Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
you can get inspired if you want :slight_smile:
aaa
I am using chips to show location of family members. At the moment I can only see the person icon and either the name or the state (home, away etc).
Is there any way to show the name of person and also the state so I can see who each chip relates to.
Will you share the code?
as soon as I finish creating the home screen, of course :slight_smile:
I ‘kinda’ solved my issue with some card shenanigans:
type: custom:stack-in-card
mode: horizontal
cards:
  - type: custom:mushroom-entity-card
    entity: cover.rol_badkamer
    icon: mdi:window-shutter
    tap_action:
      action: more-info
    hold_action:
      action: more-info
    double_tap_action:
      action: more-info
    fill_container: true
    style: |
      ha-card {
      border: none;
  - type: horizontal-stack
    cards:
        primary: ''
        secondary: ''
        icon: mdi:weather-sunset-up
        fill_container: false
        layout: vertical
        entity: input_boolean.zonsopgang_badkamer_rolluik
        icon_color: |-
          {% if is_state('input_boolean.zonsopgang_badkamer_rolluik','on') %}
          amber
        style: |
          ha-card {
          border: none;
        primary: ''
        secondary: ''
        icon: mdi:arrow-up
        layout: vertical
        icon_color: |-
          {% if is_state('cover.rol_badkamer','open') %}
          grey
          blue
        tap_action: null
        action: call-service
        service: cover.open_cover
          entity_id: cover.rol_badkamer
        data: {}
        hold_action:
          action: none
        double_tap_action:
          action: none
        style: |
          ha-card {
            border: none;
        primary: ''
        secondary: ''
        icon: mdi:arrow-down
        layout: vertical
        icon_color: |-
          {% if is_state('cover.rol_badkamer','closed') %}
          grey
          blue
        tap_action: null
        service: cover.close_cover
        data: {}
        hold_action:
          action: none
        double_tap_action:
          action: none
        style: |
          ha-card {
            border: none;
Its a combination of themes.
I used Soft UI theme
https://community.home-assistant.io/t/lovelace-soft-ui-simple-and-clean-lovelace-configuration/159357
Then combined it with a bit of coding to “neumorphism” theme
https://github.com/VonWelter/neumorphism?fbclid=IwAR2mnVHFYWQ-Yv-GJHa-VKGGq4wGa_aqfHApDbW4upe36nb7fPfTm3CO1kQ
Hope that helps
Hi Mattia
Can u share the code for the card
You cuccina and salloto ilike
Some Entity below thanks
Hey, there
Does anyone know how to add word-warp to this CSS?
 card_mod:
      style:
        mushroom-shape-icon$: |
          .shape:after {
            content: "{{ state_attr(config.entity, 'current_temperature') | round(0) }}°";
            position: absolute;
            font-size: var(--card-primary-font-size);
            font-weight: bolder;
            {% set status = state_attr('climate.3family_room','hvac_action')
            {% if status == 'off' %}
            color: grey
            {% elif status == 'cooling' %}
            color: blue
            {% elif status == 'heating' %}
            color: red
            color: grey
          .shape {
            box-shadow: var(--ha-card-box-shadow) !important;
          ha-card {
            --ha-card-background: none;
            box-shadow: none;
            --ha-card-border-width: 0;
          mushroom-shape-icon {
            --shape-color: white !important;
Hi, have you ever sorted this out?
I’m facing the same problem as you.
Thank you in advance!
Getting really close to this, I’ll show you the result once it’s finished ^^
@edit
Captura de ecrĂŁ 2023-04-29 181619sadsa
Buttons
cards:
    primary: ''
    secondary: ''
    icon: |-
      {% if states('input_boolean.room_kitchen') == 'on' %}
      mdi:robot-excited-outline
      mdi:robot-dead
    multiline_secondary: true
    entity: input_boolean.room_kitchen
    tap_action:
      action: toggle
    layout: horizontal
    hold_action:
      action: more-info
    icon_color: |-
      blue-grey
      disabled
    double_tap_action:
      action: navigate
      navigation_path: /lovelace/jarvis
    picture: ''
    card_mod:
      style:
          ha-icon {
            {% if is_state('input_boolean.room_kitchen', 'on') %}
            --icon-animation: tilt 4s steps(1) infinite, blink 4s infinite;
            transform-origin: 50% 92%;
          @keyframes tilt {
            0%, 100% { transform: rotate(0deg); }
            33% { transform: rotate(8deg); }
            66% { transform: rotate(-8deg); }
          @keyframes blink {
            0%, 20%, 30%, 45%, 55%, 70%, 80%, 100% { clip-path: inset(0 0 0 0); }
            25% { clip-path: polygon(0 0, 100% 0, 100% 53%, 25% 52%, 24% 77%, 75% 77%, 76% 52%, 100% 52%, 100% 100%, 0 100%); }
            50%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 51% 54%, 51% 76%, 76% 77%, 75% 53%, 100% 52%, 100% 100%, 0 100%); }
            75%  { clip-path: polygon(0 0, 100% 0, 100% 53%, 24% 53%, 24% 77%, 47% 77%, 47% 52%, 100% 52%, 100% 100%, 0 100%); }
          ha-card {
            box-shadow: none;
            background: rgba(0,0,0,0);
            text-align: center;
    primary: ''
    secondary: ''
    icon: >-
      {% if states('light.luzes_kitchen') == 'on' %}
      mdi:lightbulb-on-outline
      {% elif states('binary_sensor.luz_kitchen') == 'on' and
      states('light.luzes_kitchen') == 'off' %}
      mdi:weather-sunny
      mdi:brightness-5
    multiline_secondary: false
    entity: binary_sensor.luz_kitchen
    layout: horizontal
    tap_action:
      action: more-info
    hold_action:
      action: navigate
      navigation_path: /lovelace/lights
    double_tap_action:
      action: none
    icon_color: >-
      orange
      amber
      disabled
    card_mod:
      style:
          ha-icon {
            --icon-animation: illumination 2s infinite;
            {% elif states('binary_sensor.luz_kitchen') == 'on' and states('light.luzes_kitchen') == 'off' %}
            --icon-animation: sunny 8s ease-in-out infinite alternate;
          @keyframes sunny {
            70% { transform: rotate(360deg) scale(1); }
            80% { transform: scale(1); }
            90% { transform: scale(1.15); }
            100% { transform: scale(1); }
          @keyframes illumination {
            80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
          ha-card {
            box-shadow: none;
            text-align: center;
    primary: ''
    secondary: ''
    icon: >-
      {% if states('binary_sensor.occupancy_kitchen') == 'on' and
      states('input_boolean.people_presence') == 'on' %}
      mdi:motion-sensor
      {% elif states('binary_sensor.occupancy_kitchen') == 'on' and
      states('input_boolean.people_presence') == 'off' %}
      mdi:cat
      mdi:transition
    entity: binary_sensor.occupancy_kitchen
    layout: horizontal
    tap_action:
      action: more-info
    hold_action:
      action: navigate
      navigation_path: /lovelace/secure
    double_tap_action:
      action: none
    icon_color: >-
      blue-grey
      brown
      disabled
    picture: ''
    card_mod:
      style:
          ha-icon {
            {% if states('binary_sensor.occupancy_kitchen') == 'on' and states('input_boolean.people_presence') == 'on' %}
            --icon-animation: clip 2s linear infinite;
            {% elif states('binary_sensor.occupancy_kitchen') == 'on' and states('input_boolean.people_presence') == 'off' %}
            --icon-animation: huh 4s ease infinite;
            transform-origin: 50% 60%;
          @keyframes clip {
            50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
          .shape {
            --shape-animation: motion 2s linear infinite;
          @keyframes huh {
            0%, 10%, 75%, 100% { transform: rotate(0deg); }
            15% { transform: rotate(-25deg); }
            30%, 35% { transform: rotate(-40deg); }
            50% { transform: rotate(12deg); }
            65% { transform: rotate(-8deg); }
          ha-card {
            box-shadow: none;
            text-align: center;
    primary: ''
    secondary: ''
    icon: >-
      {% if states('binary_sensor.window_kitchen') == 'on' %} mdi:door {% elif
      states('cover.estore_cozinha') == 'opening' or
      states('cover.estore_cozinha') == 'closing' %} mdi:garage-variant {% elif
      states('cover.estore_cozinha') == 'open' and
      states('binary_sensor.window_kitchen') == 'off' and
      states('input_boolean.cycle_day') == 'on' %} mdi:window-closed-variant {%
      elif states('cover.estore_cozinha') == 'open' and
      states('input_boolean.cycle_night') == 'on' %} mdi:garage-open-variant {%
      elif states('cover.estore_cozinha') == 'closed' and
      states('input_boolean.cycle_day') == 'on' %} mdi:garage-variant {% elif
      states('input_boolean.cycle_night') == 'on' %} mdi:window-closed-variant
      {% elif states('binary_sensor.window_kitchen') == 'off' %}
      mdi:window-closed-variant {% endif %}
    entity: binary_sensor.window_kitchen
    layout: horizontal
    tap_action:
      action: more-info
    hold_action:
      action: navigate
    double_tap_action:
      action: none
    icon_color: >-
      {% if states('binary_sensor.window_kitchen') == 'on' %} green {% elif
      states('cover.estore_cozinha') == 'closing' %} brown {% elif
      states('input_boolean.cycle_day') == 'on' %} blue-grey {% elif
      states('input_boolean.cycle_night') == 'on' %} blue-grey {% elif
      states('input_boolean.cycle_day') == 'on' %} disabled {% elif
      states('input_boolean.cycle_night') == 'on' %} disabled {% elif
      states('binary_sensor.window_kitchen') == 'off' %} disabled {% endif %}
    card_mod:
      style:
          ha-icon {
            --icon-animation: open 6s ease-in-out infinite;
            transform-origin: 30%;
            {% elif states('cover.estore_cozinha') == 'opening' or states('cover.estore_cozinha') == 'closing' %}
            --icon-animation: door 3s steps(1) infinite alternate;
          @keyframes open {
            0%, 66% { transform: rotateY(0deg); }
            33% { transform: rotateY(-120deg); }
          .shape {
            perspective: 45px;
          @keyframes door {
            25%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 74%, 81% 74%, 81% 100%, 100% 100%, 100% 0); }
            50%  { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 60%, 81% 60%, 81% 100%, 100% 100%, 100% 0); }
            75% { clip-path: polygon(0 0, 0 100%, 19% 100%, 19% 48%, 81% 48%, 81% 100%, 100% 100%, 100% 0); }
          ha-card {
            box-shadow: none;
            text-align: center;
Kitchen (aka Cozinha)
cards:
    primary: Cozinha
    secondary: |
      {{ states('sensor.temp_kitchen') | round(0) }}°C | {{
      states('sensor.humd_kitchen') | round(0) }}%
    icon: >
      {% if is_state('light.lightstrip_kitchen_light', 'on') %}
      mdi:fridge-bottom
      {% elif is_state('light.candeeiro_cozinha', 'on') %}
      mdi:fridge
      {% elif is_state('light.varanda_churrasqueira', 'on') %}
      mdi:balcony
      {% elif is_state('media_player.speaker_kt', 'playing') or
      is_state('media_player.speaker_kt', 'playing') %}
      mdi:volume-high
      mdi:fridge-outline
    icon_color: >
      {{ '#%02x%02x%02x' % state_attr('light.lightstrip_kitchen_light',
      'rgb_color') }}
      {% elif is_state('light.candeeiro_cozinha', 'on') or
      amber
      purple
      disabled
    layout: horizontal
    tap_action:
      action: navigate
      navigation_path: cozinha
    hold_action:
      service: light.turn_off
        transition: 3
        area_id: kitchen
    double_tap_action:
      action: toggle
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.1);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
    chips:
      - type: conditional
        conditions:
          - entity: input_boolean.vacuum_kitchen
            state: 'on'
        chip:
          type: template
          icon: |
            {% if states('input_boolean.vacuum_kitchen') == 'on' %}
            mdi:robot-vacuum {% elif states('input_boolean.vacuum_kitchen') ==
            'on' and states('vacuum.robot_cleaner') == 'returning' %}
            mdi:robot-vacuum {% endif %}
          icon_color: |
            {% if states('input_boolean.vacuum_kitchen') == 'on' and
            states('vacuum.robot_cleaner') == 'cleaning' %}
            pink
            {% elif states('input_boolean.vacuum_kitchen') == 'on' and
            light-green
            disabled
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 1
      - type: conditional
        conditions:
          - entity: binary_sensor.luz_kitchen
            state: 'on'
        chip:
          type: template
          icon: |
            mdi:lightbulb-on-outline {% elif states('binary_sensor.luz_kitchen')
            mdi:weather-sunny {% else %} mdi:brightness-5 {% endif %}
          icon_color: |
            {% if states('light.luzes_kitchen') == 'on' %} orange {% elif
            states('light.luzes_kitchen') == 'off' %} amber {% else %} disabled
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 2
      - type: conditional
        conditions:
          - entity: binary_sensor.occupancy_kitchen
            state: 'on'
        chip:
          type: template
          icon: |
            mdi:motion-sensor
            mdi:cat
            mdi:transition
          icon_color: |
            blue-grey
            brown
            disabled
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 3
      - type: conditional
        conditions:
          - entity: input_boolean.jarvis_ai
            state: 'on'
        chip:
          type: template
          icon: |
            mdi:door
            mdi:garage-variant
            {% elif states('cover.estore_cozinha') == 'open' and
            {% elif states('cover.estore_cozinha') == 'closed' and
            mdi:garage-variant
          icon_color: |
            elif
            == 'closing' %} brown {% elif states('cover.estore_cozinha') ==
            'open' and
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 4
      - type: conditional
        conditions:
          - entity: input_boolean.timer_kitchen
            state: 'on'
        chip:
          type: template
          icon: |
            {% if states('timer.kitchen_ceiling') == 'active' and
            states('timer.kitchen_daytime') == 'active' %}
            mdi:clock-time-seven
            {% elif states('timer.kitchen_ceiling') == 'active' and
            states('timer.kitchen_extra') == 'active' %}
            mdi:clock-time-ten
            states('timer.kitchen_noble') == 'active' %}
            mdi:clock-time-five
            states('timer.kitchen_late') == 'active' %}
            mdi:clock-time-one
            states('timer.kitchen_tv') == 'active' %}
            mdi:clock-time-six
            {% elif states('timer.kitchen_ceiling') == 'active' %}
            mdi:clock-time-twelve
            {% elif states('timer.kitchen_ceiling') == 'idle' and
            mdi:clock-time-seven-outline
            mdi:clock-time-ten-outline
            mdi:clock-time-five-outline
            mdi:clock-time-one-outline
            mdi:clock-time-six-outline
            mdi:clock-time-twelve-outline
          icon_color: |
            {% if states('timer.kitchen_daytime') == 'active' %}
            orange
            {% elif states('timer.kitchen_extra') == 'active' %}
            teal
            {% elif states('timer.kitchen_noble') == 'active' %}
            purple
            {% elif states('timer.kitchen_late') == 'active' %}
            deep-purple
            {% elif states('timer.kitchen_tv') == 'active' %}
            pink
            blue-grey
            disabled
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 5
      - type: conditional
        conditions:
          - entity: input_boolean.trash_kt
            state: 'on'
        chip:
          type: template
          icon: mdi:delete-empty
          icon_color: red
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 6
      - type: conditional
        conditions:
          - entity: input_boolean.room_kitchen
            state: 'off'
        chip:
          type: template
          icon: mdi:chip
          icon_color: red
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 7
      - type: conditional
        conditions:
          - entity: media_player.speaker_kt
            state_not: unavailable
            state_not: 'off'
        chip:
          type: template
          icon: |
            {% if states('media_player.speaker_kt') == 'playing' %}
            mdi:speaker-wireless
            mdi:speaker
          icon_color: |
            purple
            blue-grey
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 8
      - type: conditional
        conditions:
          - entity: media_player.tv_kt
            state_not: 'off'
        chip:
          type: template
          icon: |
            {% if states('media_player.tv_kt') == 'playing' %}
            mdi:speaker
          icon_color: |
            purple
            blue-grey
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 9
      - type: conditional
        conditions:
          - entity: alarm_control_panel.kitchen
            state: triggered
        chip:
          type: template
          icon: mdi:shield-alert-outline
          icon_color: red
          tap_action:
            action: none
          hold_action:
            action: none
          content_info: 10
    alignment: end
    card_mod:
      style:
        mushroom-conditional-chip:nth-child(1):
          mushroom-template-chip$: |
            ha-icon {
              animation: shake 4000ms ease-in-out infinite;
              transform-origin: 50% 68%;
              clip-path: polygon(0 0, 0 100%, 55% 100%, 34% 75%, 75% 41%, 85% %, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
            @keyframes shake {
              0%, 100% { transform: rotate(-5deg) rotate(15deg); }
              50%  { transform: rotate(-10deg); }
              25%  { transform: rotate(-14deg) rotate(9deg); }
              75%  { transform: rotate(21deg) rotate(-16deg); }
        mushroom-conditional-chip:nth-child(2):
            ha-icon {
            @keyframes sunny {
        mushroom-conditional-chip:nth-child(3):
            ha-icon {
            @keyframes clip {
            .shape {
            @keyframes huh {
        mushroom-conditional-chip:nth-child(4):
            ha-icon {
            @keyframes open {
            .shape {
              perspective: 45px;
            @keyframes door {
        mushroom-conditional-chip:nth-child(5):
            ha-icon {
              animation: clock 5s ease-in-out infinite;
            @keyframes clock {
              100% { transform: rotate(360deg) scale(1); }
        mushroom-conditional-chip:nth-child(6):
            ha-icon {
              animation: ping 1.25s ease-out infinite ;
            @keyframes ping {
              0% {
                box-shadow: 0 0 5px 1px rgba(var(--rgb-red), 1);
                border-radius: 10px
              100% {
                box-shadow: 0 0 5px 10px rgba(var(--rgb-red), 0);
        mushroom-conditional-chip:nth-child(7):
            ha-icon {
              animation: ping 1.25s ease-out infinite;
            @keyframes ping {
              0% {
                border-radius: 10px
              100% {
        mushroom-conditional-chip:nth-child(8):
            ha-icon {
              animation: beat 1.3s ease-out infinite both;
              transform-origin: 50% 80%;
            @keyframes beat {
              0% { transform: scale(0.95); }
              10% { transform: scale(1.0); }
              17% { transform: scale(1.10); }
              33% { transform: scale(1.05); }
              60% { transform: scale(0.95); }
        mushroom-conditional-chip:nth-child(9):
            ha-icon {
            @keyframes beat {
        mushroom-conditional-chip:nth-child(10):
            ha-icon {
            @keyframes ping {
              0% {
                border-radius: 10px
              100% {
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 0;
            margin-right: 6px;
card_mod:
  style: |
    ha-card {
      height: 100px;
         background: rgba({{ (state_attr('light.lightstrip_kitchen_light', 'rgb_color') | join(',')) }},0.1)
      {% elif is_state('light.candeeiro_cozinha', 'on')  or is_state('light.varanda_churrasqueira', 'on') %}
         background: rgba(245, 192, 47, 0.1);
      {% elif is_state('media_player.speaker_kt', 'playing') or is_state('media_player.speaker_kt', 'playing') %}
         background: rgba(170, 0, 255, 0.1);
      {% elif is_state('input_boolean.room_kitchen', 'off') or is_state('input_boolean.trash_kt', 'on') or is_state('alarm_control_panel.kitchen', 'triggered') %}
         background: rgba(229, 20, 0, 0.25);
Hey everybody,
How i add one picture in a mushroom-template-card?
I have like that
picture: /local/fotos/teste.jpg
but doesn’t work
someone can help?
A new question has arisen. To navigate between individual views, I use a small bar with chip cards.
The currently active page, I control with a different icon color. However, I would prefer to be able to “underline” the current page.
Does anyone of you have an idea if and how this would be possible?
mode: horizontal
cards:
    chips:
      - type: template
        icon: mdi:home
        tap_action:
          action: navigate
          navigation_path: home
      - type: template
        icon: mdi:cog
        tap_action:
          action: navigate
          navigation_path: system
      - type: template
        icon: mdi:lan
        tap_action:
          action: navigate
          navigation_path: network
      - type: template
        icon: mdi:docker
        icon_color: disabled
        tap_action:
          action: navigate
          navigation_path: docker
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          --chip-font-size: 0.3em;
          --chip-height: 42px
style: |
  ha-card {
    border-radius: 10px;
I’m using the mushroom-cover card and would like to change the CSS of the buttons. For example shape, radius and/or size, box shadow etc but don’t seem to be having any luck.
I believe it is the .button class and i’m using card_mod but even then, when i add the code it doesn’t change anything. If i change this in the chrome inspector it updates on the screen, just doesn’t allow me to do it through Home Assistant using the card_mod. Anyone else have any luck or is this purely not possible?
You can cater for the temp and color buttons like this.
Mushroom Light Slider
type: custom:mushroom-light-card
entity: light.rhys_bedside_light
show_brightness_control: true
tap_action:
  action: toggle
use_light_color: true
icon: mdi:led-strip-variant
show_color_temp_control: true
show_color_control: true
card_mod:
  style:
      .shape:active {
        transform: scale(1.2);
      mushroom-light-brightness-control, mushroom-light-color-temp-control,
      mushroom-light-color-control {
        position: absolute;
        top: 0px;
        left: 0px;
        width: 100%;
        opacity: 0.3;
        --control-height: 66px;
        --control-border-radius: var(--ha-card-border-radius, 12px);
        --rgb-disabled: var(--rgb-card-background-color);
      mushroom-state-item {
        z-index: 1;
        max-width: fit-content;
        margin-bottom: 0px;
        pointer-events: none;
        pointer-events: auto;
      mushroom-button {
        position: absolute;
        width: calc(var(--control-height) * var(--control-button-ratio)) !important;
        height: var(--control-height) !important;
        top: var(--spacing);
        right: var(--spacing);
      mushroom-button:nth-child(3) {
        right:  calc(2 *var(--spacing) + var(--control-height) * var(--control-button-ratio));
      .actions :not(:last-child) {
        margin-right: 0px !important;
Great work as usual.
For your media payer card, is there a way to bypass muted color from node red please
I launch radio flux so they have non album art. How tu have thĂŠ radio logo as image
ThĂŠ radio code IS like
type: entities
title: Radios
entities:
  • type: custom:mini-media-player
    icon: mdi:speaker
    entity: media_player.media_group
    group: true
    source: icon
    volume_stateless: false
    shortcuts:
    align_text: left
    columns: 2
    buttons:
    - type: music
    image: /local/images/Virgin Radio.jpg
    cover: /local/images/led-multi.jpeg
    - type: music
    name: RFM Night Fever
    image: /local/images/RFM.jpg
    - type: music
    image: /local/images/Radio Meuh.jpeg
    - type: music
    name: Jazz Radio Funk
    image: /local/images/Jazz Radio.jpg
    - type: music
    image: /local/images/Fusion.jpeg
    - type: music
    image: /local/images/Oui FM.jpeg
    - type: music
    image: /local/images/FG.png
    - type: music
    image: /local/images/RTS.jpg
    artwork: cover
    entity: media_player.jbl_leo
    icon: mdi:speaker
    group: true
    hide:
    controls: true
    info: true
    entity: media_player.jbl_link_portable_a4c0
    icon: mdi:speaker
    group: true
    hide:
    controls: true
    info: true
    style: |
    ha-card {
    position: relative;
    background: url(’/local/images/led-multi.jpeg’) center / cover;
    –mini-media-player-icon-color: var(–primary-text-color)
Hey community, this is a great project and a long thread. I have searched but haven’t found a clear answer. Here goes my question.
I want to use a card (entity or template) to show WAN status (connected) in the primary info slot and IP in secondary. The IP is an attribute of the entity WAN - a binary_sensor.
If I use an entity card, I can show ‘connected’ as primary but can’t find a way to get the attribute in the secondary. If I use a template card, I can get the state to show as ‘on’ in primary info and ip in the secondary - so using a template card seems to work best for this use case.
Can someone explain why the state is ‘on’ it is displayed as ‘connected’ when using the entity card? Is there a way to expose the ‘connected’ state/value using a template?
how can i check 2 sensor value in one “if” condition? this ist not working :frowning:
              {% if is_state('sensor.smart_state_of_charge', '100') && is_state('binary_sensor.openwb_cp1_autoladestatus', 'off')%}
                not charging
First of all, I’d like to state that I admire your work! U consist an inspiration to me, though I’m totally new to home assistant and your dashboard and views are something totally unreachable to me…!
However, I try to learn from your examples! :grinning:
Having said that, could you please share (an example of) the yaml of your dashboard ? I’ve read your posts about individual cards, but I’d like to copy- imitate your (ideal!) structure…!
I hope I don’t ask for much!
Thank you so much in advance!
Hi @rhysb. Is it possible to do wider Chips card so will auto match screen size. Just now I have used padding to make it a little more wider.
chips:
  - type: template
    tap_action:
      action: none;
    hold_action:
      service: notify.mobile_app_sylwester_s_s21
        message: Ringing
        title: Find Phone
          ttl: 0
          importance: high
          priority: high
          tag: Find
          channel: alarm_stream
          timeout: 60
    icon: mdi:target
    icon_color: red
    content: Find Phone
alignment: center
card_mod:
  style: |
    ha-card {
      --chip-background: rgba(var(--rgb-red), 0.2);
      --chip-border-radius: var(--mush-control-border-radius, 12px);
      --chip-height: var(--mush-control-height, 36px);
      user-select: none;
      --chip-padding: 80px;
    ha-card:active {
      --chip-background: rgba(var(--rgb-red), 0.4);
I’m considering 3 columns for my mushroom dashboard by removing the icon to create more screen real estate - see tile Lounge below. However at the moment the icon turns orange when the light in the room is on. Could I instead turn the whole tile orange if the light in the room is on? Or if that’s not possible could I ad least add a batch and change batch color accordingly?
This is my code with the icon
cards:
    primary: Lounge
    secondary: >-
      🌡️{{ states('sensor.atc_f3d3_temperature') | round(1) }}°C 🔋{{
      states('sensor.atc_f3d3_battery') | round(0) }}%
    icon: ''
    entity: light.controller_rgbw_22854b
    tap_action:
      action: navigate
      navigation_path: lounge
    hold_action:
      action: toggle
    icon_color: |-
      {% if is_state('switch.kogan01', 'on') %}
        orange
    picture: ''
    badge_icon: mdi:home
    primary: Kitchen
    secondary: >-
      🌡️{{ states('sensor.atc_b49c_temperature') | round(1) }}°C 🔋{{
      states('sensor.atc_b49c_battery') | round(0) }}%
    icon: mdi:home
    tap_action:
      action: navigate
      navigation_path: kitchen
    hold_action:
      action: toggle
    icon_color: |-
      {% if is_state('light.controller_rgbw_22854b', 'on') %}
        orange
    badge_icon: ''
    primary: Hello, {{user}}
    secondary: How are you?
    icon: mdi:home
