Mushroom, Bubble card, Weather Card, Frigate don't work anymore
Hi everyone,
Sinoe today, i don’t know why but my dashboard look like that :slight_smile: I don’t know why… This morning it worked and i thought it was the update 2024.8 but I downgrade to 2024.7.4 and the result was the same :confused:
In HACS, Weather Chart Card, Mushroom, Bubble Card or Frigate are installed :confused:
Here my configuration :confused:
System Information
version core-2024.8.0
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.12.4
os_name Linux
os_version 6.6.31-haos-raspi
arch aarch64
timezone Europe/Paris
config_dir /config
Home Assistant Community Store
GitHub API ok
GitHub Content ok
GitHub Web ok
GitHub API Calls Remaining 4980
Installed Version 1.34.0
Stage running
Available Repositories 1460
Downloaded Repositories 18
HACS Data ok
Home Assistant Cloud
logged_in false
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 12.4
update_channel stable
supervisor_version supervisor-2024.08.0
agent_version 1.6.0
docker_version 26.1.4
disk_total 57.8 GB
disk_used 31.3 GB
healthy true
supported true
host_connectivity true
supervisor_connectivity true
ntp_synchronized true
virtualization
board rpi4-64
supervisor_api ok
version_api ok
installed_addons Terminal & SSH (9.14.0), Duck DNS (1.18.0), Whisper (2.1.2), Piper (1.5.2), Mosquitto broker (6.4.1), Zigbee2MQTT (1.39.1-1), ESPHome (2024.7.3), Studio Code Server (5.15.0), MyElectricalData (0.13.2), InfluxDB (5.0.0), openWakeWord (1.10.0), vosk (1.6.1), Fusion (2024.7.1), File editor (5.8.0)
Dashboards
dashboards 6
resources 3
error /config/ui-lovelace.yaml not found
views 29
mode yaml
Recorder
oldest_recorder_run 29 juillet 2024 à 11:04
current_recorder_run 8 août 2024 à 19:17
estimated_db_size 708.85 MiB
database_engine sqlite
database_version 3.45.3
Thanks for your help :slight_smile:
Try clearing a browser cache
Already done, didn’t work. Same for private navigation.
Okay, so in Settings > Dashboard > 3 dots > Ressources, everything disapeared except button card, layout card et swipe card. I add the module manually in configuration.yaml and now it’s okay.
