Multiple Triggers - AND
Is there a way to AND triggers together? From what I can tell it behaves as an OR.
I’d like to do:
If Trigger A and Trigger B then do C.
But right now it behave as:
If Trigger A or Trigger B then do C
I could split it into two automations… and use a condition but that seems like a nuisance.
Any help is appreciated.
I’d use ‘Trigger A’ as the real trigger and ‘Trigger B’ as a condition (or a bunch of them) in order to trigger an action.
It’s probably just in the wording, e.g. you say “If I come home AND it’s dark turn, then on the lights.”
You’d turn this into:
Trigger: change of state from not_home to home
Condition: it’s dark (e.g. after sunset)
Action: turn on the lights
In one automation: Trigger on either (A OR B), then use an and condition that asserts both (A AND B) before moving on to the action
automation:
    - platform: numeric_state
      entity_id: 'sensor.A'
      above: 68
      entity_id: 'sensor.B'
      above: 72
  condition:
    condition: and
    conditions:
      - condition: numeric_state
        above: 68
        above: 72
    - 'do stuff'
I don’t think there’s a way to limit the automation to firing on both conditions.
What would be the difference if you took out the trigger for sensor B and the condition for sensor A in this case?
Unless I’ve misunderstood something, it wouldn’t trigger on sensor B, and you’d need a second automation to trigger on sensor B then check the condition of sensor A.
Since nuurban implied that they’d prefer to use one automation, this seemed preferable.
Okay, got it.
Either change can trigger, both conditions need to be fulfilled.
Haven’t had a need for this so far, so I hadn’t thought about it that way.
This would be like turning my example into:
“(If I come home AND it’s dark) OR (if I’m home AND the sun sets), then turn on the lights.”
This works… I don’t really like the redundancy… but since the trigger section can’t do an AND there’s not really a nicer way to do this in one automation I guess. Thanks for help!
I was looking at this the other day as I wanted to include an AND for my bathroom exhaust fan trigger to compensate for outside humidity. I found that you can put logic into template triggers. Example below.
`- alias: "Turn on Bathroom Fan"
     platform: template
     value_template: '{{ states.sensor.dark_sky_humidity.state | float > 90 and states.sensor.bathroom_humidity.state | float - states.sensor.lounge_humidity.state | float > 20 or states.sensor.dark_sky_humidity.state | float < 90 and states.sensor.bathroom_humidity.state | float - states.sensor.lounge_humidity.state | float > 15 }}'
Based on the idea of using templates, I found a way to get my two motion sensors in the bathroom to function as one:
binary_sensor:
    sensors:
      master_bath_sensors:
        friendly_name: "Master Bath Sensors"
        value_template: >-
          {{ is_state('binary_sensor.master_toilet_motion_sensor', 'on')
             or is_state('binary_sensor.master_sink_motion_sensor', 'on') }}
now in my automation, i can do:
- alias: Master Bath Auto Off
  - entity_id: binary_sensor.master_bath_sensors
    for: '00:15:00'
    platform: state
    to: 'off'
     <snip>
so now, so long as there is motion on one of the sensors, the automation will not trigger. hope this helps someone who wants something similar…
Smooth !
Thanks, I was struggling with this. Works perfectly.
Michael
Rather than setting up a template can’t you just put the two sensors in a group?
yes, that probably would work as well… didn’t know about groups when i was working on this. which is one of the main challenges with learning to use HA. it can be difficult to find the best method to solve a particular problem, unless someone has already posted a similar use case.
I was looking for the way of using AND (Events Trigger), I tried solutions above but it’s not worked. Please help.
I have Sonoff RF 3 buttons, Sonoff RF bridge and using Sonoff Lan to integrated to Home Assistant.
- id: '1599813275658'
  alias: Test
  - event_data:
      command: 0
    event_type: sonoff.remote
    platform: event
  - event_data:
      command: 1
    platform: event
  - data: {}
There’s no such thing as an AND trigger, especially for events. The two events will never happen at the same time there will always be a small delay between them.
You could create input_booleans that get turned on when the event happens, but to be honest this will get very complex and tricky.
What are you trying to achieve?
I have 3 RF buttons can trigger 3 automations by events through Sonoff RF bridge (Sonoff Lan). I want to press button 1, and after 2s press button 2 (or other scenario of buttons press combination) to trigger other automation. Any solution without buy more buttons. Thanks.
I’d wait for version 0.115, from what I understand it should be possible to do this with the new wait_for_trigger.
I have an automation (closing my blinds) triggered 30mn after sunset with :
  - platform: sun
    event: sunset
    offset: '00:30:00'
Within the same automation (ideally) I would like to also close the blinds at sunset (no offset) IF temperature is below 1°C
    entity_id: weather.home
    below: '1'
Is it possible to combine :
at sunset + 30mn
OR
at sunset if temp < 1°
I’m not sure about the mix between triggers, conditions and or/and :confused:
Thank you for your tips
You can use options for that.
I didn’t complete option 2 but I think you get the idea.
Thank you for your suggestion.
I started implementing it when I realized that multiple triggers are OR by default according to the first messages of this thread.
And this is exactly what I need. I’m not sure why I didn’t try that 5 months ago :man_shrugging:
Anyways, here is my yaml which I will watch in the coming days to make sure it does what I intend :wink:
alias: 'Blinds : close downstairs 50mn after sunset or if temp below 5'
description: >-
  Close the downstairs blinds 50 minutes after sunset
  - platform: sun
    event: sunset
    offset: '00:50:00'
    entity_id: weather.bry_sur_marne
    attribute: temperature
    below: '5'
  - device_id: 8d429a48fde411ea9755eb6a665b17b6
    domain: cover
    entity_id: cover.living_room_blind
    type: close
  - device_id: 8d423ac4fde411eaadf487945d441678
    domain: cover
    entity_id: cover.study_blind
    type: close
  - device_id: 8d427234fde411ea8129e33251c2b884
    domain: cover
    entity_id: cover.kitchen_blind
    type: close
  - service: notify.mobile_app_nokia_7_plus
      message: Downstairs blinds are closing
mode: single
Triggers are always OR, not just by default, there’s no such thing as AND trigger. There’s never to things hapening at the exact same time.
