Ok so i must admit i made a bit of an embarrassing mistake here. The log file was not updated so the token for the second vacuum was not available.
After a bit of tinkering i got the new token in for the second vacuum.
Now both are visible and available in HA =)
Thanks for the help!
Original:
I tried this now and the result was that the entities disappeared when adding the “name:”. I tried it with just the single vacuum as well with the same result.
