Have just updated to HA 0.86 and am ready to dive into Lovelace. It looks like the developers are recommending we use the UI-only method (i.e. no config files). If this is the case, how do you create multiple views using only the UI?
Do you mean tabs? If you go into the UI editor, you should get a “+” mark at the top. When you click on it, you should be able to create a new view
Thanks… I missed that!
