Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Cool, thank you :wink:
Here:
https://github.com/javawizard/ha-navbar-position
type: conditional
conditions:
  - entity: input_boolean.boolean_kjokken_dashboard_lys
    state: 'on'
card:
  type: vertical-stack
  cards:
    - type: horizontal-stack
      cards:
        - type: custom:stack-in-card
          cards:
            - type: custom:mushroom-light-card
              entity: light.kjokkenet_dz
              icon: hue:lightstrip
              show_brightness_control: true
              collapsible_controls: true
            - type: custom:mushroom-chips-card
              chips:
                - type: template
                  entity: switch.aqara_kontakt_kjokkenet_1
                  icon: |-
                    {% if is_state(config.entity, 'on') %}
                      hue:plug
                    {% else %}
                      hue:plug
                    {% endif %}
                  icon_color: |-
                    green
                    {% else %}
                    white
                    {% endif %}
                  tap_action:
                    action: toggle
                    card_mod:
                      style: |
                        ha-card {
                          --chip-box-shadow: none;
                          --chip-background: none;
                          --chip-spacing: 0;
                          margin-top: -10px;
                - type: template
                  entity: light.taklyset_pa_kjokken
                  icon: |-
                      mdi:ceiling-light
                    {% else %}
                      mdi:ceiling-light-outline
                    {% endif %}
                  icon_color: |-
                    orange
                    {% else %}
                    white
                    {% endif %}
                  tap_action:
                    action: toggle
                    card_mod:
                      style: |
                        ha-card {
                          --chip-spacing: 0;
                          margin-top: -10px;
                - type: entity
                  entity: ledig
                  icon_color: purple
                  icon: mdi:arrow-expand-right
                  content_info: none
                  tap_action:
                    action: null
                  card_mod:
                    style: |
                      ha-card {
                        --chip-background: rgba(var({{ '--rgb-purple' if is_state(config.entity, 'on') else '--rgb-disabled' }}), 0.2);
                        --icon-color: rgb(var(--rgb-disabled));
              card_mod:
                style: |
                  ha-card {
                      top: 16px;
                      width: -webkit-fill-available;
                      right: 12px;
                      position: absolute;
                  .chip-container {
                      right: 0px;
                      position: absolute;
Kind of similar request I have. Did you ever find a solution?
These are just AWESOME! This will take the dash to another level, thanks @rhysb !
Now I am curious about, for example, the Washing Machine #2 Animation.
How to create: an icon without animation, but if the washing machine is running…the animated icon?
And when it has stopped…the icon without animation again.
Any thoughts?
Thanks and have a great weekend ahead!
if you use card mod you can use the following code:
chips:
  - type: …
    card_mod:
      style: |
        :host { display:
          {% set x = ['unavailable', 'unknown', 'none'] %}
          {% set e = states('sensor.mobile_battery_level') %}
          {% set b = (e|float(100) <= 35) %}
          {{ 'inline' if b or e in x else 'none' }}; }
My thought would be something like this:
cards:
    entity: sensor.washing_machine
    icon: mdi:washing-machine
    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
    primary: 'Washing Machine #2'
    card_mod:
      style:
        mushroom-shape-icon$: |
          ha-icon {
            {{ '--icon-animation: shake 400ms ease-in-out infinite;' if is_state(config.entity, 'on') }}
            transform-origin: 50% 58%;
            clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
          @keyframes shake {
            0%, 100% { transform: translate(0, 0) rotate(0); }
            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    card_mod:
      style:
          ha-icon {
            {{ '--icon-animation: spin 1s linear infinite;' if is_state(config.entity, 'on') }}
            clip-path: circle(21.7% at 50% 58%);
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
Needs help please.
I would like to change the code, if the off fan, then the icon will not turn around. If he is on then he will turn around.
cards:
    primary: Fan Bathroom
    icon: cil:pedestal-fan
    entity: light.fan_bathroom
    card_mod:
      style:
          ha-icon {
           --icon-animation: rotation 1s linear infinite;
          @keyframes rotation {
            100% {
              transform: rotate(360deg);
Just wrap the --icon-animation in an if, like this:
{{ '--icon-animation: rotation 1s linear infinite;' if is_state(config.entity, 'on') }}
Thank you very much
Is it ok to do it this way? or i’m wrong
cards:
    icon: mdi:sprinkler
    entity: switch.johnson
    primary: johnson
    card_mod:
      style:
          ha-icon {
            transform-origin: 29% 88%;
          @keyframes sprinkle {
            0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
            1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
            6%, 21%, 36%, 51% { transform: rotate(2deg); }
Now it’s all right :slight_smile:
cards:
    icon: mdi:sprinkler
    primary: johnson
    card_mod:
      style:
          ha-icon {
            {{ '--icon-animation: sprinkle 2s linear infinite;' if is_state(config.entity, 'on') }}
Cant get your Partly Cloudy animation to work on a chips card.
What i am doing wrong? :frowning:
chips:
  - type: template
    icon: mdi:weather-partly-cloudy
    icon_color: light-green
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-icon {
        --icon-animation: cloudy 10s ease-in-out infinite, sun 2s infinite;
      @keyframes cloudy {
        0%, 100% { transform: translateX(3px); }
        30% { transform: translateX(-1px); }
        45% { transform: translateX(1.5px); }
        75% { transform: translateX(-3.2px); }
      @keyframes sun {
        50% { clip-path: polygon(0 67%, 18% 55%, 16% 31%, 41% 12%, 67% 24%, 77% 59%, 100% 64%, 100% 100%, 0 100%); }
Thank you very much for the investment.
Can you make something related to the door? Door sensor opens and closes.
Nice can you share code ?
Already shared it, just a tiny scroll up :slight_smile:
Awesome work with these! Thanks alot!
I have a question: How to utilize these animations in the weather card where the icon can be different based on the weather entity state? Some kind of if structure I suppose but not too familiar how to do it…
Hi, what cards do you use for energy entity?
thank you. Animations work good on browser but not on official app. why?
Hello. Hoping someone can help. I’m trying to add a Mushroom Person Card. In all the videos I watch there are features in the videos that I don’t have.
For example, I don’t have the option to ā€œUse entity pictureā€
Also, I don’t have the option for ā€œHide stateā€ or ā€œHide nameā€.
Thanks for any help.
