Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
What weather map are you referring to?
I’m using the:
  • Weather card (with hourly instead of day to day)
  • Sun Card (HACS)
  • Clock Weather Card (HACS)
Very beautiful and practical! Can you share your code?
@rhysb card mod doesn’t seem to work on stack-in-card? How to achieve something like the following with mushroom cards then?
I want cards stacked like that, separated by a line.
Now I tried stacking 2 template cards horizontally, and then stacking those vertically, but the line border-bottom does not work.
First try
type: custom:stack-in-card
cards:
  - type: custom:stack-in-card
    mode: horizontal
    cards:
        # left aligned title card 1
        # right aligned numbers card 1
        card_mod:
          style:
            mushroom-state-info$: |
                text-align: end;
              ha-card {
                margin-right: 8px;
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
        ha-card:after {
          content: '';
          border-bottom: solid 2px rgba(var(--rgb-disabled), 0.2);
          margin: 12px 0px -12px 54px;
    cards:
      # card 2
Then I though about a rough setup like this, but the lines are not connected:
Second try
mode: horizontal
cards:
    cards:
        # left aligned title 1
        card_mod:
          style: |
              ha-card:after {
                content: '';
        # left aligned title 2
        # etc
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
    cards:
        # right aligned numbers 1
        card_mod:
          style:
                text-align: end;
              ha-card {
                margin-right: 8px;
              ha-card:after {
                content: '';
                margin: 12px 0px -12px;
        # right aligned numbers 2
        # etc
    card_mod:
      style: |
        ha-card {
          box-shadow: none;
My second try looks something like this. It’s just not quite neat enough yet.
Hope you can help with some CSS magic :smiley:
Anything in particular you’re looking for?
Almost 95% done. How does it look?
What to wear inside the house page fully combined with climate controls and automations.
As a small note. The photo of the lady in the screenshot turns pale as the house gets colder.
Try this bit of code at the end of every single entity, works for me!
Got the code from the master himself :slight_smile:
          card_mod:
            style:
              mushroom-state-info$: null
                ha-card:after {
                  content: '';
                  border-bottom: solid 1px rgba(var(--rgb-grey), 0.2);
/Thekholm
I did this card if some one else wants it!
Just change the margin to fit your phone if something is off.
cards:
    entity: sensor.tv_wave_temperature
    primary: Temperature
    secondary: |
      {{ states('sensor.tv_wave_temperature') | round(0) }}°C
    icon: mdi:thermometer
    icon_color: green
    tap_action:
      action: more-info
  - type: custom:layout-card
    layout_type: masonry
    layout:
      width: 106
      max_cols: 1
      height: auto
      padding: 0px
      card_margin: var(--masonry-view-card-margin, -10px 8px 15px)
    cards:
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.tv_wave_temperature
            color: '#00bb33'
        hours_to_show: 24
        line_width: 3
        animate: true
        show:
          icon: false
          state: false
          legend: false
          fill: fade
        card_mod:
          style: |
            ha-card {
              background: none;
              box-shadow: none;
Best regards
Thekholm
Yess I tried that but it won’t work properly :frowning:
Try this!
          card_mod:
            style:
                ha-card:after {
                  content: '';
/T
I’m sure you can apply the border to the stack in card but I’m not sure what css variable to use so I add a template card just for the border line. Not the simplest code but it works
mode: vertical
cards:
  - type: horizontal-stack
    cards:
        primary: AAPL
        secondary: Apple
        icon: mdi:apple
        icon_color: disabled
        primary: '121.35'
        secondary: +0.12%
        card_mod:
          style:
                text-align: end;
              ha-card {
                margin: 3px 8px 0px 0px;
                --secondary-text-color: rgb(var(--rgb-green));
    card_mod:
      style: |
        ha-card {
          margin: -25px 0px 0px 66px;
    cards:
        primary: GOOG
        secondary: Alphabet Inc.
        icon: mdi:google
        primary: 2,041.04
        secondary: +0.27%
        card_mod:
          style:
                text-align: end;
              ha-card {
Awesome. Just what i was looking for. Could you please share the code? :slight_smile:
Amazing, exactly what I was looking for! Your code is much more neat as well.
Heads up!
There is one breaking change for the chips. --chip-box-shadow has changed to --ha-card-box-shadow. You can do a find and replace all to fix.
In case anyone does a copy/paste from @rhysb’s last post, the --chips-box-shadow is meant to be --chip-box-shadow. There is no ‘S’ after chip.
I have an air purifier that has 3 preset speeds and wanted a button card to set those instead of the percentage slider of the fan card. Here’s the code incase anyone wants it
ezgif-5-3dbe075939
cards:
    entity: fan.andrews_air_purifier
    icon: mdi:fan
    primary: Air Purifier
    secondary: |-
      {% set fanspeed = state_attr(config.entity, 'percentage') %}
      {% if is_state_attr(config.entity, "mode", "auto") %}
        Auto
      {% elif is_state_attr(config.entity, "mode", "sleep") %}
        Sleep
      {% elif fanspeed == 100 %}
        High
      {% elif fanspeed == 66 %}
        Medium
      {% elif fanspeed == 33 %}
        Low
      {% endif %}
    icon_color: green
    card_mod:
      style:
        mushroom-shape-icon$: |
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          ha-icon {
            box-shadow: 0px 0px;
            animation: rotation linear infinite !important;
            {% set fanspeed = state_attr(config.entity, 'percentage') |float %}
              animation-duration: 2s !important;
              animation-duration: 6s !important;
              animation-duration: 0.5s !important;
              animation-duration: 1.5s !important;
              animation-duration: 3s !important;
            {%- else -%}
            animation-duration: ;
            {%- endif %}
          ha-card {
            margin-bottom: -9px;
    cards:
        layout_type: grid
        cards:
            layout: vertical
            primary: Low
            tap_action:
              action: call-service
              service: fan.set_percentage
                percentage: 33
                entity_id: fan.andrews_air_purifier
            view_layout:
              grid-area: button1
            card_mod:
              style: |
                ha-card {
                  height: 44px !important;
                  box-shadow: none;
                  --card-primary-font-weight: normal;
            layout: vertical
            primary: Medium
            tap_action:
                percentage: 66
            view_layout:
              grid-area: button2
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            layout: vertical
            primary: High
            tap_action:
                percentage: 100
            view_layout:
              grid-area: button3
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            layout: vertical
            icon: mdi:fan-auto
            icon_color: white
            tap_action:
              service: fan.set_preset_mode
                preset_mode: auto
            double_tap_action:
                preset_mode: sleep
            view_layout:
              grid-area: button4
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                mushroom-shape-icon {
                  --shape-color: none !important;
                  --icon-symbol-size: 20px;
        layout:
          grid-template-columns: 29% 29% 29% 13%
          grid-template-rows: auto
          grid-template-areas: |
            "button1 button2 button3 button4"
card_mod:
  style: |
    ha-card {
      {% if is_state('fan.andrews_air_purifier', 'on') %}
          background: rgba(101,170,91,0.1);
      {% endif %}
Many thanks for this important note. Maybe it’s because I’m running 2022.11.0b0, but when selecting the chip card in a standard view without any theme, I get this:
Super-awkward rookie mistake: forgot to clear cache. Shouldn’t have updated at 2 AM.
We have an iPad in the basement, primarily for guest use to control just that area. This is still a WIP, but I was able to fill my iPad screen perfectly. I used a custom grid layout card, defined below. The playlists on the right are displayed when nothing is playing, and that section is swipeable to view more. When Spotify is playing, it shows the current track and speaker volume controls.
max_cols: 6
grid-template-columns: 16% 16% 32% 36%
grid-template-rows: 16.7% 16.7% 16.7% 16.7% 16.7%
  "info info light-1 climate"
  "info info light-2 spotify"
  "info info light-3 spotify"
  "button-1 button-2 light-4 spotify"
  "button-3 button-4 light-5 volume-1"
  "button-5 button-6 master volume-2"
justify-items: stretch
height: calc(100vh - 5px);
card_margin: 0
Has anyone added icons or custom buttons to light cards? Several of the lights in our home have timers (automations to turn off the light after X minutes), to avoid lights being left on. I’d love an elegant way to toggle the timer automation from the light card. Maybe using the existing button style on the card for swapping between color/temp/brightness, or adding a tappable icon like the attached example. It needs to have a way to tell if the timer is on or off; in this case the icon would be a color when on, or disabled when off.
Screen Shot 2022-10-26 at 5.18.31 PM
