I am currently using ASUSWRT, the Home assistant Iphone App, and Owntracks all as presence sensors. Also working on a Bayesian sensor.
My question revolves around how Home Assistant “Merges” two trackers into a single sensor.
My ASUSWRT and the Home assistant app, are using a single presence sensor. I did not go out of my way to do this, HA just took care of it on its own. I believe it ties the MAC address of the device. I believe I can get Owntracks to do the same, but have not done that yet.
When I am at home on wifi, the source for my presence device is ROUTER, when I’m away the source is GPS.
So far, so good, makes sense. The issue is when I disconnect from the router, the app does not immediately take over. So it gets marked as away, then if I force an update, I get marked as home again.
I’ve had a lot of bouncing when I leave home, marked as away, then back home, then away.
I’ve dealt with spotty presence on most platforms I’ve tried over the years, so I’m not complaining, just looking for possible ways to improve this.
So, 1st, can I separate my asuswrt presence from the home assistant presence. I’d love to have them separate, if possible. Would allow me three devices to work with my bayesian sensor.
Thanks for any info or tips
