HI
i have multiple Z-wave relay switch around 30 some of them not showing there name
its show ready but some switch but cant see in listing ,please help me whats reason
thansk
HI
thansk
I changed mine manually in the file in your .homeassistant directory, I’m using a Z-Wave Plus Aeotec Z-Stick and I couldn’t get mine to name properly until I altered the zwcfg xml file in this directory where your configuration.yaml is, found each in this file and changed the names <Node id=“3” name=“Hall Light” …
Believe you can now alter in HA but haven’t got around to that in the interface.
Hi
thanks for quick reply but i have another problem when i look at my zwcf.xml where what i found about some nodes
i can t see its switch type and no other information,i test all switch on openhab2 its all working ok,
i thing HA not work ok with multiple z-wave mesh network where multiple nodes comes to gather dont know just guess but has some problem in HA,any expert may help ,
looking for some one who can answer this whats wrong and where ?
Did you just pair these devices or have you had them running correctly before? Whenever I’ve included a new zwave device, they always show up as you’ve described. The proper names do not populate until I’ve restarted HA.
yes all these paird ok ,before that i have also this doubt but then i install openhab2 and test there it work ok.
but in HA i m getting problem.
if you need openhab then i can provide here.
but something is wrong
