Multiple Triggers and Actions for the Aqara Mini Switch
The Mini Switch from Aqara lets you use many different triggers for different presses. With this blueprint the setup is easy!
Add as many actions you like to the separate triggers and enjoy.
-Triggers
- Single press
- Double press
- Triple press
- Quadruple press
- Many presses (more than five)
- Hold
- Release
Changelog
- 1.1 - Description corrections
- 1.0 - Initial Release
First, you will need to add it to a Github repository.
Does it need to be a repository or is gists enough? I don’t know too much about this.
AFAIK it needs to be a repo
I have made a repository now. Do you know how to make it a “Add to Home Assistant” button?
Create a link – My Home Assistant I think
Thanks! Hope it works :slight_smile:
