I’m sure this is an easy one for someone. I’m trying to add more than one switch in the light switch platform but all the methods to add a second switch have failed.can someone tell me the right way to do it?
Do you have any example code?
I am guessing you might be doing something like:
light:
- platform: mqtt
state_topic: "stat/sonoffKit/POWER1"
command_topic: "cmnd/sonoffKit/POWER1"
availability_topic: "tele/sonoffKit/LWT"
qos: 1
payload_on: "ON"
payload_off: "OFF"
payload_available: "Online"
payload_not_available: "Offline"
retain: false
light:
- platform: mqtt
state_topic: "stat/sonoffKit/POWER2"
command_topic: "cmnd/sonoffKit/POWER2"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
But you need to have it like:
light:
- platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
- platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
You also could do it like this, but I prefer the first option:
light 1:
- platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
light 2:
- platform: mqtt
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: false
Hi Will,
It’s the light switch platform
light:
- platform: switch
name: Christmas Tree Lights
entity_id: switch.christmas_tree_lights
How are you adding the additional ones?
Do the switches work OK before adding them as lights?
Then you should be able to define extra lights like so:
light:
- platform: switch
- platform: switch
name: Thermonuclear War Launch
entity_id: switch.thermonuclear_war_launch
Thanks Tom, I had not tried that! Works great!
I presume it is not possible to simplify the code further? I was thinking since all the light’s platforms are switches, it would be nice to somehow indicate that outside the list and apply to all, ie:
light:
platform: switch
- name: Christmas Tree Lights
- name: Thermonuclear War Launch
