martikainen
(Mattias Martikainen)
April 13, 2017, 7:44am
1
Hi
I have a few sensors measuring the current power usage and the total consumption since last reset,
What I would like to do is to multiply the value this template sensor is presenting with the cost of electricity, for examle 2kr (swedish currency) per kWh.
Is there any way to add another sensor taking the value from the below template sensor and multiplying it with a given number? (Of course it would be cooler to retrieve the current cost from my power distributor but that would be the next step
platform: template
sensors:
total_power_usage:
value_template: '{{ ((states.sensor.pc_power_2_4.state | float) +
(states.sensor.server_power_3_4.state | float) +
(states.sensor.frys_power_7_8.state | float) +
(states.sensor.kyl_power_8_8.state | float) +
(states.sensor.soffa_power_6_8.state | float) +
(states.sensor.sovrum_power_10_8.state | float) +
(states.sensor.tvattmaskin_power_9_8.state | float) +
(states.sensor.tvsovrum_power_5_8.state | float)) | round(1) }}'
friendly_name: 'Total power usage'
unit_of_measurement: 'w'
martikainen
April 13, 2017, 9:25am
2
Managed to solve it!
This is the code for calculating the cost off the current usage right now, i used the template sensor from the code in my previous post
platform: template
sensors:
total_power_cost:
value_template: '{{ ((states.sensor.total_power_usage.state | float * 1 / 1000 *1.885)) | round(2) }}'
friendly_name: 'Current cost'
unit_of_measurement: 'kr'
And a sensor for calculating the total cost since last reset, I’ll try to find a way to calculate it on a month basis
The sensor that sums up all power measurements
platform: template
sensors:
total_energy_used:
value_template: '{{ ((states.sensor.tvsovrum_energy_5_0.state | float) +
(states.sensor.frys_energy_7_0.state | float) +
(states.sensor.kyl_energy_8_0.state | float) +
(states.sensor.pc_energy_2_0.state | float) +
(states.sensor.server_energy_3_0.state | float) +
(states.sensor.soffa_energy_6_0.state | float) +
(states.sensor.sovrum_energy_10_0.state | float) +
(states.sensor.hall_energy_11_0.state | float) +
(states.sensor.tvattmaskin_energy_9_0.state | float)) | round(0) }}'
friendly_name: 'Total used'
unit_of_measurement: 'kWh'
And the calculation
platform: template
sensors:
total_energy_cost:
value_template: '{{ ((states.sensor.total_energy_used.state | float * 1.885)) | round(0) }}'
friendly_name: 'Total cost'
martikainen:
previous
Works like a charm, thanks!
Did you figure out how to show it per day or month?
martikainen
December 8, 2017, 8:58am
4
unfortunately I never found a way to even start figuring it out =/
xbmcnut
(xbmcnut)
February 8, 2019, 3:20am
6
martikainen:
Hi there. I’m wanting to do the same thing as you and then feed the result into the new utility_meter , but I’m unsure about your sensors. Mine are listed below that I want to add together.
- sensor.xiaomi_office_power
- sensor.xiaomi_tv_power
- sensor.cupboard_light_power
- sensor.davids_light_power
- sensor.lounge_light_power
- sensor.washing_machine_power
- sensor.zwave_garage_light_south_power
- sensor.family_room_shelly_power
- sensor.stairs_shelly_power
Where did you derive the sensor for your value template? Not quite sure how you got
Any feedback would be appreciated.
uiguy
February 14, 2019, 1:27am
7
states.sensor.total_power_usage.state is the total of adding your individual sensors using this template:
platform: template
sensors:
total_energy_used:
value_template: '{{ ((states.sensor.xiaomi_office_power.state | float) +
(states.sensor.xiaomi_tv_power.state | float) +
(states.sensor.cupboard_light_power.state | float) +
I have changed the first couple for you so you get the gist… this will then create the sensor you need for your second template sensor. total_energy_used:
use this sensor in the utility monitor…
I have also taken it a step further and calculated the cost with these template sensors (I had to add my off-peak and peak each being muliplied by their respective tarriff:
sensors:
offpeak_monthly_electricty_cost:
value_template: '{{ ((states.sensor.monthly_energy_offpeak.state | float * 0.078)) | round(0) }}'
friendly_name: 'Off Peak Monthly cost'
unit_of_measurement: 'ÂŁ'
sensors:
value_template: '{{ ((states.sensor.monthly_energy_peak.state | float * 0.155)) | round(0) }}'
friendly_name: 'Peak Monthly cost'
sensors:
total_electricity_used:
value_template: '{{ ((states.sensor.offpeak_monthly_electricty_cost.state | float) +
(states.sensor.peak_monthly_electricty_cost.state | float)) | round(2) }}'
xbmcnut
(xbmcnut)
February 14, 2019, 1:44am
8
Thanks for that, very much appreciated.
uiguy
February 14, 2019, 7:59am
9
It’s the least I could do for all your help with my (now bluetooth enabled) NUC
You may want to look at getting a Loop energy monitor. There is an official HA component and it is relativly cheap (ÂŁ65) and dead easy to setup.
More sofiaticated ones will identify appliance signatures(power per appliance) but this one works pretty well to give tou your total household usage.
Vlad0
February 17, 2019, 10:59am
10
Any idea what is wrong here?
sensors:
energy:
value_template: '{{ ((states.sensor.sonoff_10006f9587_power | float) + (states.sensor.sonoff_10006f98cc_power | float)) | round(0) }}'
friendly_name: 'Power'
unit_of_measurement: 'W'
I’m getting value 0 all the time, while both sensors can read value, no errors in log.
Also would it be possible to set
icon: mdi:flash-outline
for my custom calculate sensor samehow?
uiguy
February 18, 2019, 8:57pm
11
value_template: '{{ ((states.sensor.sonoff_10006f9587_power.state
you need to add “.state” to the end of your sensor. I have corrected your code below:
sensors:
energy:
value_template: '{{ ((states.sensor.sonoff_10006f9587_power.state | float) + (states.sensor.sonoff_10006f98cc_power | float)) | round(0) }}'
xbmcnut
(xbmcnut)
March 4, 2019, 10:50pm
12
I’m in the process of adding your costing templates now which should be great but I need to divide the monthly electricity amount by 1000 as they are reporting W instead of kWh.
xbmcnut
(xbmcnut)
March 4, 2019, 11:05pm
13
I ended up doing this which works:
| float)) | multiply(0.001) | round(4) }}'
friendly_name: 'Total Power Use'
xbmcnut
(xbmcnut)
March 4, 2019, 11:07pm
14
Whoops, that screws the daily and monthly calcs for utility_meter. Trying again.
EDIT: Sorted. Moved the multiply(0.001)
to the costing calculation template
server_monthly_electricty_cost:
value_template: '{{ ((states.sensor.server_m.state | multiply(0.001) | float * 0.2023)) | round(2) }}'
friendly_name: 'Server Monthly Cost'
unit_of_measurement: '$'
uiguy
March 5, 2019, 8:04am
15
Lol, you beat me to it… i was about to suggest that… glad you got it working… the next step is to now incorporate somehow the rss feed for fuel prices… imagine if home assistant could automatically switch your fuel suppliers based on the cheapest rate…!
Vasco
April 8, 2019, 10:45pm
16
Ok, I am doing something wrong here. Hope anyone can help me out a bit.
The error I am getting:
Log Details (ERROR)
Tue Apr 09 2019 00:36:59 GMT+0200 (CEST)
Invalid config for [sensor.template]: required key not provided @ data['sensors']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
my configuration,yaml file:
total_energy_cost:
value_template: '{{ ((sensor.power_today | float * 1.885)) | round(0) }}'
unit_of_measurement: '€'
I don’t need to sum up different value’s. Just have 2 values which I want to show the currency form from, the sensors:
sensor.power_today
Attributes for this sensor:
unit_of_measurement: kWh
friendly_name: Power_today
icon: mdi:power-plug
sensor.gas_today
unit_of_measurement: M3
friendly_name: Gas_today
icon: mdi:gas-cylinder
Can anyone please help me into the right direction?
Template extension wasn’t defined.
total_energy_cost:
value_template: '{{ (states('sensor.power_today') | float * 1.885) | round(0) }}'
Look here for more examples:
Vasco
April 8, 2019, 11:14pm
18
Thanks! Got it up and running now
yonny24
September 4, 2021, 3:31pm
19
Perfect. I’ve been doing the same but haven’t managed to split the 4 hours of peak time yet.
I’ll have a go at this.
almonteco
(Almonteco)
October 8, 2021, 2:27am
20
Hello All,
I need help!..I am on the quest of creating a custom template sensor; where I use the value from one entity and multiply that value by the number 5000.
The goal here is that I added the yahoo finance integration to my HA and want to use a stock’s current price (entity value) AND times that number by the number of shares that I have for it (5000).
sensors:
mystock_holding:
friendly_name: My Stock Holding's Value
value_template: "{{ (states('sensor.yahoofinance_ticker_usd') | float * 5000) | round(0) }}"
I have attempted everything on this page, as well as other threads, but cant seem to output the desired calculation. What I get is either the “on” or the “unavailable” values.
Image of UI:
Thank you in advance
I can’t see anything wrong with this value_template. Can you show a screenshot of what the developer tools page shows for the sensor sensor.mystock_holding
and also sensor.yahoofinance_ticker_usd
I wonder if the USD is actually part of the state of that sensor rather than a unit of measurement.
