Is it possible to use multiple tcp modbus devices on different ip adresses
modbus:
type: tcp
host: 192.168.1.24
port: 502
modbus2:
type: tcp
host: 192.168.1.204
port: 502
this does not work
modbus:
type: tcp
host: 192.168.1.24
port: 502
modbus2:
type: tcp
host: 192.168.1.204
port: 502
this does not work
So, it is not possible jet?
Did You test this?
I think I figured it out!
Copy /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/modbus.py
to “your_config”/custom_components
rename it modbus1.py
edit the file by changing DOMAIN = 'modbus1'
Now if you want a Modbus sensor
Copy /srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/modbus.py
to “your_config”/custom_components/sensor
edit the file by changing import homeassistant.components.modbus as modbus to
import custom_components.modbus1 as modbus
and then DEPENDENCIES = ['modbus1']
Note* I am running in a pvenv so I had to make homeassistant the owner of all the directories and files.
configuration.yaml…
modbus:
type: tcp
host: 127.0.0.1
port: 4000
modbus1:
type: rtuovertcp
host: 192.168.254.196
port: 4598
- platform: modbus
registers:
- name: S1
unit_of_measurement: 'mA'
slave: 2
register: 309
register_type: holding
count: 1
precision: 2
scale: 0.01
data_type: custom
structure: ">h"
- platform: modbus1
scan_interval: 60
registers:
- name: S2
unit_of_measurement: 'feet'
slave: 1
register: 1
count: 2
scale: 3.281
precision: 2
data_type: float
restart HA Done!
Is there an easy way to access that file on Rpi, samba share does not show it
FYI, a PR just got merged a few days ago to allow multiple modbus hubs. Should be possible in the next release of HA.
what will be way of configuration?
Have a PR for the multiple Modbus slaves https://github.com/home-assistant/core/pull/47043
Can someone pls help me convince code owners that the HA community needs it?
