Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Thanks Dimitriā€¦ its worked
How we know to use this configurations?
Sorry dont understand your question?
How you know do you have put muhsroom-sliders$: ?
After you have put --bg-color: and main-color:
How i can know that? Developer Tools?
Thanks, this works.
Hello, can anyone please help me to find and address the problem in my mushroom chip card?
the problem is: everytime I go back to my main pages, my mush chip card (in the room card) is something like ā€œbreathing/dancingā€ (GIF attached).
ezgif-5-be7f780b1a
This is my code looks like:
      type: custom:mushroom-chips-card
      alignment: start
      card_mod:
        style: |
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 3px;
      chips:
        - type: template
          entity: light.lampu_toilet
          tap_action:
            action: toggle
          icon: |-
            {% if is_state("light.lampu_toilet", 'on') %}
              mdi:lightbulb-on
              mdi:lightbulb
          card_mod:
            style: |
              {% if is_state('light.lampu_toilet', 'on') %}
              .content {
                animation: boing 2s ease infinite;
                transform-origin: 50% 90%;
              @keyframes boing {
                0% { transform: scale3d(1, 1, 1); }
                7% { transform: scale3d(1.25, 0.75, 1); }
                10% { transform: scale3d(0.75, 1.25, 1); }
                12% { transform: scale3d(1.15, 0.85, 1); }
                16% { transform: scale3d(0.95, 1.05, 1); }
                19% { transform: scale3d(1.05, 0.95, 1); }
                25% { transform: scale3d(1, 1, 1); }
              ha-card {
                justify-content: center;
                width: var(--chip-height) !important;
                --chip-icon-size: 20px;
                --chip-height: 10px;
                padding: 8px!important;
                border-radius: 100%!important;
                --chip-background: {{ 'rgba(243, 182, 100, 0.5)' if is_state('light.lampu_toilet', 'on') else 'rgba(169, 169, 169, 0.5)' }}
        - type: conditional
          conditions:
            - entity: binary_sensor.motion_sensor_toilet_occupancy
              state: 'on'
          chip:
            type: template
            icon_color: disabled
            icon: mdi:motion-sensor
          card_mod:
            style: |
              ha-icon {
                --icon-animation: clip 2s linear infinite;
              @keyframes clip {
                50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
              .shape {
                --shape-animation: motion 2s linear infinite;
              @keyframes motion {
                0%, 100% { --shape-color: rgba(var(--rgb-blue), 0.3); }
                50% { --shape-color: rgba(var(--rgb-blue), 0.2); }
              ha-card {
                --chip-icon-size: 17px;
                --chip-background: rgba(199, 0, 57, 0.5)
        - type: conditional
          conditions:
            - entity: binary_sensor.pintu_toilet_contact
              state: 'on'
          chip:
            type: template
            icon: mdi:door
          card_mod:
            style: |
              ha-icon {
                --icon-animation: open 6s ease-in-out infinite;
                transform-origin: 30%;
              @keyframes open {
                0%, 66% { transform: rotateY(0deg); }
                33% { transform: rotateY(-120deg); }
              .shape {
                perspective: 45px;
Common when using card mod.
You will likely need to learn to live with it.
The reason for it is that all assets are loaded. So custom cards and such (this includes card mod itself) but only then after this card mod code is applied. So this will always happen after.
How slow or quick this happens depends on a few things (in order of highest impact that i have observed).
  1. The speed of your connection to your local HA instance. You will very likely notice this taking longer if you are on a slow cellular connection for example.
  2. The processing speed your device (the viewing device, not your homeassistant device). Will take longer to load on lets say a 10 year old smartphone vs your desktop computer. This is because most CSS (what card mod modifies) is processed on the viewing device, not the server it is hosted on.
  3. The amount of card mod being used. Will start to get slower the more card mod is applied to cards.
thank you so much, it really gives me another perspective about that. cheers!
Now that the TTS field is showing up in the cards again, itā€™s not looking as nice as it once did. Hereā€™s a before and after:
Before
After
ā€¦does anyone have an edit to make this look better? How are you handling this?
Hello Team, I am new to HA and I am struggling to implement the following:
  • The Washing Machine will show the current state for example if it is Off or running.
  • I have got the washing machine to spin when the washing machine is running.
  • How can I can get the current state to show underneath the washing machine icon?
Here is my working code:
type: custom:stack-in-card
cards:
    entity: input_select.washing_machine_status_2
    icon: mdi:washing-machine
    entity_status: ''
    friendly_name: input_select.washing_machine_status_2
    value_template: |-
      {% if is_state('input_select.washing_machine_status_2', 'running') -%}
       running
      {% elif is_state('input_select.washing_machine_status_2', 'idle') %}
       idle
      {%- else -%}
       off
      {%- endif %}
    icon_color: |-
      {% if is_state('input_select.washing_machine_status_2','Running') -%}
       amber
      {%- else -%}
        red
      {%- endif %}
    layout: vertical
    primary: Washing Machine
    tap_action:
      action: Dropdown
    card_mod:
      style: |
        ha-state-icon {
          clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
        ha-card {
          border: none;
    icon_color: |-
        orange
      {%- else -%}
        grey
      {%- endif %}
    layout: vertical
    tap_action:
      action: Dropdown
    card_mod:
      style: |
        ha-state-icon {
          {{ 'animation: spin 1s linear infinite;' if is_state('input_select.washing_machine_status_2','Running') }}
          transform-origin: 50% 58%;
          clip-path: circle(21.7% at 50% 58%);
        ha-card {
          top: -99px;
          border: none;
card_mod:
  style: |
    ha-card {
      height: 100px;
Any help will be very much appreciated. Also, how can I make the Icons a bit bigger?
@LiQuid_cOOled please i still need help on how to make the chip have no background --chip-background: none; and at the same time for the fan animation to work.
Thank you very much for your time
chips:
  - type: template
    tap_action:
      action: more-info
    entity: fan.chlazeni_goodwe_ventilator
    icon: mdi:fan
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-state-icon {
        {{ 'animation: rotate 2s linear infinite;' if is_state('fan.chlazeni_goodwe_ventilator', 'on') }}
       @keyframes rotate {
          100% { transform: rotate(360deg); }
2 ways:
Option 1. Applies to all chips in the chip card.
chips:
  - type: template
    tap_action:
      action: more-info
    icon: mdi:fan
card_mod:
  style:
      ha-state-icon {
      @keyframes rotate {
      ha-card {
Option 2. You can no longer use the visual editor, but background is only removed from specific chip targeted.
chips:
  - type: template
    tap_action:
      action: more-info
    icon: mdi:fan
    card_mod:
      style: |
        ha-card {
card_mod:
  style:
      ha-state-icon {
      @keyframes rotate {
Would love to help you, but please post your code in code blocks. Indentation is important and with the way you have posted this is lost.
Check out this post, section 11.
  1. Seems like 2 different devices took those screenshots, whilst i am not under the illusion that this would make up the entire difference it will make a difference to how each looks of course.
  2. Cant help you achieve how you want it to look if you dont post the code for what you have :slight_smile:
Thank you. I solved it like this.
chips:
  - type: template
    tap_action:
      action: toggle
    entity: light.wled_loznice
    icon: mdi:fan
    icon_color: yellow
card_mod:
  style:
      ha-state-icon {
        {{ 'animation: rotate 2s linear infinite;' if is_state('light.wled_loznice', 'on') }}
       @keyframes rotate {
    style: |
      ha-card {
is there a way you can share your server page with the cards?
For some odd reason my sonos doesnt show volume buttons with the mushroom media cardā€¦ My nvidia shield does show the buttonsā€¦ Does anyone know how to solve this?
I am new to this and I apologize for my mistake, could you please check if the code has been formatted properly?
Kwame
Ill answer each of your points separately if thats ok.
  1. You can do this like this:
    secondary: |-
      {{states(config.entity) | capitalize}}
Using config.entity is just used instead of writing the entity id again.
I also had to adjust the height of the second card a bit + the total height of the stack in card.
  1. You seem to already have this working? You have it so the animation will only play when input_select is Running
You could also do it like this (IMO a bit easier to read)
{% if is_state('input_select.washing_machine_status_2','Running') %}
  1. Same number 1 :slight_smile:
Here is the full config.
cards:
    entity_status: ''
    value_template: |-
       running
       idle
      {%- else -%}
       off
      {%- endif %}
    icon_color: |-
       amber
      {%- else -%}
        red
      {%- endif %}
    layout: vertical
    secondary: |-
    tap_action:
      action: Dropdown
    card_mod:
      style: |
        ha-state-icon {
        ha-card {
          border: none;
    icon_color: |-
        orange
      {%- else -%}
        grey
      {%- endif %}
    layout: vertical
    tap_action:
      action: Dropdown
    card_mod:
      style: |
        ha-state-icon {
        ha-card {
          top: -117px;
          border: none;
card_mod:
  style: |
    ha-card {
      height: 120px;
Hello Dimitri,
Thanks so much for your quick responds, used your code and is working for now.
Again, I greatly appreciate all your assistance Sir.
Does somebody know why some of my cards are looking like this?
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: custom:mushroom-title-card
    title: Climate
    subtitle: ''
  - type: grid
    square: false
    columns: 2
    cards:
        style: |
          ha-card {
            padding-bottom: 14px !important;
        primary: Thermostat
        secondary: |
          Currently: {{ state_attr('climate.toon_thermostat', 'hvac_action') }}
        icon: |-
          {% set mode = states('climate.toon_thermostat') %}
          {% if mode == 'off' %}
          mdi:radiator-off
          {% elif mode == 'heating' %}
          mdi:radiator
          mdi:radiator-disabled
        icon_color: |-
          {% set status = state_attr('climate.toon_thermostat','hvac_action') %}
          {% if status == 'heating' %}
          red
          grey
        tap_action: none
      - type: vertical-stack
        cards:
          - type: custom:simple-thermostat
            style: |
              ha-card {
                --st-spacing: 0px;
              ha-card .current--value {
                color: #ffffff;
              header {
                margin-bottom: 10px !important;
                padding-bottom: 0px !important;
              ha-card .thermostat-trigger {
                color: #6f6f6f;
            entity: climate.toon_thermostat
            header:
              icon: false
            decimals: '1'
            fallback: 'Off'
            hide:
              temperature: true
              state: true
            layout:
              mode:
                names: false
                icons: false
                headings: false
              step: row
            step_size: '0.5'
            control:
              hvac:
                'off': false
                heat: false
                cool: false
                heat_cool: false
    style: |
      ha-card {
        --st-font-size-toggle-label: 6px
        --st-spacing: 0px;
        --st-default-spacing: 0px;
        --st-mode-background: #2d2d2d;
        margin-left: 12px;
        margin-right: 12px;
      ha-card .mode-item.active.off {
        background: #363636;
        color: #9e9e9e;
      ha-card .mode-item.active.heat {
        background: #472421;
        color: #f44336;
      ha-card .mode-item.active {
        background: #263926;
        color: #4caf50;
      ha-card .mode-item.active:hover {
        color: #9e9e9e;
      ha-card .mode-item:hover {
        color: #9e9e9e;
      ha-card .mode-item {
        --st-spacing: 10px;
        border-radius: 10px;
      ha-card .modes {
        grid-gap: 12px
    header: false
    setpoints: false
    hide:
      temperature: true
      state: true
    layout:
      mode:
        headings: false
        icons: true
        names: false
      step: row
    control:
      hvac:
        'off':
        heat:
    style: |
      ha-card {
        --chip-spacing: 0px;
        --chip-padding: 0 0.2em
    alignment: justify
    chips:
      - type: template
        content: '{{state_attr(entity, "current_temperature")}} Ā°C'
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          grey
        style: |
          ha-card {
            margin-left: 6px;
      - type: template
        double_tap_action:
          action: none
        content: >-
          {{ states(entity) }}{{ state_attr(entity, "unit_of_measurement") }}
          Humidity
        entity: sensor.slaapkamer_luchtvochtigheid
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) }} {{ state_attr(entity, "unit_of_measurement") }}'
        entity: sensor.temperatuur_buiten
        icon: mdi:thermometer
        icon_color: grey
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        icon: |-
          {% if is_state(entity, 'off') %}
            mdi:chevron-down
          {% elif is_state(entity, 'on') %}
            mdi:chevron-up
        tap_action:
          action: toggle
        entity: input_boolean.thermostat_dropdown
        style: |
          ha-card {
            --chip-icon-size: 1em
  - type: conditional
    conditions:
      - entity: input_boolean.thermostat_dropdown
        state: 'on'
    card:
      keep:
        margin: false
        box_shadow: false
        background: false
      cards:
        - type: grid
          square: false
          columns: 2
          cards:
              entity: sensor.temperatuur_woonkamer
              primary: >-
              secondary: Binnen
              icon_color: |-
                {% set temp = states(entity) %}
                {% if temp >= '21' %}
                  red
                {% elif temp >= '17' and temp < '21' %}
                  orange
                {% elif temp == 'unknown' %}
                  grey
                  blue
              icon: mdi:home-thermometer-outline
              primary: >-
              secondary: Buiten
              icon_color: |-
                {% if temp >= '22' %}
                  red
                {% elif temp >= '15' and temp < '22' %}
                  orange
                  grey
                  blue
        - type: custom:mini-graph-card
          entities:
            - entity: sensor.temperatuur_woonkamer
              name: Inside Temperature
              color: '#4caf50'
            - entity: sensor.temperatuur_buiten
              name: Outside Temperature
              color: '#2196f3'
              y_axis: secondary
          hours_to_show: 24
          line_width: 3
          font_size: 50
          animate: true
          show:
            icon: false
            state: false
            legend: false
            fill: fade
