Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Yep, added one for you.
You can do it like this:
type: custom:mushroom-chips-card
chips:
  - type: conditional
    conditions:
      - entity: sensor.lounge_sensor_temperature
        state_not: 'null'
    chip:
      type: entity
If you want to use the original aspect ratio, you can do it like this:
type: custom:mushroom-template-card
picture: /local/formula1/flags/United_Arab_Emirates.jpg
primary: ABU DHABI GRAND PRIX 2022
secondary: 18 NOV 2022 - 20 NOV 2022
layout: vertical
card_mod:
  style:
    mushroom-shape-avatar$: |
      .picture {
        height: auto !important;
      ha-card {
        font-family: "Formula1-regular";
        --card-primary-font-size: 16px;
        --card-secondary-font-size: 12px;
      :host {
        --mush-icon-border-radius: 6px;
A work in progress with Netflix/FireTV-AndroidTV page. It will include :
  • A live view of AndroidTV screen
  • Fast remote control
  • Start Netlix shows
  • Tv Usage statistics
  • App starting buttons
  • Alexa integration of non amazon store contents
  • Bypass netflix auth. screen and start show directly
  • tv and all other IR controls can be made from the page
This is a work in progress and wiki page will be ready soon.
Thanks for adding the correct Yaml code!
So I created something similar, without changing your config and when I look at my mobile…I don’t have the issue you’re experiencing :thinking:
The only change I’ve made, is that I use the vertical-stack-in-card instead.
Someone who can help to make the slider less in height?
Any advise?
I have 2 side by side in one column in the mobile screen. I think your screenshot is just 1 over the full screen, not?
p.s. strange that you have this bar behind the icons.
Hi, can you explain how create all sensors? thank you
I just took a screenshot of my mobile phone screen.
I don’t have a dashboard made for mobile or whatsoever. I took only your config, changed stack-in-card to vertical-stack-in-card and amended the sensors to my personal sensors. That’s it :man_shrugging:
I absolut love this! You have helped me so much and it looks so great. There is just one thing I can’t figure out. I want to have a background color in the card and also animate the Icon. I got both working separately, but I can’t figure out how to get both at the same time.
primary: '{{ state_attr(''binary_sensor.warning_blaubeuren_stadt_1'',''headline'') }}'
secondary: '{{ state_attr(''binary_sensor.warning_blaubeuren_stadt_1'',''description'') }}'
icon: mdi:alert-circle
entity: binary_sensor.warning_blaubeuren_stadt_1
multiline_secondary: true
icon_color: white
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        --shape-animation: ping 1.5s infinite, blink 1.5s ease-in-out infinite;;
      @keyframes ping {
      0% { box-shadow: 0 0 0 0 rgba(var(--rgb-white), 0.7); }
      100% { box-shadow: 0 0 5px 15px transparent; }
      @keyframes blink {
      100% {opacity: 0;}
  mushroom-state-info$: |
      {% if (states.binary_sensor.warning_blaubeuren_stadt_1.attributes.severity=='Severe')%}
        ha-card {
          background: red;
          --primary-text-color: AliceBlue;
          --secondary-text-color: white
      {% endif %}
This is my current try. Some help would be greatly appreciated
Try something like this:
primary: '{{ state_attr(entity, ''headline'') }}'
secondary: '{{ state_attr(entity, ''description'') }}'
icon_color: white
card_mod:
  style:
      .shape {
      @keyframes ping {
      @keyframes blink {
        100% {opacity: 0;}
      ha-card {
        {% if state_attr(config.entity, 'severity') == 'Severe') %}
          background: red;
        {% endif %}
Nice man & can you share code pleas ?
Thank you so much! It worked perfectly.
Looking at the new state home proposed default layout, I loved the nav bar at the bottom of the screen for easier navigation.
Any idea on how to approach a static nav bar at the bottom of the screen? Especially useful for quick and easy mobile navigation? Can it be done with this theme or is that a larger HACS integration needed?
it is not finished yet. I will when its complete.
Greetings to you all. I have been to figure out how to make this card work.
20220502_132702
with my netatmo climate ratiators, but no luck i get no blinking ratiator icon.
here is my template code, what am i doing wrong here? thanks in advanced.
- type: template
        entity: climate.living_room
        content_info: none
        use_light_color: false
        card_mod: null
        icon: |2-
              {% if is_state_attr("climate.living_room", "hvac_action", "heating") %}
                red
              {% if state=='heating' %}
                mdi:radiator
              {% elif state=='idle' %}
               mdi:radiator-disabled
              {% endif %}
        icon_color: |2-
              red
              black
              {% endif %}
        style: |
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          ha-card {
            box-shadow: 0px 0px;
            animation: rotation linear infinite;
            {% if states('climate.living_room') == 'heating' %}
             animation-duration: 3s;
            {%- else -%}
            {%- endif %}
            template
    alignment: center
Its possible to create something similar but its limited to your dashboard and in order for the bar to stick to the bottom screen the dashboard page needs to be longer than what’s visible (ie. scrollable)
Sticky Nav Bar
type: custom:vertical-stack-in-card
horizontal: true
cards:
    primary: Home
    icon: mdi:home
    tap_action:
      action: navigate
      navigation_path: home
    layout: vertical
    card_mod:
      style:
          .shape {
            width: 66px !important;
            height: 36px !important;
          ha-card {
            background: none;
          :host {
            --mush-icon-border-radius: 16px;
    primary: Media
    icon: mdi:play-box-multiple-outline
    layout: vertical
    card_mod:
      style:
          .shape {
            --shape-color: none;
          ha-card {
            background: none;
          :host {
    primary: Energy
    icon: mdi:lightning-bolt-outline
    layout: vertical
    card_mod:
      style:
          .shape {
          ha-card {
            background: none;
          :host {
    primary: Map
    icon: mdi:map-outline
    layout: vertical
    card_mod:
      style:
          .shape {
          ha-card {
            background: none;
          :host {
card_mod:
  style: |
    :host {
      z-index: 999;
      position: sticky;
      position: -webkit-sticky;
      bottom: 0;
    ha-card {
      background: rgb(30,30,30);
      padding-bottom: 15px;
      margin: 0px -8px -10px -8px;
      border-radius: 0px;
Thank you.
I have this media player card with buttons to select radio stations, everything works great.
How can I set the volume to 10% when I press one of the buttons?
square: false
columns: 1
type: grid
cards:
  - type: custom:vertical-stack-in-card
    cards:
      - type: grid
        square: false
        columns: 1
        cards:
          - type: custom:mushroom-media-player-card
            entity: media_player.living_room
            use_media_info: true
            media_controls:
              - play_pause_stop
              - previous
              - next
            collapsible_controls: true
            volume_controls:
              - volume_set
            show_volume_level: false
            fill_container: false
            icon: mdi:music
            card_mod:
              style: |
                ha-card {
                  {% if not is_state(config.entity, 'off') %}
                    background-image: url( '{{ state_attr( config.entity, "entity_picture" ) }}' );
                    background-position: center;
                    background-repeat: no-repeat;
                    background-size: cover;
                    position: relative;
                    background-blend-mode: overlay;
                    background-color: rgba(var(--rgb-card-background-color),0.5);
                  {% endif %}
                  #--icon-symbol-size: 32px;
                  #--icon-size: 64px;
      - type: grid
        square: false
        columns: 4
        cards:
            primary: Topradio
            secondary: ''
            icon: mdi:music
            tap_action:
              action: call-service
              service: media_player.select_source
                source: TOPradio
                device_id: f68de1583e7b807342d53504d0dbe200
            layout: vertical
            hold_action:
              action: none
            double_tap_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  --icon-size: 64px;
            primary: MNM
            secondary: ''
            icon: mdi:music
            tap_action:
                source: VRT MNM
            layout: vertical
            hold_action:
              action: none
            double_tap_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  --icon-size: 64px;
Kind regards
Kurt
