Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Damn didnt know that was possible, thanks!
check:
and opened:
I had the same issue with my TV, ideal volume is between 5-10% and volume buttons of the media card donā€™t show. So I created my own:
It requires 3 scripts that will run if you click one of those buttons, for (un)mute, volume down, and volume up.
Card
type: custom:stack-in-card
cards:
    entity: media_player.dummy_tv_01
    primary: Samsung TV
    secondary: |-
      {% if is_state(entity, 'on') %}
        Aan ā€¢ {{(state_attr(entity,'volume_level')*100) | round()}}%
      {% elif is_state(entity, 'idle') %}
      {% else %}
        Uit
      {% endif %}
    icon: mdi:television
    icon_color: |-
        red
        red
      {% else %}
        disabled
      {% endif %}
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        content: ''
        icon: >-
          {% if state_attr('media_player.dummy_tv_01', 'is_volume_muted') ==
          true %}
            mdi:volume-off
          {% else %}
            mdi:volume-high
          {% endif %}
        tap_action:
          action: call-service
          service: script.samsung_tv_volume_mute
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
      - type: template
        content: ''
        icon: mdi:volume-minus
        tap_action:
          service: script.samsung_tv_volume_down
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
      - type: template
        content: ''
        icon: mdi:volume-plus
        tap_action:
          service: script.samsung_tv_volume_up
        card_mod:
          style: |
            ha-card {
              box-shadow: none;
    alignment: center
    card_mod:
      style: |
        ha-card {
          margin: 0px 12px 12px;
          --chip-border-radius: var(--mush-control-border-radius);
          --chip-height: 42px;
          --chip-padding: 32px;
          --chip-background: rgba(var(--rgb-disabled), 0.15);
          --chip-box-shadow: none;
Script for (un)mute
alias: Samsung TV volume mute
sequence:
  - if:
      - condition: state
        entity_id: media_player.dummy_tv_01
        attribute: is_volume_muted
        state: true
    then:
      - service: media_player.volume_mute
          is_volume_muted: false
    else:
          is_volume_muted: true
mode: single
icon: mdi:volume-mute
Script for volume down
alias: Samsung TV volume down
sequence:
  - if:
      - condition: state
        attribute: volume_level
        state: 0
    then:
      - service: media_player.volume_set
          volume_level: "0"
    else:
          volume_level: >-
            {{state_attr("media_player.dummy_tv_01", "volume_level")|float - 0.01}}
mode: single
Script for volume up
alias: Samsung TV volume up
sequence:
      volume_level: >-
        {{state_attr("media_player.dummy_tv_01", "volume_level")|float + 0.01}}
mode: single
Youā€™ll have to replace all the media_player.dummy_tv_01 with your Sonos speaker. Not sure if other variables are the same with my TV as your speaker, but hope this helps.
Something like this. You can fill in your sensor names in the secondary part and your switch entity.
type: custom:mushroom-template-card
entity: switch.power_plug
primary: Hot Water
secondary: |-
    On ā€¢ {{states('sensor.power_usage')}} W ā€¢ {{states('sensor.some_other_sensor')}} kWh
  {% elif is_state(entity, 'off') %}
    Off
  {% else %}
    Unavailable
  {% endif %}
icon: |-
    mdi:power-plug
    mdi:power-plug-off
  {% else %}
    mdi:power-plug-off
  {% endif %}
icon_color: |-
    amber
    disabled
  {% else %}
    disabled
  {% endif %}
tap_action:
  action: toggle
card_mod:
  style: |
    ha-card {
      {{ 'background: rgba(var(--mush-rgb-amber), 0.2);' if is_state(config.entity, 'on') }}
Thank you! :heart:
Can anyone help point me in the right direction here?
I think Iā€™ve cracked it:
        bar-card-value::before {
          content: " {{ states.sensor.saltlevel_in_percent.state }} % / ";
hi all,
I was looking for a way to change the background color (opacity) of my mushroom card slider without success, Iā€™m quite new to this (code in general, started HA a few weeks ago) and I need a little help with the next step.
First I found ā€“rgb-disabled, this one works in the code below and gives me the option to change the color, but unfortunately not the opacity/transparency.
I used the ā€œinspectā€/ (DOM?) option for the first time to figure out what declaration I need to change and found it: ā€“bgā€“color-inactive. tried changing it in the DOM function of chrome and it does exactly what I want to achieve.
Until now I have been unsuccessful implementing it though. Using DOM I found ā€“bgā€“color-inactive was inherited from mushroom-slider,
so I tried:
style: |
  mushroom-light-brightness-control {
        --slider-color: rgb(255,166,87) !important;
        --slider-bg-color: rgba(255,166,87, 0.8) !important;
        --rgb-disabled: 255,166,87 !important;
  mushroom-slider {
        --bg-color-inactive: rgba(var(--rgb-disabled), 0.8) !important;
  ha-card {
  background: rgba(225,225,225,0);
  border: rgba(225,225,225,0);
this did not work, so i used :host as the declaration is mentioned under :host within mushroom-slider, did not work either:
style: |
  :host {
  ha-card {
Tried it in the light-brightness-control, no luck:
style: |
  ha-card {
Can anybody help me understand what Iā€™m doing wrong? how I can implement the declarations I found using DOM?
Edit: Just had a brain-fart, should I be using card-mod because of the variable?
p.s. I donā€™t know when to use !important so at the moment I just put it everywhere.
Looking Good!!
This is exactly what I was looking for. Thanks for your sharing! :slight_smile:
Can you also share the relevant scripts that you use with this card?
Looking Great!
How did you create this sensor?
Hmm - an issue with 2023.1 I guess since Mushroom Cards version last changed in November. Is the best way to use mapper as suggested, wait and see if this gets fixed or figure out where to log this as a bug?
To change the slider background when active and inactive you need to go a bit deeper, like this:
type: custom:mushroom-light-card
entity: light.office_light
show_brightness_control: true
card_mod:
  style:
    mushroom-light-brightness-control$: |
      mushroom-slider {
        --slider-bg-color: rgba(var(--rgb-state-light), 0.5);
        --bg-color-inactive: rgba(var(--rgb-disabled), 0.5);
If the change has been merged then it will be included in the next update of Mushroom.
In the meantime, if you are wanting to change the default color of the Mushroom Light Card you can add mush-rgb-state-light: var(--rgb-amber-color) to your theme file. If you want to change it for a specific card you can use card_mod like this:
card_mod:
  style: |
    :host {
       --mush-rgb-state-light: var(--rgb-amber-color)
Did you solve this?
I have the same problem on mine and just solved it.
You have to find the fan_modes on you climate entity.
For mine I replaced this:
fan:
                  Auto low:
                    icon: mdi:fan-auto
                  Low:
                    icon: mdi:fan
with this:
fan:
                auto:
                  icon: mdi:fan-auto
                turbo:
                  icon: mdi:fan-speed-3
                high: false
                medium: false
                low:
                  icon: mdi:fan-speed-1
@rhysb could you please give me any tip about editing your Room card? My problem [no2] was described in this post:
https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/4648?u=jaku2k
Blockquote
[ā€¦] 2. I would like to edit Rhysā€™ room card, so that I could switch specific light entities by pressing an icon displayed at the bottom of the card. I am able to add an interactive icon to that card, but it is being displayed at its right side and I would like it to be positioned on the left. When I add ā€œtoogle chipā€ after alignment: end it interferes with those conditional ones, made by the author. @rhysb could you please tell me how could I add such icon? Iā€™m sending an example in the attachment. I would like the toogle icon to be placed in the place of red dot. [ā€¦]
room_detaiils
Best regards,
Jakub
hey man,
may not be a perfect though
cards:
    primary: HA Server
    secondary: 'Uptime: {{ states(''sensor.ha_uptime_phrase'') }}'
    icon: mdi:server-network
    chips:
      - type: template
        entity: sensor.nas_temperature
        icon: mdi:chip
        icon_color: |
          {% if states('sensor.nas_temperature') | float < 0 %}
            blue
          {% elif states('sensor.nas_temperature') | float < 5 %}
            white
          {% elif states('sensor.nas_temperature') | float < 10 %}
            green
          {% elif states('sensor.nas_temperature') | float > 10 %}
            yellow
          {% elif states('sensor.nas_temperature') | float > 25 %}
            orange
          {% elif states('sensor.nas_temperature') | float >  30 %}
            red
          {% else %}
            green
          {% endif %}
    alignment: end
Thanks for the example. I have my NAS card sorted now and Iā€™m trying to use the same logic for a UPS card but the icon is not getting any colour at all and I canā€™t see what Iā€™ve done wrongā€¦
code for the first chip
    chips:
      - type: template
        entity: sensor.ups_input_voltage
        content: 'Input: {{ states(entity) }} V'
        icon: mdi:power
        icon_color: |
          {% if states('sensor.ups_input_voltage') | int < 230 %}
            red
          {% if states('sensor.ups_input_voltage') | int < 235 %}
            orange
          {% elif states('sensor.ups_input_voltage') | int > 235 %}
            green
          {% elif states('sensor.ups_input_voltage') | int > 242 %}
            red
          {% else %}
            red
          {% endif %}
You have two ifā€™s. Should be:
            red
          {% elif states('sensor.ups_input_voltage') | int < 235 %}
            orange
            green
            red
          {% else %}
            red
          {% endif %}
Oops! Good old copy/paste error. Thanks!
Hey Jakub, you could do that like this.
Mushroom Room Card with Light Toggle:
Mushroom Room Card with Light Toggle YAML
cards:
    primary: Lounge
    secondary: '{{ states("sensor.lounge_sensor_temperature") | round(0) }} Ā°C'
    icon: mdi:sofa
    entity: light.lounge_light
    tap_action:
      action: navigate
      navigation_path: lounge
    hold_action:
      action: toggle
    icon_color: '{{ ''red'' if is_state(entity, ''on'') }}'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
          --ha-card-border-width: 0;
    chips:
      - type: light
        entity: light.pipe_man
        content_info: none
        card_mod:
          style: |
            ha-card {
              position: absolute;
              left: 0px;
      - type: conditional
        conditions:
          - entity: binary_sensor.lounge_motion_occupancy
            state: 'on'
        chip:
          type: template
          icon_color: disabled
          icon: mdi:motion-sensor
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: media_player.lounge_tv
            state_not: 'off'
            state_not: idle
            state_not: unavailable
        chip:
          type: template
          icon: |-
            {% set media_type = state_attr(config.entity,
            'media_content_type') %}
            {% if media_type == 'tvshow' %}
              mdi:television-classic
            {% elif media_type == 'movie' %}
              mdi:movie-roll
            {% elif media_type == 'music' %}
              mdi:music
            {% elif media_type == 'playlist' %}
              mdi:music
            {% else %}
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              ha-card {
                {% set media_type = state_attr(config.entity, 'media_content_type') %}
                  animation: flicker 1s linear infinite alternate;
                  animation: spin 2s linear infinite reverse;
                  animation: beat 1.3s ease-out infinite both;
                {% else %}
                {% endif %}
              @keyframes spin {
                100% { transform: rotate(360deg); }
              @keyframes flicker {
                0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { opacity: 1; }
                32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { opacity: 0.6; }
              @keyframes beat {
                0% { transform: scale(1); }
                10% { transform: scale(1.1); }
                17% { transform: scale(1.05); }
                33% { transform: scale(1.25); }
                60% { transform: scale(1); }
      - type: conditional
        conditions:
          - entity: climate.air_conditioner
            state_not: 'off'
        chip:
          type: template
          icon: |-
            {% if is_state(entity, 'heat_cool') %}
              mdi:sync
            {% elif is_state(entity, 'heat') %}
              mdi:fire
            {% elif is_state(entity, 'cool') %}
              mdi:snowflake
            {% elif is_state(entity, 'dry') %}
              mdi:water-percent
            {% elif is_state(entity, 'fan_only') %}
              mdi:fan
            {% else %}
              mdi:air-conditioner
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              ha-card {
                {% if is_state(config.entity, 'heat_cool') %}
                  animation: spin 3s ease-in-out infinite alternate;
                {% elif is_state(config.entity, 'heat') %}
                  animation: heat 2s infinite;
                {% elif is_state(config.entity, 'cool') %}
                  animation: cool 6s ease-in-out infinite;
                {% elif is_state(config.entity, 'dry') %}
                  animation: dry 1.5s linear infinite;
                {% elif is_state(config.entity, 'fan_only') %}
                  animation: spin 1s linear infinite;
                {% else %}
                {% endif %}
              @keyframes spin {
              @keyframes cool {
                0%, 100% { transform: rotate(25deg); }
                25% { transform: rotate(-25deg); }
                50% { transform: rotate(50deg); }
                75% { transform: rotate(-50deg); }
              @keyframes heat {
                50% { opacity: 0.4; }
              @keyframes dry {
                50% { transform: scale(1.2); }
      - type: conditional
        conditions:
          - entity: group.lounge_windows
            state: 'on'
        chip:
          type: template
          icon: mdi:window-open
          tap_action:
            action: none
          hold_action:
            action: none
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-background: none;
          --chip-spacing: 0;
          --chip-border-width: 0;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('light.lounge_light', 'on') %}
        background: rgba(var(--rgb-red-color), 0.1);
      {% endif %}
