Multiple servers?
Is there a way to set up the ios app to point at more than one HASS server? Somehow easier to switch between two accounts without changing the config each time?
I don’t believe it’s possible. Maybe you could set both servers to talk to each other (via MQTT for example) and add entities from the 2nd server to show on your main server so they show up on the app?
It’s not ideal, but open the secondary server in Safari. Then tap the share icon, and tap “add to homescreen”.
You’ll get an icon on your homescreen that replicates the home assistant app, accessing that server.
