HI,
trying to configure multiple template locks I wonder if there’s anything missing in the way we should set these up.
with sensors, binary_sensors, template_sensors etc we use
sensors:
name:
as described on https://www.home-assistant.io/components/template/#configuration
checking the docs on https://www.home-assistant.io/components/lock.template/#configuration the equivalent line to sensors:
in this case would be locks:
but that is not described.
Could this be an oversight in the docs, or is it an oversight in the integration setup…
I think I’m having a similar issue. In the following, only the second lock “Pinless Front Door” shows up in the entity registry. I think this may be a bug. Ideally there should be a “locks” attribute for consistency.
name: 'Pinless Garage Door'
value_template: "{{ is_state('cover.garage_door_opener', 'open') }}"
unlock:
service: cover.open_cover
entity_id: cover.garage_door_opener
lock:
service: cover.close_cover
name: 'Pinless Front Door'
value_template: "{{ is_state('lock.schlage_allegion_be469_touchscreen_deadbolt_locked_frontdoor', 'unlocked') }}"
unlock:
service: lock.unlock
entity_id: lock.schlage_allegion_be469_touchscreen_deadbolt_locked_frontdoor
lock:
service: lock.lock
ETA: WORKAROUND
Add - platform: template
before each lock definition makes both locks appear in the registry
yes, I did so also.
still I feel this is an incorrect and at least inconsistent way of doing so.
filed an issue to be sure this gets some attention: https://github.com/home-assistant/home-assistant/issues/26061
