Multiple MJPEG Cameras not loaded
I have a problem with PI-SPW303l Panasonic IP cameras. when i stream from 10 cameras, only 6 cameras are working and it stream with lag and slows down the home assistant when i open the stream. i’m using RPi 4 and the streaming is MJPEG. could anyone suggest a solution for this issue ?
Can you use a lower resolution substream from the cameras to reduce the load?
yes i did but i have the same problem
As HA is not a NVR…
I use - platform: proxy for all cameras in Lovelace cards (updates every approx. 4 seconds :slight_smile:
When I need a direct view I click on it and go to live.
Best, JR
Capture
I did but the proxy camera entity does not work like in the pictures
is this warning cause a problem in loading all cameras !?
Yeah. That is bad for everything. Get a better power supply.
