Hello same problem for me. It seems not working.
In the logs of Sylab addon I see:
[09:02:41] INFO: The otbr-web is disabled.
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/check-cpcd-shm.sh
[09:02:41] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Jan 24 2024 17:58:11) starting
cont-init: info: /etc/cont-init.d/check-cpcd-shm.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
Add-on: Silicon Labs Multiprotocol
Zigbee and OpenThread multiprotocol add-on
Add-on version: 2.4.4
You are running the latest version of this add-on.
System: Home Assistant OS 12.0 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.2.5
Home Assistant Supervisor: 2024.02.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[09:02:43] INFO: Flashing firmware is disabled
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service cpcd-config: starting
[09:02:45] INFO: Generating cpcd configuration.
s6-rc: info: service cpcd-config successfully started
s6-rc: info: service cpcd: starting
[09:02:45] INFO: Starting cpcd...
WARNING in function 'main' in file /usr/src/cpc-daemon/main.c at line #186 : Running CPCd as 'root' is not recommended. Proceed at your own risk.
[09:02:45:554778] Info : [CPCd v4.3.1.0] [Library API v3] [RCP Protocol v4]
[09:02:45:554945] Info : Git commit: 133b29678b3d0bc7578e098d2f46b4d5bcd2ebb4 / branch:
[09:02:45:554949] Info : Sources hash: ff8300587e7e4ab1def7a89a272c0baef32f9eb3bff9b0ba06b94e655d652367
[09:02:45:554966] WARNING : In function 'main' in file /usr/src/cpc-daemon/main.c at line #186 : Running CPCd as 'root' is not recommended. Proceed at your own risk.
[09:02:45:554999] Info : Reading cli arguments
[09:02:45:555009] Info : /usr/local/bin/cpcd
[09:02:45:562837] Info : Reading configuration
[09:02:45:562857] Info : file_path = /usr/local/etc/cpcd.conf
[09:02:45:562860] Info : instance_name = cpcd_0
[09:02:45:562863] Info : socket_folder = /dev/shm
[09:02:45:562866] Info : operation_mode = MODE_NORMAL
[09:02:45:562868] Info : use_encryption = false
[09:02:45:562871] Info : binding_key_file = /etc/binding-key.key
[09:02:45:562873] Info : stdout_tracing = false
[09:02:45:562875] Info : file_tracing = false
[09:02:45:562878] Info : lttng_tracing = false
[09:02:45:562880] Info : enable_frame_trace = false
[09:02:45:562882] Info : traces_folder = /dev/shm/cpcd-traces
[09:02:45:562884] Info : bus = UART
[09:02:45:562887] Info : uart_baudrate = 460800
[09:02:45:562890] Info : uart_hardflow = false
[09:02:45:562892] Info : uart_file = /dev/ttyUSB0
[09:02:45:562894] Info : fu_recovery_pins_enabled = false
[09:02:45:562897] Info : fu_connect_to_bootloader = false
[09:02:45:562899] Info : fu_enter_bootloader = false
[09:02:45:562901] Info : restart_cpcd = false
[09:02:45:562904] Info : application_version_validation = false
[09:02:45:562906] Info : print_secondary_versions_and_exit = false
[09:02:45:562908] Info : use_noop_keep_alive = false
[09:02:45:562911] Info : reset_sequence = true
[09:02:45:562913] Info : stats_interval = 0
[09:02:45:562915] Info : rlimit_nofile = 2000
[09:02:45:562918] Info : ENCRYPTION IS DISABLED
[09:02:45:562920] Info : Starting daemon in normal mode
[09:02:45:580582] Info : Connecting to Secondary...
[09:02:47:581071] Info : Failed to connect, secondary seems unresponsive
[09:02:47:581103] Info : Connecting to Secondary...
[09:02:49:581382] Info : Failed to connect, secondary seems unresponsive
[09:02:49:581422] Info : Connecting to Secondary...
[09:02:51:581651] Info : Failed to connect, secondary seems unresponsive
[09:02:51:581684] Info : Connecting to Secondary...
[09:02:53:581851] Info : Failed to connect, secondary seems unresponsive
[09:02:53:581884] Info : Connecting to Secondary...
[09:02:55:582141] Info : Failed to connect, secondary seems unresponsive
[09:02:55:582189] Info : Connecting to Secondary...
[09:02:57:582402] Info : Failed to connect, secondary seems unresponsive
[09:02:57:582435] Info : Connecting to Secondary...
My configuration:
device: >-
/dev/serial/by-id/usb-Nabu_Casa_SkyConnect_v1.0_5085f9eb1e7ded1194bfbd6c4fc49859-if00-port0
baudrate: "460800"
flow_control: false
autoflash_firmware: false
cpcd_trace: false
otbr_enable: true
otbr_log_level: notice
otbr_firewall: true
Then Z2M refuse to start:
Zigbee2MQTT:error 2024-02-27 22:07:52: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-02-27 22:07:52: Exiting...
Zigbee2MQTT:error 2024-02-27 22:07:53: Error: Failure to connect
at Ezsp.connect (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/ezsp.ts:364:19)
at Driver.startup (/app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/driver.ts:158:13)
at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29)
at Zigbee.start (/app/lib/zigbee.ts:60:27)
at Controller.start (/app/lib/controller.ts:109:27)
at start (/app/index.js:107:5)
I tried with port tcp://core-silabs-multiprotocol:9999 and Z2M restart always wihtout message.
Port 9999 is not open on my HA box:
$ nmap -Pn 192.168.1.64
Starting Nmap 7.92 ( https://nmap.org ) at 2024-03-02 09:06 CET
Nmap scan report for ha-server-pi-eth.home (192.168.1.64)
Host is up (0.012s latency).
Not shown: 993 closed tcp ports (conn-refused)
PORT STATE SERVICE
53/tcp open domain
111/tcp open rpcbind
139/tcp open netbios-ssn
443/tcp open https
445/tcp open microsoft-ds
5050/tcp open mmcc
8086/tcp open d-s-n
Nmap done: 1 IP address (1 host up) scanned in 0.98 seconds
My z2M configuration:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt:
server: mqtt://192.168.1.64:1883
base_topic: zigbee2mqttHA
user: mqtt
password: xxxxxxx
serial:
adapter: ezsp (try with or without)
port: tcp://core-silabs-multiprotocol:9999
baudrate: 460800 (try with 115200)
rtscts: true (try with or without)
advanced:
channel: 20
log_level: debug
Any help would be greatly appreciated
