Multisensor devices imported from deCONZ gets different entity names each time?
Hi!
I have several Xiaomi ZigBee devices I import to Hass.io using the deCONZ integration. Each time I remove the integration and re-add it the entity names of the multisensors is randomized.
For example, I have a Xiaomi multisensor that gives me four different entities (temperature, humidity, air pressure and battery level). The entities for the kitchen sensor is named sensor.kitchen, sensor.kitchen_2, sensor.kitchen_3 and sensor.kitchen_battery_level.
Sometimes the temperature sensor is named sensor.kitchen. Sometimes it is named sensor.kitchen_2. It seems random what specific sensor gets a specific entity name.
This is breaking some of my other configuration, for example history graphs or termostats relaying on a specific sensor.
Is it possible to ALWAYS get the temperature sensor named sensor.kitchen, the humidity named sensor.kitchen_2 and air pressure sensor.kitchen_3?
Hi , I have the same issue and couldn’t find any solution until now.Did you solve your issue ?
No, I never found a solution so I need to rename the devices each time.
thanks for your quick answer.
But i m sure we are not the only ones with this issue ?
how are the others all doing ???
