Multiple Tuya Hubs In HA
I have found out I’ve got multiple Tuya Hubs in HA. I guess its been creating a new hub when I’ve been adding devices. Does this matter? Can I remove any of the hubs without causing myself a lot of work? Everything is and has been working fine but I guess simple is better than this setup. Thanks
Hello charsiufan,
If it’s Tuya, and it’s working consistently, that thank your deity and let it run…
Tuya can be… special.
Thanks. So far, using quite a few Tuya smart sockets (maybe around 30) I’ve had no issues over the last few years.
The motion / presence detectors on the other hand…
Just want to say that I see the same thing in my configuration. I have also noticed that when deleting a hub you lose Tuya devices.
I think it must be possible to have only one hub but I am afraid that you need to setup the Tuya integration from scratch.
And perhaps after some time new hubs will ‘pop-up’ again…
So, let it be as long the Tuya devices workt without a problem.
