zgadson
(Zach)
September 27, 2022, 5:02pm
3133
Can anyone help me set the color of my brightness slider bar and the max height of my card? I have never been successful with themes but Iāve managed just fine without them until now.
Hereās my code:
type: custom:mushroom-light-card
entity: light.basement_lights
show_brightness_control: true
primary_info: none
secondary_info: none
icon_type: none
style: |
ha-card {
height: 60px;
background: transparent !important;}
In short, my slider bar is too thick, so I was hoping to use the height element to shrink it down a bit. Iād also like my slider bar to be lime green. My transparent background works just fine, and height works in every other card, but not in Mushrooms.
Thank you!
silvio
(Silvio)
September 28, 2022, 5:22am
3134
Tx for the reply mate. I already started adding the css to all pop up elements. This is a pain in the xxx.
cloudbr34k
(Apples)
September 28, 2022, 5:57am
3135
Has anyone designed an appliance page , to monitor your appliances
? Just looking for inspiration. This is what I have so far
schnuggo
September 28, 2022, 6:04am
3136
Is it possible, to fix a chip card in the first row?
When scrolling down on that page, that the first row with the chip card is all time visible?
I have a back button realized in every room to come back to the main dashboard. When scrolling down in the room, i have to scroll up to see the back button again.
artpcpl
(Artpcpl)
September 28, 2022, 6:49am
3137
Looks good can u share your code, THX
Sddawson
September 28, 2022, 8:08am
3138
Out of interest, what are you using to monitor your pool chemical status? Iām using a Blue Connect.
cloudbr34k
(Apples)
September 28, 2022, 8:41am
3139
So I bought your tuya 6 in 1 wifi pool from AliExpress. I have compared it when I get my pool tested and salinity had been bang on and ph was off by.25. so Iām pretty happy with it.
You have to use LocalTuya anf pull in the data as the tuya integration only shows temperature
AU $14.03 44%OFF | Wifi Digital Water Quality Tester Wall Mounted 6 in 1 Water Analyzer PH/ EC/ TDS/ SALT/ G.S/ Temperature APP Remote Monitoring
https://a.aliexpress.com/_mPEaFao
nsf
(Nuno)
September 28, 2022, 9:35am
3140
Guys, iām pulling my hair.
Iām trying to set an icon (fan) to rotate according to the speed of a fan based on itās power consumption. But I just cant make it work. The best I was able to do was to make the whole card rotate. I tried @rhysb code, from here: Mushroom Cards - Build a beautiful dashboard easily š - #1188 by rhysb
Can someone point me un the right direction.
brewston
(Tim Jones)
September 28, 2022, 10:20am
3141
Iāve got some code for that, mine looks at
'fan.hot_tub_pump_1', 'preset_mode'
and adjusts the rotation speed.
type: custom:mushroom-template-card
primary: null
secondary: null
icon: mdi:pump
icon_color: blue
picture: ''
card_mod:
style: |
mushroom-shape-icon {
display: flex;
border-radius: 60%;
{% if (state_attr('fan.hot_tub_pump_1', 'preset_mode') == "HI") %}
animation: rotation-pulse 1s linear infinite;
{% elif (state_attr('fan.hot_tub_pump_1', 'preset_mode') == "LO") %}
animation: rotation-pulse 3s linear infinite;
{% endif %}
@keyframes rotation-pulse {
0% {
box-shadow: 0 0 0 0 rgb(var(--rgb-blue), 0.8);
transform: rotate(0deg);
70% {
box-shadow: 0 0 0 10px rgba(var(--rgb-blue), 0);
100% {
box-shadow: 0 0 0 0 rgba(var(--rgb-blue), 0);
transform: rotate(360deg);
ha-card {
background: none ;
width: 65px;
display: flex;
Sddawson
September 28, 2022, 11:00am
3142
Very interesting. So localtuya is an HA integration that can talk to this device? Have you plumbed the sensors into your pool piping, and, if so, how? Maybe this would be best via DM or something, since itās a bit off-topic here.
Could you please share your yaml for this card?
cloudbr34k
(Apples)
September 28, 2022, 11:16am
3144
which code are you after, or section or image do you want code for?
codedmind
(Codedmind)
September 28, 2022, 11:28am
3145
I think is better share the code for each image
cloudbr34k
(Apples)
September 28, 2022, 1:28pm
3146
type: vertical-stack
cards:
- camera_view: auto
type: picture-glance
title: Pool & Garden
entities: []
aspect_ratio: '4'
theme: Mushroom
camera_image: ''
image: >-
https://img.freepik.com/free-vector/house-swimming-pool-with-deck-chairs_107791-1868.jpg?w=1800&t=st=1658959684~exp=1658960284~hmac=8aa467512948cba314cf5ff8afbb3dd045a25077d24b7de7c74e2af127c3d55c
- square: false
columns: 6
type: grid
cards:
secondary: '{{ states(''sensor.pool_average_temperature'') }}Ā°C'
primary: ''
icon: mdi:pool-thermometer
entity: sensor.pool_average_temperature
icon_color: '#85C1E9'
layout: vertical
tap_action:
action: call-service
service: browser_mod.popup
content:
cards:
- type: custom:mini-graph-card
entities:
- entity: sensor.pool_average_temperature
color: '#85C1E9 '
name: Daily Pool Temperature Max
show:
graph: line
hours_to_show: 24
points_per_hour: 1
animate: true
entities:
color: '#85C1E9 '
name: Weekly Pool Temperature Max
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 168
animate: true
entities:
color: '#85C1E9 '
name: Monthly Pool Temperature Max
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 720
animate: true
title: Pool Temperature Graphs
target: {}
badge_color: ''
badge_icon: ''
multiline_secondary: false
fill_container: false
card_mod:
style:
mushroom-shape-icon$: |
.shape {
box-shadow: 0px 2px 2px 0px rgba(0,0,0,0.16) !important;
secondary: '{{ states(''sensor.pool_multi_sensor_ph'')}} ppm'
primary: ''
icon: mdi:ph
icon_color: '#009688'
layout: vertical
tap_action:
content:
cards:
entities:
- entity: sensor.pool_multi_sensor_ph
color: '#009688'
show:
graph: line
hours_to_show: 24
points_per_hour: 1
animate: true
entities:
color: '#009688'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 168
animate: true
entities:
color: '#009688'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 720
animate: true
title: Pool pH
target: {}
badge_color: ''
badge_icon: ''
card_mod:
style:
.shape {
secondary: '{{ states(''sensor.pool_multi_sensor_salinity'')}} ppm'
primary: ''
icon: mdi:flask
entity: sensor.pool_multi_sensor_salinity
icon_color: '#F1948A'
layout: vertical
tap_action:
content:
cards:
entities:
- entity: sensor.pool_multi_sensor_salinity
color: red
show:
graph: line
hours_to_show: 24
points_per_hour: 1
animate: true
entities:
color: red
name: Weekly Salinity Max
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 168
animate: true
entities:
color: '#F1948A'
name: Monthly Salinity Max
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 720
animate: true
title: Pool Salinity Graphs
target: {}
badge_color: ''
badge_icon: ''
card_mod:
style:
.shape {
secondary: '{{ states(''sensor.pool_multi_sensor_tds'')}} ppm'
primary: ''
icon: mdi:molecule
entity: sensor.pool_multi_sensor_tds
icon_color: '#7DCEA0'
layout: vertical
tap_action:
content:
cards:
entities:
- entity: sensor.pool_multi_sensor_tds
color: '#7DCEA0 '
show:
graph: line
hours_to_show: 24
points_per_hour: 1
animate: true
entities:
color: '#7DCEA0'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 168
animate: true
entities:
color: '#7DCEA0'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 720
animate: true
title: Pool Total Dissolvable Solutions
target: {}
badge_color: ''
badge_icon: ''
fill_container: true
card_mod:
style:
.shape {
secondary: '{{ states(''sensor.pool_multi_sensor_ec'')}} ppm'
primary: ''
icon: mdi:lightning-bolt
entity: sensor.pool_multi_sensor_ec
icon_color: '#F8C471'
layout: vertical
tap_action:
content:
cards:
entities:
- entity: sensor.pool_multi_sensor_ec
color: '#F8C471 '
show:
graph: line
hours_to_show: 24
points_per_hour: 1
animate: true
entities:
color: '#F8C471'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 168
animate: true
entities:
color: '#F8C471'
show:
graph: bar
group_by: date
aggregate_func: max
hours_to_show: 720
animate: true
title: Pool Electrical Conductivity Graphs
target: {}
badge_color: ''
badge_icon: ''
card_mod:
style:
.shape {
secondary: '{{ states(''sensor.zodiac_exo_chlorine_production_value'')}} %'
primary: ''
icon: mdi:chemical-weapon
entity: sensor.zodiac_exo_chlorine_production_value
icon_color: '#C39BD3'
layout: vertical
tap_action:
action: more-info
badge_color: ''
badge_icon: ''
hold_action:
action: more-info
card_mod:
style:
.shape {
cards:
- type: custom:mushroom-title-card
title: ''
subtitle: Pool Equipment
- type: vertical-stack
cards:
- type: custom:mushroom-climate-card
entity: climate.pool_heater
show_temperature_control: false
hvac_modes:
- heat
card_mod:
style:
.shape {
- square: false
columns: 3
type: grid
cards:
- type: custom:stack-in-card
cards:
secondary: null
primary: Chlorinator
icon: >-
{{ state_attr('binary_sensor.zodiac_exo_chlorinator_status',
'icon') }}
entity: binary_sensor.zodiac_exo_chlorinator_status
icon_color: >-
{% set state=states('binary_sensor.zodiac_exo_chlorinator_status')
{% if state=='off' %}
disabled
{% elif state=='on' %}
green
{% elif state=='unavailable' %}
red
{% endif %}
layout: vertical
tap_action:
action: more-info
badge_color: ''
card_mod:
style:
.shape {
- type: custom:mushroom-chips-card
chips:
- type: template
entity: binary_sensor.zodiac_exo_chlorine_production_status
icon: >-
{% set
state=states('binary_sensor.zodiac_exo_chlorine_production_status')
%} {% if state=='on' %} mdi:flask-plus {% elif state=='off' %}
mdi:chemical-weapon {% elif state=='unavailable' %}
mdi:chemical-weapon {% endif %}
icon_color: >-
{% set
%} {% if state=='on' %} green {% elif state=='off' %} disabled
{% elif state=='unavailable' %} red {% endif %}
tap_action:
action: more-info
content: ''
hold_action:
action: more-info
- type: template
entity: binary_sensor.zodiac_app_connnection_status
icon: >-
{% set
state=states('binary_sensor.zodiac_app_connnection_status') %}
mdi:api
mdi:api-off
{% endif %}
icon_color: >-
{% set
green
red
{% endif %}
tap_action:
action: more-info
content: ''
hold_action:
action: more-info
- type: template
entity: sensor.zodiac_exo_error_state
icon: |-
{% set state=states('sensor.zodiac_exo_error_state') %}
{% if state=='0' %}
mdi:alert-circle
{% elif state=='1' %}
mdi:alert-circle
{% endif %}
icon_color: |-
{% if state=='0' %}
disabled
red
{% endif %}
tap_action:
action: more-info
content: ''
hold_action:
action: more-info
alignment: center
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
cards:
primary: >-
{{ state_attr('binary_sensor.zodiac_pool_filter_pump',
'friendly_name') }}
secondary: null
icon: '{{ state_attr(''binary_sensor.zodiac_pool_filter_pump'', ''icon'') }}'
tap_action:
action: more-info
layout: vertical
icon_color: |-
{% set state=states('binary_sensor.zodiac_pool_filter_pump') %}
disabled
green
red
{% endif %}
entity: binary_sensor.zodiac_pool_filter_pump
card_mod:
style:
.shape {
chips:
- type: entity
entity: sensor.zodiac_exo_chlorinator_schedule_start_time
- type: entity
entity: sensor.zodiac_exo_chlorinator_schedule_end_time
alignment: center
card_mod:
style: |
ha-card {
--chip-spacing: 0;
cards:
primary: Pool Cleaner
secondary: null
icon: mdi:robot-mower
entity: sensor.robot_pool_cleaner_power_status
picture: ''
badge_icon: ''
icon_color: |-
{% set state=states('sensor.robot_pool_cleaner_power_status') %}
{% if state=='On' %}
green
{% elif state=='Off' %}
disabled
{% endif %}
layout: vertical
tap_action:
action: more-info
card_mod:
style:
.shape {
chips:
- type: template
entity: sensor.robot_pool_cleaner_voltage_status
icon: >-
{% set
state=states('sensor.robot_pool_cleaner_voltage_status') %}
mdi:flash-triangle
mdi:flash-triangle
{% endif %}
icon_color: >-
{% set
green
red
{% endif %}
- type: template
icon: >-
mdi:flash
mdi:flash
{% endif %}
icon_color: >-
green
disabled
{% endif %}
alignment: center
card_mod:
style: |
ha-card {
--chip-spacing: 0;
card_mod:
style: |
ha-card {
{% if is_state('sensor.robot_pool_cleaner_plug_power', '{% if is_number(state) and state | float >= 1 %}') %}
background: rgba(76, 175, 80, 0.1);
{% endif %}
codedmind
(Codedmind)
September 28, 2022, 3:11pm
3147
Thanks.
Can you share also the code for the first to picsā¦ the applicances and the popup card.
can I use ābadge iconā settings in custom:mushroom-person-card ?
this is my code, but badge icon doesnāt change:
mode: vertical
cards:
- type: custom:mushroom-person-card
entity: person.andrea
use_entity_picture: true
primary_info: name
secondary_info: null
layout: vertical
badge_icon: >-
{% if is_state('binary_sensor.cellulare_andrea_is_charging_2', 'on') -%}
mdi:power-plug
{%- elif is_state('binary_sensor.cellulare_andrea_is_charging_2', 'off')
mdi:power-plug-off
{%- else -%}
mdi:power-plug-off
{%- endif %}
badge_color: |-
red
{%- endif %}
card_mod:
style: |
mushroom-shape-avatar {
{{ 'filter: grayscale(100%);' if not is_state('person.andrea', 'home') }}
thank you
tvds
(Tim)
September 28, 2022, 7:18pm
3149
I got it working based on your config ā¦ I have a light group: light.all_lights.
chips:
- type: template
icon: |
{% if is_state('light.all_lights', 'off') %}
mdi:lightbulb-multiple-off
{% else %}
{% endif %}
icon_color: |
blue-grey
{% else %}
#FDD835
{% endif %}
entity: light.all_lights
content: >-
{{ expand(states.light.all_lights) | selectattr( 'state', 'eq','on')
| list | count }}
card_mod: null
tap_action:
action: fire-dom-event
browser_mod:
title: Lichten aan
content:
type: custom:auto-entities
filter:
include:
- group: light.all_lights
state: 'on'
options:
layout: horizontal
tap_action:
action: toggle
use_light_color: true
card_mod:
style: |
ha-card {
padding: 4px 12px !important;
exclude:
- domain: light
attributes:
types: browser_mod
card:
type: entities
cards: []
show_header_toggle: false
sort:
method: friendly_name
target: {}
nsf
(Nuno)
September 28, 2022, 8:16pm
3150
Thanks @brewston but I cant make it work.
Hereās the code I have. Icon color, secondary information, and badge icon work as expected based on the power usage of the fan.
But I cant get the fan rotation speed working based on the power usage. The way it is itās the whole card that spins.
Can someone point me to the problem.
primary: VentilaĆ§Ć£o
entity: sensor.ventilacao_power
icon: mdi:fan
secondary: |-
{% set power = states('sensor.ventilacao_power') | int %}
{% if power < 5 %} Standby
{% elif power < 13 %} MĆnimo
{% elif power < 19 %} MĆ©dio
{% elif power < 28 %} MƔximo
{% else %} Desligada
{% endif %}
icon_color: |-
{% if power < 5 %} green
{% elif power < 13 %} blue
{% elif power < 19 %} amber
{% elif power < 28 %} red
{% else %} grey
{% endif %}
badge_icon: |-
{% if power < 5 %} mdi:fan
{% elif power < 13 %} mdi:numeric-1
{% elif power < 19 %} mdi:numeric-2
{% elif power < 28 %} mdi:numeric-3
{% else %} mdi:fan-off
{% endif %}
card_mod: null
style: |
@keyframes rotation {
0% {
100% {
ha-card {
box-shadow: 0px 0px;
animation: rotation linear infinite;
{% if states('sensor.ventilacao_power') | float < 10 %}
animation-duration: 5s;
{% elif states('sensor.ventilacao_power') | float < 17 %}
animation-duration: 3s;
{% elif states('sensor.ventilacao_power') | float < 21 %}
animation-duration: 1s;
{%- else -%}
animation-duration: ;
{%- endif %}
brewston
(Tim Jones)
September 28, 2022, 9:05pm
3152
You appear to applying the animation to ha-card whereas my example applies it to mushroom-shape-icon
wernazz
(Wernazz)
September 28, 2022, 9:24pm
3153
that worked perfectly thank you very much!
