Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Sure but I didnā€™t get which ones you want ?
Thatā€™s very cool :+1:
Hi there - I posted a question earlier that you answered here a few days ago - sorry about that, I must have missed it.
The example you provided in this reply allows us to change the characteristics of all the cards inside a musroom-chips-card, which is awesome. Do you have any idea if itā€™s possible to use is_state or states() logic in this top-level configuration as sort of a template? Iā€™d love to have 20-30 binary_sensors in a single chips card and use the same styling logic for every card without having to repeat it per entity/template just to capture each sensorā€™s entity idea.
I guess I could get around this a bit by using a decluttering-template that takes 3 sensors at a time and creates a chips card for every 3 sensors, but thatā€™s kind of janky. Any ideas? Thanks!
Here you go :crown:
Mushroom Light Card with animated SVG icon:
Mushroom Light Card - Animated SVG Icon
type: custom:mushroom-light-card
entity: light.office_light
show_brightness_control: true
show_color_temp_control: true
show_color_control: true
use_light_color: true
icon: none
card_mod:
  style: |
    mushroom-state-item {
      {% if is_state(config.entity, 'on') %}
        {% set light_level = ((state_attr(config.entity, "brightness") / 255) * 10) | round(0) * 10 %}
        {% if light_level == 100 %}
          {% set light_level = 'on' %}
        {% elif light_level == 0 %}
          {% set light_level = 'off' %}
        {% endif %}
      {% else %}
      {% endif %}
      background: url("/local/lightbulb/lightbulb-{{ light_level }}.svg") no-repeat;
    mushroom-shape-icon {
      --shape-color: none !important;
      --shape-color-disabled: none;
Animated SVG Lightbulb
Yes, you can use Jinja in there fine. What are you wanting to do with the entities?
Cheers, give me some time to get my head around itā€¦ :wink:
Hi guys,
I have a question in regards to the usage of the browser_mod popup in combination with Mushroom. When I create a popup all the elemants in the popup have no style. The mushroom cards seem to loose the borders, shadows, etc. Do you have any clue what could cause this issue?
Iā€™ve seen some pretty nice implementations in this thread where people use the popup with these awesome mushroom cards.
Thanks in advance for your help.
Hereā€™s an example:
Hereā€™s the code I used:
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      title: Test
      content:
        type: vertical-stack
        cards:
          - type: custom:mushroom-light-card
            entity: light.lichten_keuken
            fill_container: true
            use_light_color: false
            entity: light.lichten_beneden
Kr,
Silvio
wow, this is cool.
hello, may i know how do you code the wifi chip? iā€™ve been trying to use url path but i still donā€™t get it. iā€™m still new in HASS btw.
My post might not directly be mushroom related or itā€™s not very clear what Iā€™m trying to ask. The holy grail for a lot of ā€œHome Assistant nerdsā€ is to have one UI (HA) that allows replacing all other apps. Along the same line removing of all the remotes is part of the same goal - TV, AVR, blinds etc.
So whatā€™s not clear to me on this thread is how you guys navigate in a UI like Google TV, Plex etc. If I want to watch a movie I have to search it first which is done via the UI. How do you guys do this?
If I rather post this in another topic please advise as well.
Still struggling with this one. If my sonos beam is set to TV, it is ā€˜playingā€™ therefore the card extends to show what would be the progress bar, but there is no need for it to do so.
If music is playing then it extends and album artwork appears as it should.
.image
However, id like to know how I can use mini media player variables to make the artwork gradient fade out to a colour rather than --rgb-card-background-color, I have tried variables such as some in this image, eg. --paper-item-icon-color
an example of the gradient fade to colour is here on mini media player card:
Where do you put the Decluttering Card template? Iā€™ve never done anything like that with templates.
Download decluttering card from hacs and then just put that code in your Lovelace.yaml
I would like to have a badge with the number of open shutters in a room. Does anyone knows if its possible with chips? In the example below I know I can add it to the icon with the sofa, but I would like it to be on top of the shutter icon.
Captura de ecraĢƒ 2022-09-06, aĢ€s 18.00.44
Is is also possible to blink the background(circle) of the icon?
i now how to blink the icon, but want to blink the background.
So the icon stayā€™s the same collor.
Finally i want to make the background blink when the state = today(vandaag)
    card_mod:
      style:
        mushroom-shape-icon:
            .shape ha-icon
                --icon-animation: blink 1s linear infinite;
              @keyframes blink {
              50% {opacity: 0;}
@rhysb do you know if I should put some link to the Mushroom css or the actual styling in popup css section ?
It can not be done??:upside_down_face:
Here is another option for ā€œanimatingā€ an SVG icon.
Mushroom Light Card with animated SVG icon v2:
Mushroom Light Card - Animated SVG Icon v2
icon: none
card_mod:
  style: |
        {% set light_level = (100 - (state_attr(config.entity, "brightness") | int)) %}
          background: url("/local/lightbulb/lightbulb-on.svg") no-repeat;
          filter: sepia({{ light_level }}%);
      {% else %}
          background: url("/local/lightbulb/lightbulb-off.svg") no-repeat;
      {% endif %}
      background-size: 42px 42px;
You could also use a PNG or JPG and use grayscale() instead of sepia().
I havenā€™t used the swipe card, but perhaps you could use z-index to bring the switches forward or the swipe card back.
Hello Daros, your dashboard looks just great, my absolute respect for this work.
A few parts I have taken over, would you share the code for the top area with the chipcards?
Thanks a lot and greetings
Moss
