Multiple integrations of an integration
Is there a way to run more than 1 inegration of the same integration ?
yes there is
Some integrations support multiple instances - see withings
Some don’t.
You can theoretically make a copy, rename the right stuff and make a ‘custom’ copy of an integration but it LS a lot of work and you may not need to.
In your case I’d ask WHICH integration. - what are you ACTUALLY trying to do.
Duotecno is the name
How then ?
I have 3 smartboxed of duotecno and only one is supported. I am looking for a way to have them all 3
I am unfamiliar with this integration.
Have you tried to add another device after configuring the 1st by just using another IP address?
yea, I get the notification that it’s only possible to have 1 running…
If I look at the integration code, I can see it mentions VelBus :thinking:
But that is all I can find maybe @Cereal2nd knows more ??
Looks like he works on both Duetecno and Velbus :stuck_out_tongue:
this is on the todo list, but at this moment only one is possible
Is this something coming in a month, in 6 month’s, a year ?
It is because I have 3 smartboxes, and only one I can use :slight_smile: If it is in a year, I will return it to sender :slight_smile:
Hi Jo,
There is no timeline.
If you do decide to return them.
Please reach out to Cereal and I, I’m sure we can arrange a good price on some #Velbus alternative modules
Would be nice to know indeed.
For me as well, having multiple smartboxes integrated is what makes or breaks the Duotecno setup.
Somebody got it working for me, but I cant update HA or I loose this config…
