The issue is that this is not working. When I configure the integration to remove it it will appear after the reboot again
Hi Flo, I pushed a new version of the custom component (ecff7da) via HACS with an attempt to fix this issue. Please let me know if this persists.
@Flo.C got the hint that the custom component wouldnât properly override the discovery. Would you be able to set up a separate instance for testing (ideally venv/core) so you could run a custom branch?
Hi Tobi. Thanks for the effort. I need to check if I have somewhere a spare Pi to test it. Will let you know!
You could probably patch you main instance by hand.
Hi Tobi!
Just wanted to let you know that I got it working at least.
Still need to check if I get multiple discoveries.
Will let you know!
Best,
Flo
Hey Flo, thatâs great to hear. Looking forward to your feedback.
