Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Is this what you wanted?
type: custom:mushroom-template-card
primary: '{{ states[entity].name }}'
secondary: '{{ states(entity) | title }}'
entity: light.office_light
picture: local/icons/custom_icons/ceiling-lamp.png
hold_action:
  action: toggle
double_tap_action:
  action: more-info
layout: vertical
tap_action:
  action: none
card_mod:
  style: |
    mushroom-shape-icon {
      --shape-color: none !important;
      --shape-color-disabled: none !important;
    ha-card {
      background: transparent;
      border-radius: 30px;
      margin-left: auto;
      margin-right: auto;
      margin-bottom: 2px;
      --icon-border-radius: 0;
Yes that’s exactly what I was looking for.
I’m having an issue with the rotation animation.
It works in a regular template card but not a chip template card.
What I have to spin a regular template card
card_mod:
  style:
    mushroom-shape-icon:
        .shape ha-icon {
            {% set status = state_attr('climate.daniel_s','hvac_action') %}
            {% if status == 'cooling' or status == 'heating' %}
              --icon-animation: rotation 1s linear infinite;
            {% endif %}
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
This is not working in a template chips card. The status template is correct.
card_mod:
  style:
        .shape ha-icon {
            {% set status = state_attr('climate.daniel_s','fan_mode') %}
            {% if status == 'Low' %}
            {% endif %}
            0% {
            100% {
The method is different for Mushroom Chips. Have a look here:
I figured that.
This doesn’t seem to be working.
card_mod:
  style:
    div:
      mushroom-template-chip:
          mushroom-chip: |
            ha-icon {
              {% endif %}
              0% {
              100% {
Great catch. Oddly enough, I did spell it correctly in the household overview popup. Thank you very much!
Try this
                  type: template
                  icon_color: white
                  icon: mdi:snowflake-alert
                  card_mod:
                    style: |
                        0% {
                        100% {
                      ha-card {
                        animation: rotation linear infinite;
                        animation-duration: 2s;
Thanks, I will use this for the two electric cars we have. Do you know if it can be altered so the colour changes depending on the value? For instance, below 20% the bar is red, 20%-80% the bar is green and above 80% its a totally different colour?
Not sure if that will work as it’s targeting the card and not the icon?
Write down your full code. It works on my climate.
As expected it rotates the entire chip card and not the icon.
- type: template
  entity: climate.daniel_s
  content: |
    {{ state_attr(entity,'fan_mode') }}
  icon: |-
    {% set mode = state_attr(entity,'fan_mode') %}
    {% if mode == 'Auto low' %}
     mdi:fan-off
    {% elif mode == 'Low' %}
    fas:fan
    {% endif %}
  icon_color: |-
    {% set status = state_attr(entity,'fan_mode') %}
    {% if status == 'Auto low' %}
    grey
    {% elif status == 'Low'  and states(entity) == 'cool' %}
    blue
    {% elif status == 'Low'  and states(entity) == 'heat' %}
    red
    {% else %}
    grey
    {% endif %}
  tap_action: none
  card_mod:
  style: |
      0% {
      100% {
    ha-card {
         {% endif %}
I’m going to follow this guide.
I’ve built the sensor up but haven’t yet flashed the code. I’ve moved to unraid since I last flashed an esp so need to work out if I can with unraid
I’m trying to get only the icon to spin as well, like the fan card does it. Can’t figure it out either.
I can get it to spin with a template card just not a template chip card.
How do you get it to spin with the template card?
cards:
  - type: grid
    square: false
    columns: 2
    cards:
        primary: Daniels
        secondary: >
          Currently: {{ state_attr('climate.daniel_s', 'hvac_action') | replace
          ('cooling','Cooling') | replace ('heating','Heating') | replace
          ('idle','Idle') }}
        icon: |-
          {% set mode = states('climate.daniel_s') %}
          {% if mode == 'off' %}
          mdi:fan-off
          {% elif mode == 'cool' %}
          fas:fan
          {% elif mode == 'heat' %}
          fas:fan
          {% else %}
          mdi:home-thermometer
          {% endif %}
        icon_color: |-
          {% if status == 'idle' %}
          grey
          {% elif status == 'cooling' %}
          blue
          {% elif status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        card_mod:
          style:
                .shape ha-icon {
                    {% endif %}
                    0% {
                    100% {
                ha-card {
                  padding-bottom: 14px !important;
Thanks a bunch!
But you haven’t followed my example :grinning_face_with_smiling_eyes:.
If you have more than one Chip, you need to select the Chip with nth-child(3):. You need to use animation: not --icon-animation:.
This is the second chip. I tried this and it’s not working.
card_mod:
  style:
    div:
      mushroom-template-chip:nth-child(2):
          mushroom-chip: |
            ha-icon {
              {% endif %}
              0% {
              100% {
Post your complete chip code and we can have a look.
- type: custom:mushroom-chips-card
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
        --chip-spacing: 0px;
        --chip-padding: 0 0.2em
    alignment: justify
    chips:
      - type: template
        content: '{{state_attr(entity, ''current_temperature'')}} °F'
        icon: mdi:home-thermometer
        tap_action:
          action: more-info
        icon_color: |-
          {% set state=states(entity) %}
          {% if state=='cool' %}
          blue
          {% elif state=='heat' %}
          red
          {% else %}
          grey
          {% endif %}
        style: |
          ha-card {
            margin-left: 6px;
      - type: template
        content: |
        icon: |-
           mdi:fan-off
          fas:fan
          {% endif %}
        icon_color: |-
          grey
          blue
          red
          {% else %}
          grey
          {% endif %}
        tap_action: none
        card_mod:
          style:
            div:
                  mushroom-chip: |
                    ha-icon {
                      {% endif %}
                      0% {
                      100% {
      - type: template
        tap_action:
          action: more-info
        content: >
          {{ states('sensor.daniels_humidifier_status') | replace('off','Off') |
          replace('on','On') }}
        entity: sensor.daniels_humidifier_status
        icon: mdi:air-humidifier
        icon_color: blue
        hold_action:
          action: none
      - type: template
        double_tap_action:
          action: none
        content: '{{ states(entity) | round(0) }}% Humidity'
        entity: sensor.daniels_humidity
        icon: mdi:water
        icon_color: blue
        tap_action:
          action: none
        hold_action:
          action: none
card_mod:
  style: |
    ha-card {
      --ha-card-background: transparent
