Multiple sensors in yaml.... help please
Hello, these two code blocks are causing an error in the yml file, I would appreciate it if you could help me to fix it.
# https://www.speedtest.net/apps/cli
# Template sensors are in configuration.yaml
# Download and test, use binary matching platform, e.g. for x86_64
# wget -qO- https://install.speedtest.net/app/cli/ookla-speedtest-1.2.0-linux-x86_64.tgz | tar xvz
# ./speedtest --accept-license --accept-gdpr
# Copy binary to desired HA config folder
# mkdir -p /config/3rdparty/speedtest
# cp ./speedtest /config/3rdparty/speedtest/
- platform: command_line
  name: "SpeedTest CLI Data"
  unique_id: speedtest_cli_data
  # Use the path as configured on your system
  command: "/config/shell_commands/speedtest --format=json --accept-license --accept-gdpr"
  # Every 4 hours, 60 * 60 * 4 = 14400
  scan_interval: 14400
  command_timeout: 60
  # Summarize results to stay below string limit and convert to JSON
  value_template: >-
        "ping": value_json.ping.latency,
        "download": value_json.download.bandwidth,
        "upload": value_json.upload.bandwidth
      | to_json
    sensors:
        ipfire_mbps_received:
            friendly_name: "Mbps Received"
            value_template: "{{ states('sensor.x60_kib_s_received') | multiply (0.001024)  | round(1) }}"
            unit_of_measurement: 'Mbps'
            icon_template: mdi:download-network
        ipfire_mbps_sent:
            friendly_name: "Mbps Sent"
            value_template: "{{ states('sensor.x60_kib_s_sent') | multiply (0.001024)  | round(1) }}"
            icon_template: mdi:upload-network
Remember to include the error you get. Just saying there is an error is not helpful for us.
But in this case it’s quite obvious.
You have sensor: twice in the configuration.
Remove the second sensor: and it will work.
I’m sorry I couldn’t give enough information because I’m new.
this is the error i got
bad indentation of a sequence entry (96:2)
93 | }}
94 |
95 |
96 | - platform: template
97 | sensors:
98 | ipfire_mbps_received:
You have indentation errors too. Didn’t notice that first.
# notice I removed sensor:
    sensors:
      ipfire_mbps_sent:
