  • AVM Fritz!Box
  • Cast
  • ibeacon
  • Internet Printing Protokol (IPP)
  • Mobile App
  • MQTT
  • oralb
  • sleep as android
  • Xiaomi Miio
  • Xiaomi_miot
  • Zigbee Home Automation
Did anyone encounter something similar?
I have already tried to restart Home Assistant (All 3 options), but nothing seems to fix it for me.
There are still plenty of integrations, that do work and I can also access it through Home Assistant Cloud, but not having Zigbee and MQTT is a huge bummer for me.
What does your logs say? I run several of these, no issues.
This is a short screengrab of the logs. Do you want me to provide the full log?
You have a under-voltage error in your log, have you tried another power supply?
I have tried another cable, but let me try for a different power supply…
I have changed to a powerbank with a higher output and it seems to have solved the problem, even though the logs still show Under-voltage.
Great! I’ve heard that raspberries are picky on the power supply.
I had this problem with Alarmo, I updated to the last version in HACS and it was solved.
I don’t know why, but this only worked for a couple of days and than failed again. But in the meantime I have opted to get my self a small NUC sized Mini PC with an AMD CPU and Home Assistant now runs happily in a Proxmox VM. This has other benefits like being able to host other stuff simultaneously and being able to load a nice big speach-to-text model for local voice.
I guess money does solve some problems, too. :slight_smile:
