Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
@rhysb Hi, love your work! Do you think is it possible to animate a badge icon? (for exemple for a blinking battery alert). Thanks in advance.
please share your configuration!!!
Can someone kindly help me with reducing the white space at the bottom of my card? It appears to be caused by a before pseudo element - setting a padding-bottom of 184.5px - which is a child of div#root in the grid card. Am i able to mod the CSS? I’ve tried without success.
My card yaml is:
type: custom:stack-in-card
cards:
  - type: custom:mushroom-title-card
    title: Media
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-media-player-card
        entity: media_player.bedroom_currently_playing
        icon: mdi:play
        use_media_info: true
        use_media_artwork: false
        show_volume_level: false
        media_controls:
          - play_pause_stop
          - previous
          - next
        volume_controls:
          - volume_buttons
          - volume_set
        fill_container: false
        card_mod:
          style: |
            mushroom-shape-icon {
              {% set media_type = state_attr(config.entity, 'media_content_type') %}
              --card-mod-icon:
              {% if media_type == 'tvshow' %}
                mdi:television-classic
              {% elif media_type == 'movie' %}
                mdi:movie-open
              {% elif media_type == 'music' %}
                mdi:music
              {% elif media_type == 'playlist' %}
                mdi:music
              {% else %}
                mdi:play
              {% endif %};
    card_mod:
      style: |
        ha-card {
          {% if not is_state('media_player.bedroom_currently_playing', 'off') and not is_state('media_player.bedroom_currently_playing', 'idle') %}
            background: url( '{{ state_attr("media_player.bedroom_currently_playing", "entity_picture") }}' ), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 50%);
            {% if state_attr('media_player.bedroom_currently_playing', 'media_content_type') == 'tvshow' %}
              background-size: auto 100%, cover;
            {% else %}
              background-size: 50% auto, cover;
            {% endif %}
            background-position: right;
            background-repeat: no-repeat;
            background-blend-mode: saturation;
          {% endif %}
  - square: true
    columns: 2
    type: grid
    cards:
        icon: phu:nvidia-shield
        entity: switch.bedroom_hub_tv
        tap_action:
          action: toggle
        icon_color: '{{ "green" if is_state(entity, "on") else "disabled" }}'
        layout: vertical
        icon: phu:firetv
        entity: switch.bedroom_hub_fire_tv
        tap_action:
          action: toggle
        layout: vertical
Thanks in advance for any assistance
Is it possible to centre the chip in the middle?
Code:
type: custom:mushroom-chips-card
chips:
  - type: template
    content: '{{ now().strftime(''%H:%M %a, %d %b'') }}'
  - type: light
    entity: light.living_all_lights
    content_info: none
    use_light_color: true
    tap_action:
      action: toggle
  - type: template
    content: '{{ states(''sensor.outdoor_temperature}} °C'
    show_conditions: true
    show_temperature: true
    tap_action:
      action: navigate
      navigation_path: weather
alignment: justify
Hi, there are options (margin, outer_padding) for the stack-in-card i think:
  mode: horizontal
  keep:
    box_shadow: true/false
    margin: true/false
    border_radius: true/false
    background: true/false
    outer_padding: true/false
A little messy but here are my chips :slight_smile:
chips:
  - type: template
    icon: mdi:thermometer
    content: >-
      {{states('sensor.temperatur_lavest')|int}}-{{states('sensor.temperatur_hoyest')|int}}°
    tap_action:
      action: more-info
    entity: sensor.temperatur_lavest
    hold_action:
      action: more-info
  - type: template
    entity: sensor.fuktighet_lavest
    icon: mdi:water
    icon_color: light-blue
    content: '{{states(entity)| int}}-{{states(''sensor.fuktighet_hoyest'')  | int}}%'
    tap_action:
      action: more-info
    hold_action:
      action: more-info
  - type: template
    entity: sensor.netatmo_innemodul_air_health
    icon: mdi:weather-windy
    icon_color: green
    content: |+
      {% set netatmo=states('sensor.netatmo_innemodul_air_health') %}
      {% set p1=states('sensor.p1_air_health') %}
      {% if netatmo == 'Farlig' or p1 == 'Farlig' %}
      Farlig
      {% elif netatmo == 'Veldig Dårlig' or p1 == 'Veldig Dårlig'  %}
      Veldig Dårlig
      {% elif netatmo ==  'Dårlig' or p1 == 'Dårlig' %}
      Dårlig
      {% elif netatmo == 'Ok' or p1 == 'Ok'  %}
      Ok
      {% elif netatmo == 'Bra' or p1 == 'Bra'  %}
      Bra
      {% elif netatmo == 'Utmerket' or p1 == 'Utmerket'  %}
      Utmerket
      {% else %}
      error
      {% endif %}
    double_tap_action:
      action: none
    tap_action:
      action: more-info
    hold_action:
      action: more-info
  - type: template
    entity: sensor.eva_meter_reader_smartenergymetering
    icon: mdi:lightning-bolt
    icon_color: '{{''orange'' if ((states(entity)|int) > 3000) else ''amber'' }}'
    content: '{{states(entity)}} W'
    tap_action:
      action: navigate
      navigation_path: /lovelace/strom
    hold_action:
      action: navigate
  - type: conditional
    conditions:
      - entity: sensor.current_lights_on
        state_not: '0'
    chip:
      type: template
      icon: >-
        {{ "mdi:lightbulb-group" if states(entity) | int > 1 else
        "mdi:lightbulb" }}
      double_tap_action:
        action: none
      icon_color: amber
      tap_action:
        action: more-info
      hold_action:
        action: more-info
      card_mod:
        style: |
          ha-card:after {
            content: "{{ states('sensor.current_lights_on') }}";
            position: absolute;
            display: flex;
            justify-content: center;
            align-items: center;
            background: rgb(var(--rgb-orange));
            color: var(--card-background-color);
            font-weight: bolder;
            border-radius: 50%;
            top: -5px;
            right: -5px;
            width: 16px;
            height: 16px;
            font-size: 11px;
  - type: conditional
    conditions:
      - entity: sensor.current_speakers_playing
        state_not: '0'
    chip:
      type: template
      icon: '{{ state_attr(entity, ''icon'') }}'
      icon_color: teal
      tap_action:
        action: more-info
      hold_action:
        action: more-info
      card_mod:
        style: |
          ha-card:after {
            content: "{{ states('sensor.current_speakers_playing') }}";
            position: absolute;
            display: flex;
            background: rgb(var(--rgb-teal));
            border-radius: 50%;
            top: -5px;
            right: -5px;
            width: 16px;
            height: 16px;
            font-size: 11px;
  - type: conditional
    conditions:
      - entity: switch.varmtvannsbereder
        state: 'off'
    chip:
      type: template
      double_tap_action:
        action: none
      tap_action:
        action: navigate
        navigation_path: /lovelace/varmtvann
      hold_action:
        action: none
      icon: mdi:water-boiler
      icon_color: grey
  - type: conditional
    conditions:
      - entity: binary_sensor.foliestatus
        state: 'on'
    chip:
      type: entity
      entity: sensor.varmefolie_sanntid
      icon: mdi:radiator
      icon_color: orange
      content_info: none
  - type: conditional
    conditions:
      - entity: binary_sensor.contactsensor_inngangspartidor
        state: 'on'
    chip:
      type: entity
      content_info: name
  - type: conditional
    conditions:
      - entity: binary_sensor.contactsensor_stuedor_kontaktsensor
        state: 'on'
    chip:
      type: entity
      content_info: name
  - type: conditional
    conditions:
      - entity: binary_sensor.contactsensor_utebod_kontaktsensor_door
        state: 'on'
    chip:
      type: entity
      content_info: name
  - type: conditional
    conditions:
      - entity: binary_sensor.contactsensor_fryseboks
        state: 'on'
    chip:
      type: template
      double_tap_action:
        action: more-info
      icon: mdi:fridge-alert
      icon_color: red
      content: Fryseboks
      tap_action:
        action: more-info
      hold_action:
        action: more-info
  - type: conditional
    conditions:
      - entity: switch.front_door_live_stream
        state: 'on'
    chip:
      type: template
      icon: mdi:record-rec
      icon_color: red
      tap_action:
        action: toggle
  - type: conditional
    conditions:
      - entity: binary_sensor.leaf_lader
        state: 'on'
    chip:
      type: template
      icon: mdi:car-electric
      icon_color: blue
      tap_action:
        action: navigate
        navigation_path: leaf
alignment: center
Brilliant, works a charm, wish I could get my head round this templating and css.
Change square: true to square: false.
For those triggered by an off-center Chip :grin:, you can center it properly like this.
Mushroom Chip True Center:
chips:
  - type: template
  - type: light
    entity: light.office_light
    content_info: none
    tap_action:
      action: toggle
    card_mod:
      style: |
        ha-card {
          position: absolute;
          left: calc(50% - (var(--chip-height) / 2));
  - type: template
    content: '{{ states(''sensor.weatherflow_feels_like_temperature'')}} °C'
    tap_action:
      action: navigate
alignment: justify
Thanks for the suggestions. I tried them all without success; changing to a custom-layout card did the trick.
Ty. That was it. I didn’t even think to change that.
Yes, you can like this.
Mushroom Badge Animation:
type: custom:mushroom-template-card
primary: Mushroom
icon: mdi:mushroom
icon_color: red
badge_icon: mdi:snail
badge_color: green
card_mod:
  style: |
    mushroom-badge-icon {
      animation: pulse 1s infinite;
    @keyframes pulse {
      50% { opacity: 0;}
Got ispired and made a wind-chip.
wind_chip
It shows the direction and the wind force in beaufort.
Although the outcome of my cut-and-paste code is oké, I doubt whether this is correct.
Could you check?
chips:
  - type: template
    content: ""
    icon: mdi:navigation
    card_mod:
      style: |
        ha-card:after {
          content: "{{ state_attr('sensor.knmi_home_wind', 'beaufort')|round(0) }}";
          position: absolute;
          display: flex;
          background: var(--primary-text-color);
          border-radius: 50%;
          top: -6px;
          right: -6px;
          width: 16px;
          height: 16px;
          font-size: 11px;
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-icon {
        {% set BEARING = state_attr('sensor.knmi_home_wind', 'graden') %}
          transform: rotate({{BEARING}}deg);
Apologies for not taking the time to look, I was hoping someone could quickly tell me how to change the colours for the media card and slider? ie. green when playing, blue when paused, grey when idle/everything else etc.
Working on a new AND FINAL tablet layout, here is the Sonos card broken up to allow Mushy to shine.
Here you go:
Good job :+1:.
The only thing I could suggest is that you could do away with the second card_mod and complex selector to put it in .content like this:
chips:
  - type: template
    card_mod:
      style: |
        ha-card:after {
          content: "{{ states('sensor.weatherflow_beaufort') | round(0) }}";
          position: absolute;
          display: flex;
          border-radius: 50%;
          top: -6px;
          right: -6px;
          width: 16px;
          height: 16px;
          font-size: 11px;
        .content {
          transform: rotate({{ states('sensor.weatherflow_wind_bearing') }}deg);
very nice. What is this card layout called? How did you make the left bar?
Chip Card Help anyone?
Is it possible to add text to a chip card entity?
1
I am using them to display my internet connection and while i have icons, I would like to add text to them.
Is that possible? I have read the threads but unfortunatly I cannot find an answer.
Moin,
you must take a template chip. Here is an example:
      - type: template
        icon_color: blue
        content: |2-
                test
                {{ states('sensor.openweathermap_forecast_precipitation_probability') }}% |  {{
                states('sensor.openweathermap_forecast_precipitation' ) | int }}mm
        icon: mdi:weather-pouring
Greets
Basti
I previously had customized the font size in the Mushroom Light card but after the update to HA 2022.11 it was removed. Now I can’t remember how to do it again and how do I make sure that it is not overwritten again?
