tfmeier
(Thomas Meier)
September 4, 2022, 12:28am
2723
Media integration in mushroom is one of my main projects now and I’m trying to learn from the great masters here…
While I’m trying to get my head around this one thing I don’t seem to see in any of the posts here is the replacement of the remote for UI navigation. Say I have a Google TV media player. How do you navigate the UI to select the program/video/episode with the various media players featured on this page?
Do you guys still use the remote for this? If not how do you control it from the mushroom UI, e.g. simple up/down/left/right/confirm etc. commands etc.?
Vandana
(Vandana Dass)
September 4, 2022, 1:47am
2724
Guys plz help me how can I design the same using mushroom cards.
I am a beginner plz help
rhysb
(Rhys)
September 4, 2022, 3:29am
2725
Here you go.
Mushroom Light Card with animated icon:
type: custom:mushroom-light-card
entity: light.office_light
show_brightness_control: true
card_mod:
style: |
mushroom-shape-icon {
{% if is_state(config.entity, 'on') %}
--card-mod-icon:
{% set light_level = ((state_attr(config.entity, "brightness") / 255) * 10) | round(0) * 10 %}
{% if light_level == 100 %}
mdi:lightbulb-on
{% elif light_level > 0 %}
mdi:lightbulb-on-{{ light_level }}
{% else %}
mdi:lightbulb-on-outline
{% endif %};
{% else %}
--card-mod-icon: mdi:lightbulb-outline;
{% endif %}
rhysb
(Rhys)
September 4, 2022, 5:25am
2726
Here’s an iOS styled Mushroom Card for you:
type: custom:mushroom-template-card
primary: Apple-ish Mushroom
icon: mdi:apple
icon_color: green
layout: vertical
card_mod:
style:
display: block;
margin-left: auto;
width: 96px;
mushroom-state-info {
text-align: start;
ha-card {
width: 120px;
height: 120px;
margin: auto;
mushroom-state-item {
height: 96px;
mushroom-state-info$: |
.primary {
white-space: normal !important;
overflow: hidden;
tobpet
September 4, 2022, 7:52am
2727
Icon animation like the radiator.
“icon animation using clip-path”
Sylwester
(Sylwester Olik)
September 4, 2022, 8:19am
2728
You are the best @rhysb !!! Amazing.
rhysb
(Rhys)
September 4, 2022, 8:25am
2729
Yes, you can do that like this:
Mushroom Chip clip-path animation:
type: custom:mushroom-chips-card
chips:
- type: template
icon: mdi:mushroom
icon_color: red
- type: template
icon: mdi:radiator
icon_color: orange
- type: template
icon: mdi:snail
icon_color: green
card_mod:
style:
mushroom-template-chip:nth-child(2)$: |
ha-icon {
animation: clip 1s linear infinite;
@keyframes clip {
0% {
clip-path: inset(50% 0 0 0);
100% {
clip-path: inset(0 0 0 0);
Sylwester
(Sylwester Olik)
September 4, 2022, 8:33am
2730
Did you find solution for that?
rhysb
(Rhys)
September 4, 2022, 9:25am
2732
You can change the colors used for the Mushroom Alarm Card/Chip by adding these values to you theme:
mush-rgb-red: 244, 67, 54
mush-rgb-green: 76, 175, 80
mush-rgb-yellow: 255, 235, 59
mush-rgb-state-alarm-disarmed: var(--mush-rgb-green)
mush-rgb-state-alarm-armed: var(--mush-rgb-red)
mush-rgb-state-alarm-triggered: var(--mush-rgb-yellow)
Or you can change it using CSS like this:
type: custom:mushroom-alarm-control-panel-card
entity: alarm_control_panel.downstairs
states:
- armed_home
- armed_away
card_mod:
style: |
:host {
--mush-rgb-state-alarm-disarmed: var(--rgb-green);
--mush-rgb-state-alarm-armed: var(--rgb-red);
--mush-rgb-state-alarm-triggered: var(--rgb-yellow);
Vandana
(Vandana Dass)
September 4, 2022, 10:06am
2733
Can you plz guide how can I have the same design with mushroom card. This screenshot is from room-card.
Kindly guide
buche11
(Sebastian)
September 4, 2022, 11:08am
2734
Great, thank you! Works perfekt!!!
(James Scialdone)
September 4, 2022, 1:25pm
2735
Any idea what I’m doing wrong yet with the slider?
Is it possible to get more information by the name or create something like this? now i did used the light card. Can i use an entity bij the name: field?
FreakLikeMe:
WiFi: Picture element
Hi Can you post the code snipet pls ? newbie here having trouble integrating picture element within the mushroom chip card. thanks again.
(James Scialdone)
September 4, 2022, 10:59pm
2738
Ok sorry to keep bugging you with this, but I have the code working. The fan speed changes as I drag the slider up and down
However if I drag it all the way to 0, it kills it, the animation code won’t work anymore unless I redo the code . Any idea why?
(James Scialdone)
September 4, 2022, 11:07pm
2739
Anddd I fixed it. In case anyone has the same
Issue….had to change input_number slider minimum value to 1 instead of 0. 0 broke the code you gave me.
Thanks for the help
rhysb
(Rhys)
September 5, 2022, 5:26am
2740
Yes, you can add text to both the primary and secondary info text. This should work for any Mushroom Card and you can apply separate styling to the text.
Mushroom Card - Before primary text:
layout: vertical
card_mod:
style:
.primary:before {
content: "({{ states('sensor.rhys_office_sensor_temperature') | round(1) }} °C / {{ states('sensor.rhys_office_sensor_humidity') | round(1) }} %) ";
color: rgb(var(--rgb-orange));
font-weight: 400;
Mushroom Card - After primary text:
layout: vertical
card_mod:
style:
.primary:after {
content: " ({{ states('sensor.rhys_office_sensor_temperature') | round(1) }} °C / {{ states('sensor.rhys_office_sensor_humidity') | round(1) }} %)";
color: rgb(var(--rgb-red));
font-weight: 400;
Mushroom Card - Before secondary text:
layout: vertical
card_mod:
style:
.secondary:before {
color: rgb(var(--rgb-blue));
font-weight: 400;
Mushroom Card - After secondary text:
layout: vertical
card_mod:
style:
.secondary:after {
color: rgb(var(--rgb-green));
font-weight: 400;
Robshot
(robbie demaegdt)
September 5, 2022, 5:29am
2741
I think you will have to use roomcard for a feature to make this.
I have the same design and I’m also using room-card.
Vandana
(Vandana Dass)
2742
ok thank you for the reply
