Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Yes, this is how I use it for my Christmas Tree.
Mushroom Animated Christmas Tree Light:
type: custom:stack-in-card
cards:
  - type: custom:mushroom-light-card
    entity: light.christmas_tree
    icon: mdi:pine-tree
    use_light_color: true
    show_brightness_control: true
    show_color_temp_control: false
    show_color_control: true
    collapsible_controls: true
    card_mod:
      style: |
        ha-card {
          --ha-card-border-width: 0;
    icon: mdi:star-four-points
    icon_color: yellow
    primary: Star
    card_mod:
      style:
        mushroom-shape-icon$: |
          ha-icon {
            --icon-animation: star 8s ease infinite alternate;
          @keyframes star {
            0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
            50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -120px;
    icon: mdi:grain
    icon_color: red
    card_mod:
      style:
          ha-icon {
            --icon-animation: flash 2s steps(1) infinite, lights 2s infinite;
            clip-path: polygon(51% 15%, 24% 74%, 74% 74%);
          @keyframes flash {
            50% { transform: rotateY(180deg); }
          @keyframes lights {
            0%, 100% {--icon-color: rgb(var(--rgb-red)); }
            6.25% { --icon-color: rgb(var(--rgb-deep-orange)); }
            12.5% { --icon-color: rgb(var(--rgb-orange)); }
            18.75% { --icon-color: rgb(var(--rgb-amber)); }
            25% { --icon-color: rgb(var(--rgb-yellow)); }
            31.25% { --icon-color: rgb(var(--rgb-lime)); }
            37.5% { --icon-color: rgb(var(--rgb-light-green)); }
            43.75% { --icon-color: rgb(var(--rgb-green)); }
            50% { --icon-color: rgb(var(--rgb-teal)); }
            56.25% { --icon-color: rgb(var(--rgb-cyan)); }
            62.5% { --icon-color: rgb(var(--rgb-light-blue)); }
            68.75% { --icon-color: rgb(var(--rgb-blue)); }
            75% { --icon-color: rgb(var(--rgb-indigo)); }
            81.25% { --icon-color: rgb(var(--rgb-deep-purple)); }
            87.5% { --icon-color: rgb(var(--rgb-purple)); }
            93.75% { --icon-color: rgb(var(--rgb-pink)); }
          .shape {
          ha-card {
            width: 66px;
            top: -186px;
    icon: mdi:gift
    icon_color: red
    tap_action:
      action: toggle
    card_mod:
      style:
          ha-icon {
            --icon-animation: surprise 4s ease infinite;
          @keyframes surprise {
            0%, 20%, 100% { transform: translateY(0); }
            2.5% { transform: translateY(-2px) rotate(-27deg); }
            5% { transform: translateY(-2px) rotate(21deg); }
            7.5% { transform: translateY(-2px) rotate(-15deg); }
            10% { transform: translateY(-2px) rotate(9deg); }
            12.5% { transform: translateY(0); }
            15% { transform: translateY(-1.2px) }
          .shape {
            --icon-size: 18px;
            top: 18px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -252px;
card_mod:
  style: |
    ha-card {
      {{ 'height: 120px;' if is_state('light.christmas_tree', 'on') else 'height: 66px;' }}
      {% set r = state_attr('light.christmas_tree', 'rgb_color')[0] %}
      {% set g = state_attr('light.christmas_tree', 'rgb_color')[1] %}
      {% set b = state_attr('light.christmas_tree', 'rgb_color')[2] %}
      background-color: rgba( {{r}}, {{g}}, {{b}}, 0.1 );
Why don’t you just create an input_boolean helper for the on/off state?
thank you. i had a look in this code.
You are an absolute wizard
No one who can help me. Thank you very much
Lots of different ways, but a theme seems best, take a look at the thread and the post marked as the answer.
Hi Rhys,
I tried to replicate your beautiful Christmas tree, it works great but it show the chips border of the other images you offset on the tree:
Do you have any tip to hide those?
Thanks!
Nice job. Instead of currently playing entity wich doesn’t let me control music and speakers how can i make one card with multiple players?
Thanks! It works
Oops, forgot to check the default theme. Add --chip-border-width: 0; to the bottom like this:
      mushroom-template-chip:not(:first-child) {
        --chip-background: none;
        --chip-box-shadow: none;
Thanks that worked beautifully!
@rhysb love these but have a question;
Most of your designs & code you create a version that works with a ‘dark’ and ‘light’ theme modes. However that option only seems to work if you use the default HASS theme. If you have a custom theme like mine (Noctis, which has many dark colors) and I implement this card for example it reverts to the ‘light’ version of your card and I still have not found a way to trick the theme to HASS thinks it’s dark. So with the example above (Mushroom Media Player Ultrablur Background with Idle Art) I get the left but want to right (dark version).
I guess there is something in your code that checks light/dark. Could you tell me how to ‘trick it’ so it forces dark even tough the theme is not aware?
HI All
I am trying to have an icon change its animation based on the weather. So, for example, when its sunny, it uses the sunny animation, and when it’s raining, it used the raining animation.
I have got it working with the weather-sunny icon, but when I do the weather-rain, it produces a funny result
See below
weather-rain
type: custom:mushroom-template-card
primary: '{{states(''sensor.highett_short_text_0'' ) }}'
secondary: ''
icon: '{{states(''sensor.highett_mdi_icon_0'') }}'
icon_color: |-
  {% if is_state('sensor.highett_mdi_icon_0', 'mdi:weather-sunny') %}
    yellow
  {% elif is_state('sensor.highett_mdi_icon_0', 'mdi:weather-rainy') %}
    blue
card_mod:
  style: |
    mushroom-shape-icon {
      {% set weather = states('sensor.highett_mdi_icon_0') %}
      {% if weather == 'mdi:weather-sunny' %}
        --card-mod-icon: mdi:weather-sunny;
        animation: sunny 8s ease-in-out infinite alternate;
      {% elif weather == 'mdi:weather-rainy' %}
        --card-mod-icon: mdi:weather-rainy;
        animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;
      display: flex;
    @keyframes sunny {
      70% { transform: rotate(360deg) scale(1); }
      80% { transform: scale(1); }
      90% { transform: scale(1.15); }
      100% { transform: scale(1); }
    @keyframes cloudy {
      0%, 100% { transform: translateX(3px); }
      30% { transform: translateX(-1px); }
      45% { transform: translateX(1.5px); }
      75% { transform: translateX(-3.2px); }
    @keyframes rain {
      50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
    @keyframes moon {
      0%, 100% { transform: rotate(12deg); }
      30% { transform: rotate(-6deg); }
      45% { transform: rotate(8deg); }
      75% { transform: rotate(-10deg); }
    @keyframes stars {
      0%, 3.1%, 14.1% { clip-path: inset(0 0 0 0); }
      3% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 99% 62%, 68% 62%, 62% 44%, 76% 34%, 100% 34%, 99% 0%); }
      14% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 100% 25%, 51% 45%, 38% 34%, 36% 0); }
Amazing! thank you so much!
I have modified it a little bit to make a tree green .
ON
OFF
@rhysb Thanks a lot again
Here is card-yaml:
cards:
    entity: light.christmas_lights
    icon: mdi:pine-tree
    icon: mdi:pine-tree
    icon_color: green
    card_mod:
      style:
          .shape {
          ha-card {
            width: 66px;
            top: -120px;
    icon_color: yellow
    card_mod:
      style:
          ha-icon {
          @keyframes star {
          .shape {
          ha-card {
            width: 66px;
            top: -186px;
    icon: mdi:grain
    icon_color: red
    card_mod:
      style:
          ha-icon {
          @keyframes flash {
          @keyframes lights {
          .shape {
          ha-card {
            width: 66px;
            top: -252px;
    icon: mdi:gift
    icon_color: red
    tap_action:
      action: toggle
    card_mod:
      style:
          ha-icon {
          .shape {
            --icon-size: 18px;
            top: 18px;
            left: 18px;
          ha-card {
            width: 66px;
            top: -318px;
card_mod:
  style: |
    ha-card {
      {{ 'height: 120px;' if is_state('light.christmas_lights', 'on') else 'height: 66px;' }}
hello, can you show your code? thank you
That is because you are trying to animate mushroom-shape-icon which includes the Icon Shape (shaded circle around the icon). You will need to animate just the ha-icon. At the moment you are trying to change the Icon in two places, with a template in icon: and then with --card-mod-icon: in the CSS. Change the icon with icon: and icon_color: and then do just the animation with card_mod.
That is because Noctis only has a ‘light’ mode. You could try changing the following line.
From this:
background: url( '{{ state_attr("media_player.currently_playing", "entity_picture") }}' ), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 50%);
To this:
background: url( '{{ state_attr("media_player.currently_playing", "entity_picture") }}' ), linear-gradient(to left, transparent, var(--ha-card-background) 50%);
I really like the chips, if that’s the right word for it, on the future concept. Has anyone done anything similar?
Do you mean like this? :thinking:
New Chips
type: custom:mushroom-chips-card
chips:
  - type: template
    entity: climate.office_air_conditioner
    icon: mdi:thermometer
    icon_color: red
    content: |-
      Climate
      {{ state_attr(entity, 'temperature') | round(1) }} °C
    card_mod:
      style: |
        ha-card {
          padding: 5px;
        .content {
          white-space: pre-wrap;
  - type: template
    icon: mdi:lightbulb
    content: |-
      Lights
      {{ expand(states.group.all_lights) | selectattr( 'state', 'eq', 'on') |
      list | count }} On
    entity: group.all_lights
    icon_color: yellow
    tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          padding: 5px;
          {{ '--chip-background: rgba(var(--rgb-yellow), 0.2);' if is_state(config.entity, 'on') }}
        .content {
  - type: template
    icon: '{{ ''mdi:lock'' if is_state(entity, ''locked'') else ''mdi:lock-open'' }}'
    content: |-
      Security
      {{ expand(states.group.all_locks) | selectattr( 'state', 'eq', 'unlocked') | list | count }} Unlocked
    entity: group.all_locks
    icon_color: '{{ ''green'' if is_state(entity, ''locked'') else ''red'' }}'
    tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          padding: 5px;
        .content {
