Multiscrape FirstEnergy JCP&L Website for Home Electric Usage Data
Hi. I’ve been trying for the past few days to multiscrape the Jersey Central Power & Light (a FirstEnergy company) website to get electric usage stats without luck. Using GitHub - danieldotnl/ha-multiscrape: Home Assistant custom component for scraping (html, xml or json) multiple values (from a single HTTP request) with a separate sensor/attribute for each value. Support for (login) form-submit functionality..
The URL with the data is at Log In (specific kWh selector is “#usage-history-table > tbody > tr:nth-child(1) > td:nth-child(4) > span”) which, when accessed, redirects the user to a login page here: Log In. On the login page is a form for username and password.
Here is the configuration I’ve tried without luck:
multiscrape:
  - resource: 'https://www.firstenergycorp.com/my_account/view_usage_history.html'
    name: FirstEnergy Electric Data
    scan_interval: 60
    form_submit:
      submit_once: True
      resource: 'https://www.firstenergycorp.com/content/customer/log_in.html'
      select: "#main-content-wrap > section > div.subpage-template.subpage-template2.subpage-template2--1col_centered > div > div:nth-child(2) > div.mainpar.parsys > div.loginwithregister.section > div > div:nth-child(2) > div:nth-child(1) > div > form"
      input:
        login: [email protected]
        password: '12345678'
      - select: '#usage-history-table > tbody > tr:nth-child(1) > td:nth-child(4) > span'
I receive the following error in the log:
This error originated from a custom integration.
Logger: custom_components.multiscrape.coordinator
Source: custom_components/multiscrape/coordinator.py:75
Integration: Multiscrape scraping component (documentation, issues)
First occurred: 7:36:25 PM (2 occurrences)
Last logged: 7:36:59 PM
FirstEnergy Electric Data # Exception in form-submit feature. Will continue trying to scrape target page. Client error '403 Forbidden' for url 'https://www.firstenergycorp.com/log_in.fecorplogin.html' For more information check: https://httpstatuses.com/403
And,
Logger: custom_components.multiscrape.sensor
Source: custom_components/multiscrape/sensor.py:172
First occurred: 7:36:28 PM (2 occurrences)
FirstEnergy Electric Data # kWh Used Last Month # Unable to scrape data: Could not find a tag for given selector Consider using debug logging and log_response for further investigation.
Also, I cannot for the life of me figure out how to enable the debug logging…
I’d appreciate any help.
Did you ever figure this out? I’d like to do the same.
I’m on the same boat, have any of you figured it out?
