I’m a VERY new user and having trouble searching for an answer on this:
Trying to get sensors added for multiple devices that are the same.
I have multiple QNAP NAS devices. Per the instructions i added this block to my configuration.yaml file and restarted. But it only picks up the LAST one in the list. If i change the order that becomes the one it picks up. I don’t really see how to specify more than 1 sensor.
Can you advise how that would be done? They are identical devices with just different IP’s.
Remove the second sensor: and maybe some then empty lines.
The sensors: use a list and a yaml list is just something like this:
listname:
- item
- item
Edit: Leave everything not prefixed with a dash and not intended in place You’r items are not just items but dicts (and this is the yaml way of writing them).
You can find a quite good cheat sheet for yaml syntax in the ansible documentation, here.
