I’m trying to scrape the following.
I want to get this information:
When I run in the debugger and break on this area. I can see the code looks like
If I select and copy CSS Selector it give me:
span.msg_tline:nth-child(1)
This is for the line that has “Furnace Status”
For the next line, that says Idle
span.msg_tline:nth-child(2)
All the rest are nth-child(3-6)
The line with the actual value returns a CSS Selector of: #param_0, 1, 2, 3
There is an additional value called inner HTML that contains the value I want.
How do I go about getting these values?
When I try to use:
- unique_id: loginPage
select: '#desktopUserName > h2:nth-child(1)'
- unique_id: loggedIn
select: "#desktopUserName > p:nth-child(2) > a:nth-child(1)"
- unique_id: siemenslogo
select: "#logo_iPad"
- unique_id: screen
select: "span.msg_tline:nth-child(2)"
I get an error: 2022-11-21 13:12:10.185 ERROR (MainThread) [custom_components.multiscrape.sensor] Furnace # entireScreen # Unable to scrape data: Could not find a tag for given selector
Debug Log Info:
2022-11-21 14:21:35.199 DEBUG (MainThread) [custom_components.multiscrape.sensor] Furnace # entireScreen # Start scraping to update sensor
2022-11-21 14:21:35.200 DEBUG (MainThread) [custom_components.multiscrape.scraper] Furnace # entireScreen # Tag selected: None
2022-11-21 14:21:35.200 DEBUG (MainThread) [custom_components.multiscrape.form] Furnace # Exception occurred while scraping, will try to resubmit
the form next interval.
2022-11-21 14:21:35.200 ERROR (MainThread) [custom_components.multiscrape.sensor] Furnace # entireScreen # Unable to scrape data: Could not find a
Consider using debug logging and log_response for further investigation.
Any insight would be appreciated.
thanks
