Hi all,
I’ve seen multiple topics about multiroom audio. If I understand correctly, most of them use something like snapcast or other software running on a Raspberry Pi. Also if I understand correctly, every ‘speaker’ needs to have a seperate Pi connected to it as the audio source (over 3.5mm jack I guess?).
Now, with all the current speakers and streaming options included with it, I was wondering if the following scenario could be created a bit more ‘natively’’:
Let’s say we have a Soundbar in the living room with google cast functionality (For i.e. the ‘HEOS by Denon Bar’ ), a Google Home Mini in the Kitchen, a TV with a Chromecast in it upstairs and ideally also a bluetooth speaker floating around the house, but always within reach of the Kitchen GH Mini.
Wouldn’t it somehow be possible to ‘stream/cast’ (for i.e. Spotify or TuneIn) to all or some of these devices using Home Assistant? Ideally including some kind of syncing and off course master + separate volume control in LoveLace?
To be clear, without the need to put any device (manually) to the correct input source on forehand, and without seperate Pi’s or similar for the different devices?
Maybe it’s a proven thing already, but I didn’t happen to find usefull info about this.
Thanks in advance!
