Sorry for my english, i’m french. I’m newbies, thank you for your help.
I’m trying to do this, but I can’t:
If door 1 or door 2 is open, and the window group is closed, then only light 1 is active.
If door 1 or door 2 is open, and the window group is open, then only light 2 is active.
If door 1 and door 2 are closed, and the window group is open, then only light 3 is active.
If door 1 and door 2 are closed, and the window group is closed, then everything is off.
Here, if you can help me that would be nice.
Thank you all
Original
Bonjour,
Je suis débutants, merci de votre aide. Je cherche à faire ceci, mais je n’y arrive pas:
Si la porte 1 ou la porte 2 est ouverte, et que le groupe fenêtres est fermé, alors seule la lumière 1 est active.
Si la porte 1 ou la porte 2 est ouverte, et que le groupe fenêtres est ouvert, alors seule la lumière 2 est active.
Si la porte 1 et la porte 2 sont fermées, et que le groupe fenêtres est ouvert, alors seule la lumière 3 est active.
Si la porte 1 et la porte 2 sont fermées, et que le groupe fenêtres est fermé, alors tout est éteint.
Voici, si vous pouvez m’aider ce serait sympa.
Merci à tous
There are also a couple of other options which may simplify your triggers/conditions, although they are not necessary to achieve what you want to do.
You could create a new group containing the two door sensors. The group should report on if either door is open, or off it they are both closed, so you can use the group in your automations in place of checking each door individually.
You could also create a binary sensor for your doors which reports a single status - either on if one of the doors is open, or off if both are closed. The config would be something like this:
I made a second group for the gates as recommended by EKC and modified the automation of Tom_I to take this new group into account.
Everything is OK.
