Mushroom Cards - Build a beautiful dashboard easily πŸ„ (Part 1)
Amazing, thank you
OK, this takes me down a new rabbit hole of knowledge, thanks again for sharing the know-how.
Love this contribution. I’m going around my current dashboard and trying to animate where I can using some of your examples. For the most part I’ve gotten everything figured out except this last little piece when trying to add in the chip styling code to remove the shadow and outline around the individual chips. Any tips on how to achieve this? Anything I’ve tried with card mod just disables the animation.
Providing my code and gif
chrome-capture-2022-9-4
type: custom:stack-in-card
cards:
    primary: Garage
    secondary: '{{ states(''sensor.livingroom'') }}'
    icon: mdi:garage
    entity: input_boolean.garage_light
    tap_action:
      action: navigate
      navigation_path: garage
    hold_action:
      action: toggle
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 56px;
          height: 66px;
          margin-left: -22px !important;
    chips:
      - type: template
        icon: mdi:washing-machine
        icon_color: |2-
            {% if is_state(entity, 'off') %}
            grey
            blue
        entity: sensor.washer
        tap_action:
          action: more-info
      - type: template
        icon: mdi:tumble-dryer
        icon_color: |2-
            grey
            red
        entity: sensor.dryer
        tap_action:
          action: more-info
    card_mod:
      style:
        mushroom-template-chip:nth-child(1)$: |
          {% if is_state('sensor.washer','on') %}
          ha-icon {
            animation: shake 800ms ease-in-out infinite, drum 2s ease infinite;
          @keyframes shake {
            0%, 100% { transform: translate(0, 0) rotate(0); }
            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
          @keyframes drum {
            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
        mushroom-template-chip:nth-child(2)$: |
          {% if is_state('sensor.dryer','on') %}
          ha-icon {
            animation: shake 800ms ease-in-out infinite, drum 1s infinite;
            transform-origin: 100% 100%;
          @keyframes shake {
            0%, 100% { transform: rotate(4deg); }
            50%  { transform: rotate(-4deg); }
          @keyframes drum {
            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
    alignment: end
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('input_boolean.garage_light', 'on') %}
         background: rgba(255, 152, 0, 0.1);
This should do the trick:
cards:
    primary: Garage
    icon: mdi:garage
    tap_action:
      action: navigate
    hold_action:
      action: toggle
    layout: horizontal
    card_mod:
      style: |
        :host {
          height: 66px;
    chips:
      - type: template
        icon_color: |2-
            grey
            blue
        tap_action:
          action: more-info
      - type: template
        icon_color: |2-
            grey
            red
        tap_action:
          action: more-info
    card_mod:
      style:
          ha-icon {
          @keyframes shake {
          @keyframes drum {
          ha-icon {
          @keyframes shake {
          @keyframes drum {
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 0;
    alignment: end
card_mod:
  style: |
    ha-card {
      height: 102px;
This is super exciting! I’ve been keeping a close eye on your examples, and am really excited to finally leverage (a.k.a. borrow :)) your code. Thanks again for being willing to share it.
Mushroom Animations :mushroom: - Part 2
Hit the limit for characters in a single post so have had to split it :grinning:
Mushroom Title Animations
These ones run once to transition in the Mushroom Title.
Mushroom Title Typewriter
Typewriter Animation
type: custom:mod-card
card:
  type: custom:mushroom-title-card
  title: Mushroom.
  subtitle: Typewriter
card_mod:
  style:
    mushroom-title-card$: |
      h1 {
        width: 9ch;
        animation: typing 5s steps(9), cursor 0.25s step-end 30 alternate;
        overflow: hidden;
        border-right: 2px solid transparent;
        font-family: monospace;
       @keyframes typing {
        0% { width: 0; }
      @keyframes cursor {
        50% { border-color: var(--primary-text-color); }
Mushroom Title Scale-In
Scale-in Animation
card:
  title: Mushroom πŸ„
  subtitle: Scale-in
card_mod:
  style:
          animation: scale-in 1s;
          transform-origin: 15%;
      @keyframes scale-in {
        0% { transform: scale(0); opacity: 0; }
        100% { transform: scale(1); opacity: 1; }
Mushroom Title Fade-In
Fade-in Animation
card:
  subtitle: Fade-in
card_mod:
  style:
        animation: fade 1s ease-in;
      @keyframes fade {
        0% { opacity: 0; }
        100% { opacity: 1; }
Mushroom Title Focus
Focus Animation
card:
  subtitle: Focus
card_mod:
  style:
        animation: focus 1.5s;
      @keyframes focus {
        0% { filter: blur(10px); opacity: 0; }
Mushroom Title Drop-In
Drop-in Animation
card:
  subtitle: Drop-in
card_mod:
  style:
        animation: drop-in 1.1s both;
      @keyframes drop-in {
        0% { transform: translateY(-400px); animation-timing-function: ease-in; filter: blur(40px); opacity: 0; }
        38% { transform: translateY(0); animation-timing-function: ease-out; filter: blur(0); opacity: 1; }
        55% { transform: translateY(-16px); animation-timing-function: ease-in; }
        72% { transform: translateY(0); animation-timing-function: ease-out; }
        81% { transform: translateY(-7px); animation-timing-function: ease-in; }
        90% { transform: translateY(0); animation-timing-function: ease-out; }
        95% { transform: translateY(-2px); animation-timing-function: ease-in; }
        100% { transform: translateY(0); animation-timing-function: ease-out; }
Mushroom Title Slide-In
Slide-in Animation
card:
  subtitle: Slide-in
card_mod:
  style:
        animation: slide-in 1.1s both;
      @keyframes slide-in {
        0% { transform: translateX(600px) scaleX(2.5) scaleY(0.2); animation-timing-function: ease-in; filter: blur(40px); opacity: 0; }
        38% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; filter: blur(0); opacity: 1; }
        55% { transform: translateX(68px) scaleY(1.1) scaleX(0.95); animation-timing-function: ease-in; }
        72% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; }
        81% { transform: translateX(32px) scaleY(1.05) scaleX(0.98); animation-timing-function: ease-in; }
        90% { transform: translateX(0) scaleY(1) scaleX(1); animation-timing-function: ease-out; }
        95% { transform: translateX(8px); animation-timing-function: ease-in; }
        100% { transform: translateX(0); animation-timing-function: ease-out; }
Mushroom Title Flicker
Flicker Animation
card:
  subtitle: Flicker
card_mod:
  style:
        animation: flicker 1.1s both;
      @keyframes flicker {
        0%, 10%, 10.2%, 20%, 20.6%, 30%, 30.6%, 45%, 55.1%, 57%, 60.1%, 65%, 75.1%, 77%, 85.1%, 86% { opacity: 0; }
        10.1%, 20.1%, 30.1%, 30.5%, 45.1%, 50%, 55%, 57.1%, 60%, 65.1%, 75%, 77.1%, 85%, 86.1%, 100% { opacity: 1; }
Mushroom Spinner Animations
Mushroom Comet Spinner
Comet Spinner
type: custom:mushroom-template-card
icon: none
primary: Comet
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        border-right: 4px solid;
        border-bottom: 4px solid transparent;
        --shape-animation: spin 1s linear infinite, comet 10s infinite;
        --shape-color: none;
        --icon-size: 38px;
      @keyframes comet {
        0% { border-right-color: rgb(var(--rgb-red)); }
        6.25% { border-right-color: rgb(var(--rgb-deep-orange)); }
        12.5% { border-right-color: rgb(var(--rgb-orange)); }
        18.75% { border-right-color: rgb(var(--rgb-amber)); }
        25% { border-right-color: rgb(var(--rgb-yellow)); }
        31.25% { border-right-color: rgb(var(--rgb-lime)); }
        37.5% { border-right-color: rgb(var(--rgb-light-green)); }
        43.75% { border-right-color: rgb(var(--rgb-green)); }
        50% { border-right-color: rgb(var(--rgb-teal)); }
        56.25% { border-right-color: rgb(var(--rgb-cyan)); }
        62.5% { border-right-color: rgb(var(--rgb-light-blue)); }
        68.75% { border-right-color: rgb(var(--rgb-blue)); }
        75% { border-right-color: rgb(var(--rgb-indigo)); }
        81.25% { border-right-color: rgb(var(--rgb-deep-purple)); }
        87.5% { border-right-color: rgb(var(--rgb-purple)); }
        93.75% { border-right-color: rgb(var(--rgb-pink)); }
        100% { border-right-color: rgb(var(--rgb-red)); }
Mushroom Crescent Spinner
Crescent Spinner
icon: none
primary: Crescent
card_mod:
  style:
      .shape {
        border: 1px solid rgba(var(--rgb-disabled), 0.8);
        border-right: 3px solid rgba(var(--rgb-light-blue));
        --shape-animation: spin 1s linear infinite;
        --icon-size: 40px;
Mushroom Munch Spinner
Munch Spinner
icon: none
primary: Munch
card_mod:
  style:
      ha-icon, .shape {
        --icon-animation: spin 1.5s linear infinite reverse;
        --shape-animation: spin 2s linear infinite;
        border-radius: 50%;
        border: 4px solid transparent;
        border-top-color: rgb(var(--rgb-amber));
        --icon-symbol-size: 34px;
        --icon-size: 34px;
Mushroom Double Spinner
Double Spinner
icon: none
primary: Double
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 1s linear infinite reverse;
        border-radius: 50%;
        border: 4px double transparent;
        border-top-color: rgb(var(--rgb-deep-orange));
      .shape {
        border-left-color: rgb(var(--rgb-amber));
        border-bottom-color: rgb(var(--rgb-amber));
        --icon-symbol-size: 20px;
        --icon-size: 34px;
Mushroom St. Nick Spinner
St. Nick Spinner
icon: none
primary: St. Nick
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 0.5s linear infinite reverse;
        border-radius: 50%;
        border: 8px dotted rgb(var(--rgb-red));
      .shape {
        border: 4px dashed rgb(var(--rgb-green));
        --icon-symbol-size: 5px;
        --icon-size: 34px;
Mushroom Gradient Spinner
Gradient Spinner
icon: none
primary: Gradient
card_mod:
  style:
      .shape {
         background: radial-gradient(farthest-side, rgb(var(--rgb-blue)) 94%, transparent) top/4px 4px no-repeat, conic-gradient(transparent 30%, rgb(var(--rgb-blue)));
         -webkit-mask: radial-gradient(farthest-side, transparent calc(100% - 4px), #000 0);
         --shape-animation: spin 1s infinite linear;
Mushroom Dots Spinner
Dots Spinner
icon: none
primary: Dots
card_mod:
  style:
      .shape {
          border: 4px dotted transparent;
          --shape-animation: spin 800ms ease-in-out infinite, color 10s infinite;
          --icon-size: 34px;
      @keyframes color {
        0% { border-right-color: rgb(var(--rgb-red)); border-top-color: rgb(var(--rgb-red)); }
        6.25% { border-right-color: rgb(var(--rgb-deep-orange)); border-top-color: rgb(var(--rgb-deep-orange)); }
        12.5% { border-right-color: rgb(var(--rgb-orange)); border-top-color: rgb(var(--rgb-orange)); }
        18.75% { border-right-color: rgb(var(--rgb-amber)); border-top-color: rgb(var(--rgb-amber)); }
        25% { border-right-color: rgb(var(--rgb-yellow)); border-top-color: rgb(var(--rgb-yellow)); }
        31.25% { border-right-color: rgb(var(--rgb-lime)); border-top-color: rgb(var(--rgb-lime)); }
        37.5% { border-right-color: rgb(var(--rgb-light-green)); border-top-color: rgb(var(--rgb-light-green)); }
        43.75% { border-right-color: rgb(var(--rgb-green)); border-top-color: rgb(var(--rgb-green)); }
        50% { border-right-color: rgb(var(--rgb-teal)); border-top-color: rgb(var(--rgb-teal)); }
        56.25% { border-right-color: rgb(var(--rgb-cyan)); border-top-color: rgb(var(--rgb-cyan)); }
        62.5% { border-right-color: rgb(var(--rgb-light-blue)); border-top-color: rgb(var(--rgb-light-blue)); }
        68.75% { border-right-color: rgb(var(--rgb-blue)); border-top-color: rgb(var(--rgb-blue)); }
        75% { border-right-color: rgb(var(--rgb-indigo)); border-top-color: rgb(var(--rgb-indigo)); }
        81.25% { border-right-color: rgb(var(--rgb-deep-purple)); border-top-color: rgb(var(--rgb-deep-purple)); }
        87.5% { border-right-color: rgb(var(--rgb-purple)); border-top-color: rgb(var(--rgb-purple)); }
        93.75% { border-right-color: rgb(var(--rgb-pink)); border-top-color: rgb(var(--rgb-pink)); }
        100% { border-right-color: rgb(var(--rgb-red)); border-top-color: rgb(var(--rgb-red)); }
Mushroom Radial Spinner
Radial Spinner
icon: none
primary: Radial
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 1.5s linear infinite;
        border-radius: 50%;
        border: 3px solid rgb(var(--rgb-blue));
        border-right-color: transparent;
      .shape {
        border: 3px solid rgb(var(--rgb-red));
        --icon-symbol-size: 24px;
        --icon-size: 36px;
Mushroom Dual Spinner
Dual Spinner
icon: none
primary: Dual
card_mod:
  style:
      .shape {
        --shape-animation: spin 1s ease infinite;
        border-bottom-color: rgb(var(--rgb-deep-orange));
        --shape-color: none !important;
        --icon-size: 34px;
Mushroom Morse Spinner
Morse Spinner
icon: none
primary: Morse
card_mod:
  style:
      ha-icon {
        border-radius: 50%;
        border: 4px dashed transparent;
        border-left-color: rgb(var(--rgb-pink));
      .shape {
        border-left-color: rgb(var(--rgb-purple));
        --icon-size: 34px;
Mushroom Fade Spinner
Fade Spinner
icon: none
primary: Fade
card_mod:
  style:
      .shape {
        --shape-animation: fade 25s linear infinite reverse;
      @keyframes fade {
        6.24%, 12.49%, 18.74%, 24.99%, 31.24%, 37.49%, 43.74%, 49.99%, 56.24%, 62.49%, 68.74%, 74.99%, 81.24%, 87.49%, 93.74%, 100%  { box-shadow: 0 0 20px 20px transparent inset; }
        0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7) inset; }
        6.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-deep-orange), 0.7) inset; }
        12.5% { box-shadow: 0 0 0 0 rgba(var(--rgb-orange), 0.7) inset; }
        18.75% { box-shadow: 0 0 0 0 rgba(var(--rgb-amber), 0.7) inset; }
        25% { box-shadow: 0 0 0 0 rgba(var(--rgb-yellow), 0.7) inset; }
        31.25% { box-shadow: 0 0 0 0 rgba(var(--rgb-lime), 0.7) inset; }
        37.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-green), 0.7) inset; }
        43.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-green), 0.7) inset; }
        50% { box-shadow: 0 0 0 0 rgb(var(--rgb-teal), 0.7) inset; }
        56.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-cyan), 0.7) inset; }
        62.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-light-blue), 0.7) inset; }
        68.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-blue), 0.7) inset; }
        75% { box-shadow: 0 0 0 0 rgb(var(--rgb-indigo), 0.7) inset; }
        81.25% { box-shadow: 0 0 0 0 rgb(var(--rgb-deep-purple), 0.7) inset; }
        87.5% { box-shadow: 0 0 0 0 rgb(var(--rgb-purple), 0.7) inset; }
        93.75% { box-shadow: 0 0 0 0 rgb(var(--rgb-pink), 0.7) inset; }
Mushroom Dotty Spinner
Dotty Spinner
icon: mdi:dots-circle
primary: Dotty
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 1s linear infinite reverse, color 60s infinite;
      @keyframes color {
        0% { border-color: rgb(var(--rgb-red)); color: rgb(var(--rgb-red)); }
        6.25% { border-color: rgb(var(--rgb-deep-orange)); color: rgb(var(--rgb-pink)); }
        12.5% { border-color: rgb(var(--rgb-orange)); color: rgb(var(--rgb-purple)); }
        18.75% { border-color: rgb(var(--rgb-amber)); color: rgb(var(--rgb-deep-purple)); }
        25% { border-color: rgb(var(--rgb-yellow)); color: rgb(var(--rgb-indigo)); }
        31.25% { border-color: rgb(var(--rgb-lime)); color: rgb(var(--rgb-blue)); }
        37.5% { border-color: rgb(var(--rgb-light-green)); color: rgb(var(--rgb-light-blue)); }
        43.75% { border-color: rgb(var(--rgb-green)); color: rgb(var(--rgb-cyan)); }
        50% { border-color: rgb(var(--rgb-teal)); color: rgb(var(--rgb-teal)); }
        56.25% { border-color: rgb(var(--rgb-cyan)); color: rgb(var(--rgb-green)); }
        62.5% { border-color: rgb(var(--rgb-light-blue)); color: rgb(var(--rgb-light-green)); }
        68.75% { border-color: rgb(var(--rgb-blue)); color: rgb(var(--rgb-lime)); }
        75% { border-color: rgb(var(--rgb-indigo)); color: rgb(var(--rgb-yellow)); }
        81.25% { border-color: rgb(var(--rgb-deep-purple)); color: rgb(var(--rgb-amber)); }
        87.5% { border-color: rgb(var(--rgb-purple)); color: rgb(var(--rgb-orange)); }
        93.75% { border-color: rgb(var(--rgb-pink)); color: rgb(var(--rgb-deep-orange)); }
        100% { border-color: rgb(var(--rgb-red)); color: rgb(var(--rgb-red)); }
      .shape {
        border: 5px dotted transparent;
        --shape-animation: spin 2s linear infinite, color 60s infinite;
        --icon-symbol-size: 30px;
        --icon-size: 32px;
Mushroom Plain Spinner
Plain Spinner
icon: none
primary: Plain
card_mod:
  style:
      .shape {
        border: 5px solid rgb(var(--rgb-disabled));
        border-left-color: transparent;
        --icon-size: 32px;
Mushroom Toggle Spinner
Toggle Spinner
icon: none
primary: Toggle
card_mod:
  style:
      ha-icon {
        border-radius: 50%;
        border-left-color: rgb(var(--rgb-cyan));
      .shape {
        --icon-size: 34px;
Mushroom Spheres Spinner
Spheres Spinner
icon: none
primary: Spheres
card_mod:
  style:
      ha-icon {
        border-radius: 50%;
        border: 12px dotted transparent;
        border-left-color: rgb(var(--rgb-blue));
      .shape  {
        border-left-color: rgb(var(--rgb-red));
        --icon-symbol-size: 18px;
        --icon-size: 18px;
Mushroom Triple Spinner
Triple Spinner
icon: mdi:loading
icon_color: red
primary: Triple
card_mod:
  style:
      ha-icon {
        --icon-animation: spin 4s linear infinite;
        border-radius: 50%;
        border-bottom-color: rgb(var(--rgb-blue));
      .shape {
        border-bottom-color: rgb(var(--rgb-green));
        --icon-symbol-size: 42px;
        --icon-size: 34px;
Mushroom Card Active Animations
Mushroom Activate Background
Activate Background
primary: Activate Mushroom
icon: mdi:mushroom
icon_color: red
secondary: Background
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      background: rgba(var(--rgb-disabled), 0.1);
      transition: 0s;
Mushroom Activate Box-shadow
Activate Box-Shadow
icon: mdi:mushroom
icon_color: red
secondary: Box-Shadow
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      box-shadow: 0 0 20px rgba(var(--rgb-disabled), 0.8);
      transition: 0s;
Mushroom Activate Scale-Out
Activate Scale-Out
icon: mdi:mushroom
icon_color: red
secondary: Scale-Out
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: scale(1.02);
      transition: 0s;
Mushroom Activate Scale-In
Activate Scale-In
icon: mdi:mushroom
icon_color: red
secondary: Scale-In
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: scale(0.975);
      transition: 0s;
Mushroom Activate Push Down
Activate Push Down
icon: mdi:mushroom
icon_color: red
secondary: Push Down
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: translateY(1.5px);
      transition: 0s;
      box-shadow: 0 0.5px 2px 0 rgba(0, 0, 0, 0.16);
Mushroom Activate Push In
Activate Push In
icon: mdi:mushroom
icon_color: red
secondary: Push In
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active {
      transform: translateY(-1.5px);
      transition: 0s;
Mushroom Activate Ripple
Activate Ripple
icon: mdi:mushroom
icon_color: red
secondary: Ripple
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card {
      overflow: hidden;
    ha-card:after {
      display: none;
      content: "";
      position: absolute;
      border-radius: 50%;
      background-color: rgba(var(--rgb-disabled), 0.1);
      width: 100px;
      height: 100px;
      margin-top: -50px;
      margin-left: -50px;
      top: 50%;
      left: 50%;
      animation: ripple 750ms;
      opacity: 0;
    ha-card:active:after {
      display: block;
    @keyframes ripple {
      from { opacity: 1; transform: scale(0); }
      to { opacity: 0; transform: scale(10); }
Mushroom Activate 3D Perspective
icon: mdi:mushroom
icon_color: red
secondary: 3D Perspective
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 900px;
    ha-card:active {
      transform: rotateY(20deg);
      transition: 0s;
Mushroom Activate 3D Tilt
Activate 3D Tilt
icon: mdi:mushroom
icon_color: red
secondary: 3D Tilt
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 1000px;
    ha-card:active {
      transform: rotate3d(0.5, -0.9, 0, 10deg) rotate(1deg);
      transition: 0s;
Mushroom Activate 3D Flap
Activate 3D Flap
icon: mdi:mushroom
icon_color: red
secondary: 3D Flap
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    :host {
      perspective: 900px;
    ha-card:active {
      transform: rotateX(25deg);
      transform-origin: center bottom;
      transition: 0s;
Mushroom Activate Trash
Activate Icon Spin
icon: mdi:mushroom
icon_color: red
secondary: Icon Spin
tap_action:
  action: none
hold_action:
  action: none
card_mod:
  style: |
    ha-card:active mushroom-shape-icon {
        display: flex;
        #--icon-animation: spin 1s;
        transform: rotate(360deg);
        transition: 500ms;
Applying Active Animations to your Theme
Rather than applying the active animations to each card, you can apply the to all cards by adding the card_mod to your theme.
Mushroom Custom:
  card-mod-theme: "Mushroom Custom"
  card-mod-card: |
    ha-card:active {
      transition: 0s;
Reference documentation
Card mod Themes Β· thomasloven/lovelace-card-mod Wiki Β· GitHub
lovelace-card-mod/README-themes.md at master Β· thomasloven/lovelace-card-mod Β· GitHub
:point_right: Continued in Part 1, Part 3, Part 4 & Part 5
quick question, what does β€œ|-” before template mean?
it’s yaml for multi-line use https://yaml-multiline.info or https://www.w3schools.io/file/yaml-multiline-strings/
hi :wink: i Copied exact your code. It seems like coloring the bar is not working. May you can help me
cards:
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 42px auto 12px
      margin: '-4px -4px -8px -4px;'
    cards:
        entity: sensor.water_filter_days_remaining
        icon: mdi:air-filter
        icon_color: |
          {% set filter_days = states(entity) | int %}
          {% if filter_days < 31 %}
            red
          {% elif filter_days < 91 %}
            orange
            green
        card_mod:
          style: |
            ha-card {
              background: none;
              --ha-card-box-shadow: 0px;
      - type: custom:bar-card
        height: 42px
        min: '0'
        max: '200'
        entity_row: true
        severity:
          - color: rgb(var(--mush-rgb-green))
            to: 200
          - color: rgb(var(--mush-rgb-orange))
            to: 109
          - color: rgb(var(--mush-rgb-red))
            to: 30
        positions:
          icon: 'off'
          indicator: 'off'
        card_mod:
          style: |
            ha-card {
              padding: 12px;
              margin-left: 12px;
              --bar-card-border-radius: 12px;
            bar-card-value {
              margin: 12px;
              font-size: 12px;
              font-weight: bolder;
            bar-card-name {
              margin: 12px;
              font-size: 12px;
            bar-card-backgroundbar {
              opacity: 0.2;
              filter: brightness(1);
        entity: input_boolean.water_filter_dropdown
        icon: mdi:chevron-down
        icon_color: disabled
        hold_action:
          action: none
        card_mod:
          style:
            mushroom-shape-icon:
                .shape ha-icon {
                  transition: transform 0.14s !important;
                  {{ 'transform: rotate(-180deg);' if is_state(config.entity, 'on') }}
                ha-card {
                  align-items: flex-end;
                  box-shadow: none;
  - type: custom:stack-in-card
    mode: horizontal
    cards:
      - type: custom:mushroom-entity-card
        entity: input_datetime.water_filter_replaced
        icon: mdi:calendar
        layout: vertical
        primary_info: state
        secondary_info: name
        card_mod:
          style: |
            ha-card {
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        entity: sensor.water_filter_days_since_replacement
        layout: vertical
        primary_info: state
        card_mod:
          style: |
            ha-card {
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        entity: input_number.water_filter_threshold
        icon: mdi:calendar-edit
        layout: vertical
        primary_info: state
        card_mod:
          style: |
            ha-card {
              width: 130px;
              margin-left: auto;
              margin-right: auto;
        primary: Reset
        secondary: ''
        icon: mdi:refresh
        layout: vertical
        tap_action:
          action: call-service
          service: script.reset_water_filter_date_to_today
          data: {}
          target: {}
        hold_action:
          action: none
        double_tap_action:
          action: none
    card_mod:
      style: |
        ha-card {
          margin-top: -14px;
card_mod:
  style: |
    ha-card {
      {{ 'height: 66px;' if is_state('input_boolean.water_filter_dropdown', 'off') }}
Hello the cards I see here are great, but my design skills are beter in Adobe then do the technical stuff :). I was wondering if somebody can build this card. I have an airco which I can turn on/off with a outlet and also show the power. I like to have them bought in one card. Is this possible and how?
grafik
Im sure someone else can do it better :wink:
cards:
    chips:
      - type: entity
        entity: switch.solar
        icon: mdi:toggle-switch
        icon_color: light-green
        content_info: none
    alignment: end
    card_mod:
      style: |
        ha-card {
  - type: custom:mini-graph-card
    entities:
      - sensor.solar_energy
    label: null
    show:
      labels: true
      icon: false
    color_thresholds:
      - value: 0
        color: '#c5dde3'
      - value: 5
        color: '#12c2f3'
      - value: 8
        color: '#b3f312'
Add the mushroom variables to your theme file.
Hey, how have you removed the default dashboard bar at the top? By β€œdefault bar” I mean this one:
Your custom one looks really sleek, those are mushroom chips, am I right?
Use the kiosk mode or sidebar-card in HACS. Set the hideTopMenu on True
sidebar:
  digitalClock: true
  date: true
  dateFormat: dddd DD MMMM YYYY
  hideTopMenu: false
Thank you for the quick service :). This is a good start.
looking in how to get the on for CCTV working, I can get it working but only for both icons, but want to have it only for one, any idea how to fix that if possible?
type: custom:vertical-stack-in-card
mode: vertical
cards:
  - type: custom:vertical-stack-in-card
    horizontal: true
    cards:
        entity: switch.cctv
        layout: vertical
        icon: |-
          {% if is_state('switch.cctv', 'on') %}
            mdi:cctv
            mdi:cctv-off
        icon_color: |-
            yellow
            #6f6f6f
Just add your if/on to the --icon-animation like this:
mode: vertical
cards:
    horizontal: true
    cards:
        entity: switch.cctv
        layout: vertical
        icon: |-
          {% if is_state(entity, 'on') %}
            mdi:cctv
            mdi:cctv-off
        icon_color: |-
            yellow
            #6f6f6f
        card_mod:
          style:
              ha-icon {
                {% if is_state(config.entity, 'on') %}
                  --icon-animation: scan 5s ease-in-out infinite;
                transform-origin: 90% 80%
              @keyframes scan {
                0%, 100% { transform: rotate(20deg); }
                50% { transform: rotate(-15deg); }
Does anybody know how I could add battery levels for my blinds into upper right corner of the cover card? Completely lost here…
type: custom:mushroom-cover-card
entity: cover.living_room_blinds
name: Living Room Blinds
show_position_control: true
show_buttons_control: true
sorry for the late reply i was out of town. Im also using an iphone but i dont have those borders. Neither on an android device.
But i think u already found a solution :smiley:
great! this part I was missing: {% if is_state(config.entity, β€˜on’) %}
keep up the good work!
