Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Perfect! Whatā€™s the dot syntax here ?
Back up to root
When taking the code, changing till light entity to one that I have, the card fail to load as expectedā€¦
Do I need to change something in some theming code to make it work, maybe?
type: horizontal-stack
cards:
  - type: custom:mushroom-light-card
    entity: light.vardagsrum_golvlampa_tv_soffa_light
    layout: vertical
    card_mod:
      style: |
        mushroom-state-info {
          text-align: start;
          width: fit-content;
        ha-card {
          width: 100px;
  - type: custom:my-slider-v2
    vertical: true
    styles:
      card:
        - height: 147px
        - width: 42px
      container:
        - border-radius: 12px
      track:
        - background: >
            [[[ if (entity.state == "off") return
            "rgba(var(--mush-rgb-disabled), 0.2)";
             else return "rgba(var(--mush-rgb-amber), 0.2)";
      progress:
        - background: >
            "rgb(var(--mush-rgb-disabled))";
             else return "rgb(var(--mush-rgb-amber))";
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
          padding: 12px 12px 12px;
          margin-left: auto;
card_mod:
  style: |
    ha-card {
      height: 171px;
Some of the cards iā€™ve seen here are brilliant. Iā€™m really stuck trying to alter the icon on the mushroom climate card based on if there is a demand for heat. Iā€™ve also tried to get this working in a template card also, but im missing something.
Facts:
The Mushroom climate card works as expected normally, with the heat and off functions working
trv. I also got it to flash at all times.
type: custom:mushroom-climate-card
entity: climate.trv_2
icon: mdi:radiator
layout: horizontal
hvac_modes:
  - heat
  - 'off'
show_temperature_control: true
collapsible_controls: true
tap_action:
  action: none
hold_action:
  action: toggle
double_tap_action:
  action: more-info
card_mod:
  style: |
    {% set state=states('climate.trv_2') %}
    {% if state == 'heat' %}
      mushroom-shape-icon {
        animation: blink 3s ease-in infinite;
      @keyframes blink {
        50% {opacity: 0;}
    {% endif %}
I have card-mod installed
I have a TRV (actually 20 in total, but focusing on one to get the code working).
The TRV entity is climate.trv_2 and also exposes a temperature sensor - sensor.trv_2_air_temperature
These are the states reported:
hvac_modes:
  - 'off'
  - heat
min_temp: 8
max_temp: 28
preset_modes:
  - none
  - Energy heat
  - Full power
current_temperature: 21.9
temperature: 17.5
preset_mode: none
friendly_name: TRV 2 - Kitchen Hall
Generally in normal use the TRV will be in preset mode -none
If you press the boost button, it will be in Full Power for 15 minutes and then revert back to none (Energy Heat is like an eco mode and not important at this point)
Iā€™ve tried all sorts and been through many posts here and tried snippets of code.
I ultimately would like the icon to change colour or flash if the ā€˜temperatureā€™ (setpoint) is less than ā€˜current_temperatureā€™ - so that I can see at a glance that the room is demanding heat.
I cant get the states to even reflect properly and change the icon based on if the TRV is set to heat or off.
Although I can in a template card - although the icon doesnt change colour in this example still, but the icon does change on and off
type: custom:mushroom-template-card
style: |
  ha-card {
    padding-bottom: 14px !important;
primary: TRV_2
secondary: ''
icon: |-
  {% set mode = states('climate.trv_2') %}
  {% if mode == 'none' %}
  mdi:radiator-off
  {% elif mode == 'heat' %}
  mdi:radiator
  {% else %}
  mdi:radiator-disabled
  {% endif %}
icon_color: |-
  {% set status = state_attr('climate.trv2','hvac_modes') %}
  {% if status == 'heat' %}
  red
  {% else %}
  grey
  {% endif %}
I really dont know why (but this is not my specialty!)
What iā€™m trying to accomplish is the mushroom climate card working as normal,
but the icon changing from ā€˜radiator-offā€™ to ā€˜radiatorā€™ when the TRV is in heat mode, and
it changing colour (flashing ideally) when the ā€˜temperatureā€™ (setpoint) is less than 'current_temperature, to indicate the room is demanding heat
Could anyone please make my day and help me accomplish what i thought was going to be something simple? :slight_smile:
Thanks in advance!
Ok, so I had another theme applied, and that made the slider look funny :slight_smile:
How do I add script ā†’ last changed (last time the script was called) to a template card secondary information?
Iā€™m having the same problems you experienced but Iā€™m on the correct theme i believe. Can you elaborate what you had to do to fix it?
type: custom:stack-in-card
mode: horizontal
cards:
    entity: light.br_desk_lightbulb
    layout: vertical
    card_mod:
      style: |
          text-align: start;
          width: fit-content;
        ha-card {
          width: 66px;
    vertical: true
    styles:
      card:
        - height: 147px
        - width: 42px
      container:
      track:
        - background: >
      progress:
        - background: >
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
          margin-left: auto;
card_mod:
  style: |
    ha-card {
      height: 171px;
In this file;
I replaced everything with this;
Mushroom:
  # HA variables
  ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
  ha-card-border-radius: 12px
  # Mushroom layout
  mush-spacing: 12px
  # Title
  mush-title-padding: 24px 12px 16px
  mush-title-spacing: 12px
  mush-title-font-size: 24px
  mush-title-font-weight: normal
  mush-title-line-height: 1.2
  # Subtitle
  mush-subtitle-font-size: 16px
  mush-subtitle-font-weight: normal
  mush-subtitle-line-height: 1.2
  # Card
  mush-card-primary-font-size: 14px
  mush-card-secondary-font-size: 12px
  mush-card-primary-font-weight: bold
  mush-card-secondary-font-weight: bolder
  mush-card-primary-line-height: 1.5
  mush-card-secondary-line-height: 1.5
  # Chip
  mush-chip-spacing: 8px
  mush-chip-padding: 0 0.25em
  mush-chip-height: 36px
  mush-chip-border-radius: 18px
  mush-chip-font-size: 0.3em
  mush-chip-font-weight: bold
  mush-chip-icon-size: 0.5em
  mush-chip-avatar-padding: 0.1em
  mush-chip-avatar-border-radius: 50%
  mush-chip-box-shadow: var(--ha-card-box-shadow)
  mush-chip-background: var(--ha-card-background)
  # Control
  mush-control-border-radius: 12px
  mush-control-height: 42px
  mush-control-button-ratio: 1
  mush-control-icon-size: 0.5em
  # Slider
  mush-slider-threshold: 10
  # Badge
  mush-badge-size: 16px
  mush-badge-icon-size: 0.75em
  mush-badge-border-radius: 50%
  # Icon
  mush-icon-border-radius: 50%
  mush-icon-size: 42px
  mush-icon-symbol-size: 0.5em
  # Colors
  mush-rgb-red: 244, 67, 54
  mush-rgb-pink: 233, 30, 99
  mush-rgb-purple: 156, 39, 176
  mush-rgb-deep-purple: 103, 58, 183
  mush-rgb-indigo: 63, 81, 181
  mush-rgb-blue: 33, 150, 243
  mush-rgb-light-blue: 3, 169, 244
  mush-rgb-cyan: 0, 188, 212
  mush-rgb-teal: 0, 150, 136
  mush-rgb-green: 76, 175, 80
  mush-rgb-light-green: 139, 195, 74
  mush-rgb-lime: 205, 220, 57
  mush-rgb-yellow: 255, 235, 59
  mush-rgb-amber: 255, 193, 7
  mush-rgb-orange: 255, 152, 0
  mush-rgb-deep-orange: 255, 87, 34
  mush-rgb-brown: 121, 85, 72
  mush-rgb-grey: 158, 158, 158
  mush-rgb-blue-grey: 96, 125, 139
  mush-rgb-black: 0, 0, 0
  mush-rgb-white: 255, 255, 255
  mush-rgb-info: var(--mush-rgb-blue)
  mush-rgb-success: var(--mush-rgb-green)
  mush-rgb-warning: var(--mush-rgb-orange)
  mush-rgb-danger: var(--mush-rgb-red)
  mush-rgb-state-fan: var(--mush-rgb-green)
  mush-rgb-state-light: var(--mush-rgb-orange)
  mush-rgb-state-entity: var(--mush-rgb-blue)
  mush-rgb-state-switch: var(--mush-rgb-blue)
  mush-rgb-state-alarm-disarmed: var(--mush-rgb-info)
  mush-rgb-state-alarm-armed: var(--mush-rgb-success)
  mush-rgb-state-alarm-triggered: var(--mush-rgb-danger)
  mush-rgb-state-person-home: var(--mush-rgb-success)
  mush-rgb-state-person-not-home: var(--mush-rgb-danger)
  mush-rgb-state-person-zone: var(--mush-rgb-info)
  mush-rgb-state-person-unknown: var(--mush-rgb-grey)
  mush-rgb-state-cover-open: var(--mush-rgb-blue)
  mush-rgb-state-cover-closed: var(--mush-rgb-disabled)
  mush-rgb-state-climate-auto: var(--mush-rgb-green);
  mush-rgb-state-climate-cool: var(--mush-rgb-blue);
  mush-rgb-state-climate-dry: var(--mush-rgb-orange);
  mush-rgb-state-climate-fan-only: var(--mush-rgb-blue-grey);
  mush-rgb-state-climate-heat: var(--mush-rgb-deep-orange);
  mush-rgb-state-climate-heat-cool: var(--mush-rgb-green);
  mush-rgb-state-climate-idle: var(--mush-rgb-grey);
  mush-rgb-state-climate-off: var(--mush-rgb-disabled);
  # You must keep this to support light/dark theme
  modes:
    light:
      mush-rgb-disabled: 189, 189, 189
    dark:
      mush-rgb-disabled: 111, 111, 111
Then I selected the Mushrrom theme
Worked perfectly! Thank you!
Follow-up Idea for this post:
@rhysb Do you think itā€™s possibile to combine the my-slider-card-v2 + the mushroom light card and maybe the card-mod to put the slider on the right side?
Proposed design:
I did some playing around with all the my-slider-card-v2 and everytime I try it I run into the same problem that I canā€™t place the my-slider-card-v2 within the mushroom entity card. If i could figure that peice of the puzzle out I think it could flow easily.
Test code:
mode: horizontal
cards:
    entity: light.lr_light_group
    name: All Living Room Lights
    show_brightness_control: true
    use_light_color: true
    show_color_control: true
    layout: vertical
    card_mod:
      style: |
          text-align: start;
          width: fit-content;
        ha-card {
          width: 66px;
    vertical: true
    styles:
      card:
        - height: 147px
        - width: 42px
      container:
      track:
        - background: >
      progress:
        - background: >
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
          margin-left: auto;
card_mod:
  style: |
    ha-card {
      height: 171px;
Other test code:
Notes on this code:
  • conditional card that shows only if the light isnā€™t unavailable
  • within that is a grid that shows the light + switch group for group control
  • within each group is the pop-up-card that shows all the individual entities for individual control
Goal in mind: On mobile, the slider is too small to dial in desired amounts and if I can move the slider like in my proposed design, hopefully Itā€™ll display better on mobile and enable finer detailed controls while maintaining individual control as well via popup. Best of both worlds I guess.
square: false
columns: 2
type: grid
cards:
  - type: conditional
    conditions:
      - entity: light.lr_light_group
        state_not: unavailable
    card:
      cards:
        - type: custom:layout-card
          layout_type: custom:grid-layout
          layout:
            grid-template-columns: auto 42px
            margin: '-4px -4px -8px -4px;'
          cards:
              name: 'All Living Room Lights '
              show_color_temp_control: true
              icon: mdi:sofa-outline
              layout: vertical
              hold_action:
                action: toggle
              tap_action:
                action: fire-dom-event
                browser_mod:
                  service: browser_mod.popup
                    title: All Living Room Lights
                    content:
                      cards:
                          entity: light.lr_couch_lightbulb
                          name: 'Couch Lightbulb '
                          icon: mdi:sofa
                          tap_action:
                            action: toggle
                          card_mod:
                            style: |
                              ha-card {
                                padding: 8px 24px !important;
                          entity: light.lr_porch_lightbulb
                          name: Porch Lightbulb
                          icon: mdi:outdoor-lamp
                          tap_action:
                            action: toggle
                          card_mod:
                            style: |
                              ha-card {
                          entity: light.lr_small_couch_lightbulb
                          name: 'Small Couch Lightbulb '
                          icon: mdi:sofa-single-outline
                          tap_action:
                            action: toggle
                          card_mod:
                            style: |
                              ha-card {
                          entity: light.lr_small_porch_lightbulb
                          name: 'Small Porch Lightbulb '
                          icon: mdi:coach-lamp
                          tap_action:
                            action: toggle
                          card_mod:
                            style: |
                              ha-card {
                          entity: light.lr_tv_light_bars
                          name: TV Light Bars
                          icon: mdi:led-strip
                          tap_action:
                            action: toggle
                          card_mod:
                            style: |
                              ha-card {
                              ha-card {
                                    --badge-size: 0px;
                    layout: vertical
                    card_mod:
                      style: |
                        ha-card {
                          background: none;
                          --ha-card-box-shadow: 0px;
  - type: custom:stack-in-card
    cards:
        layout:
        cards:
          - type: custom:mushroom-entity-card
            entity: switch.lr_switch_group
            name: 'All Living Room Switches '
            icon_color: blue
            layout: vertical
            card_mod:
              style: |
                ha-card {
                  background: none;
            hold_action:
              action: toggle
            tap_action:
              browser_mod:
                  title: All Living Room Switches
                  content:
                    type: grid
                    square: false
                    columns: 2
                    cards:
                        entity: switch.lr_couch_light
                        name: Couch Light (Disabled)
                        icon: mdi:sofa
                        layout: vertical
                        tap_action:
                          action: toggle
                        card_mod:
                          style: |
                            ha-card {
                              --badge-size: 0px;
                        entity: switch.lr_porch_light_switch
                        name: Porch Light (disabled)
                        layout: vertical
                        tap_action:
                          action: toggle
                        card_mod:
                          style: |
                            ha-card {
                              --badge-size: 0px;
                        entity: switch.lr_tv
                        icon: mdi:television-box
                        layout: vertical
                        icon_type: icon
                        tap_action:
                          action: toggle
                        entity: switch.lr_light_bars
                        layout: vertical
                        icon: mdi:led-strip
                        tap_action:
                          action: toggle
                        entity: switch.lr_vinyl_player
                        name: Vinyl Player (disabled)
                        icon: mdi:album
                        layout: vertical
                        tap_action:
                          action: toggle
                        card_mod:
                          style: |
                            ha-card {
                              --badge-size: 0px;
                        entity: switch.lr_video_games
                        name: V.G / Air Purifer
                        icon: mdi:video-input-component
                        layout: vertical
                        tap_action:
                          action: toggle
                      - type: conditional
                        conditions:
                          - entity: fan.cr_air_purifier
                        card:
                          type: custom:mushroom-fan-card
                          icon_animation: true
                          name: 'Air Purifier Fan '
                          icon: mdi:fan
                          layout: vertical
                          secondary_info: state
                          icon_type: entity-picture
                          show_percentage_control: true
                          show_oscillate_control: false
                          tap_action:
                            action: toggle
                          hold_action:
                            action: more-info
I just KNOW the answer is close but I just donā€™t have the knowledge and experience yet on how to configure this the right way.
Could you ā€œphotoshopā€ the card that you want to create? Iā€™m doing the exact same thing here on my end. And I think Iā€™m close to getting it the way I want it.
My suggestion is; start with one horizontal card, followed by two vertical cards.
In the first vertical card, add entities as you wish.
In the second, add the slider.
cards:
  - type: vertical-stack
    cards:
        secondary_info: none
        fill_container: false
        tap_action:
          action: toggle
        icon: mdi:floor-lamp
        primary_info: none
        layout: horizontal
        secondary_info: name
        tap_action:
          action: toggle
        icon: ''
        icon_type: none
        primary_info: state
    vertical: true
    styles:
      card:
        - height: 140px
        - width: 35px
      container:
      track:
        - background: >
      progress:
        - background: >
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
          margin-left: auto;
      card_mod:
        style: |
          ha-card {
            height: 140x;
Then when You have it the way you want it, change the first horizontal card to a stack in card instead.
This is three cards, nested with custom stack in card in the end.
(I always do the stack-in-card at the very end, so I can see all the other cards malfunctioning up until where I get it the way I want it).
  • The struggle for me right now is that; my left half of the card is two entities cards, stacked vertically. And the second (lower) entity card, I want to align to the BOTTOM of the stack-in-card.
EDIT
Or I might do this
I see what youā€™re saying. Hereā€™s what Iā€™m trying to achieve as one card:
aad0712279e81ccefc03c184815d53954d6b05e8
and then ultimately end up with something like this:
But what I think what would be better and maybe more realistic is this or the same above but stacked onto each other:
Screen Shot 2022-10-17 at 1.31.10 PM
What I currently have:
cards:
    cards:
        show_brightness_control: false
        show_color_temp_control: false
        show_color_control: false
        name: Living Room Lights
        tap_action:
          action: toggle
        icon: ''
        primary_info: name
        name: Living Room Switches
        layout: horizontal
    vertical: true
    styles:
      card:
        - height: 100px
        - width: 35px
      container:
      track:
        - background: >
      progress:
        - background: >
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
      card_mod:
        style: |
          ha-card {
            height: 140x;
Things that are left Iā€™m still struggling with:
  1. Making the slider match the current color state
  2. ā€œlinkingā€ the slider with the temp + color controls
I think problem 1 will be solved if we can solve problem 2 hopefully.
Other Notes:
3. Not a problem right now but thereā€™s a lot of negative space on the right of the slider card based on this config, Iā€™d like to clean that up after I get the 2 problems fixed above
4. Add in the pop-up cards for individual control like in my ā€œside by sideā€ code above.
Is it possible to make this in Mushroom (taken from Minimalist). Camera feed and Input datetime.
Nest_Camera
Input_datetime
Best Regards
Thekholm
The way I would go about it, is the same approach I presented in the above post; nested cards.
You can split the design into pieces first. From the top;
  1. Entity (Camera) with icon and primary info and secondary info
  2. Picture entity
  3. Entity (Alarm) with icon and primary and secondary info
  4. Entity (minus sign), entity (alarm time) and entity (plus sign).
Nowā€¦
Recreate the cards as individual cards using the horizontal stack card
I.e. 4th bullet point I made, see above
4.1. Start with the Horzontal card
4.2. Add Entity, remove all but ā€œiconā€, set the desired icon
4.3. Add a new entity, remove all but the time
4.4. Finaly add entity, remove all but ā€œiconā€, set the desired icon
Do all this for all bullets points, 1-4.
Show code editor for each and every new card you created.
Copy paste all code together, in order, into a Windows\Notepad or ā€œtext editorā€. Iā€™ll call this the Base
Create a new card, select vertical stack
Select Manual card
Paste the Base into the manual card
Now you have Base 2
Now create a custom:stack-in-card, and pase Base 2 into that card.
You will probably need to use tab or space-bar to make the syntax work, but it will work.
Where can I read more about this? for further information and learning?
and another question can we apply the animations to mushroom template chip?
type: conditional
conditions:
  - entity: switch.irrigation_valves
    state: 'on'
chip:
  type: template
  entity: switch.irrigation_pump_garden
  icon: mdi:sprinkler
  icon_color: '{{ ''light-blue'' if is_state(entity, ''on'') else ''disabled'' }}'
  card_mod:
    style:
      mushroom-shape-icon$: |
        ha-icon {
          {{ '--icon-animation: sprinkle 2s linear infinite;' if is_state(config.entity, 'on') }}
          transform-origin: 29% 88%;
        @keyframes sprinkle {
          0%, 15%, 30%, 45%, 60%, 100% { clip-path: inset(0 55% 0 0); transform: rotate(0deg); }
          1%, 16%, 31%, 46% { clip-path: inset(0 0 0 0); transform: rotate(-10deg); }
          6%, 21%, 36%, 51% { transform: rotate(2deg); }
  content_info: none
  tap_action:
    action: toggle
  hold_action:
    action: none
  double_tap_action:
    action: none
I will try when I get some time. Great little guide you did, thanks! :grin:
Best regards
Thekholm
You are welcome m8. Iā€™ll try and put together a tutorial with screen captures when I have them time for it.
Peace :dove:
has anyone build a weather dashboard/page using mushroom?
would like to get some inspiration
How do you center primary and secondary text or just one of them using the mushroom template card?
How to add a second Badge Icon under the first one?
Screenshot_20221018-142109_Home Assistant
primary: TV-Rum
icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''grey'' }}'
layout: vertical
secondary: '{{ states(''sensor.tv_wave_temperature'') | round(0) }}Ā°C'
badge_icon: mdi:microsoft-xbox
badge_color: green
entity: light.tv_rum
tap_action:
  action: navigate
  navigation_path: /lovelace-mushroom/tvrum-page
hold_action:
  action: toggle
card_mod:
  style:
        display: block;
        margin-left: auto;
        width: 92px;
        text-align: start;
      ha-card {
        width: 109px;
        height: 120px;
        margin: auto;
      mushroom-state-item {
        height: 92px;
    mushroom-state-info$: |
      .primary {
        white-space: normal !important;
        overflow: hidden;
Best regards
Thekholm
