Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Yep, 2017 Fire 10s. I can usually snag them dirt cheap on Woot.
I finally resolved it, but Iā€™m still not quite sure WHAT I did that did the trick.
I ended up uninstalling FK, rebooting, sideloading FK via the Fire Toolbox, directing it to the ā€œkioskā€ page on my instance, and then using the other tablet as a reference, slowly reconfigured all of the settings.
Previously, Iā€™d reimported FKā€™s settings (first from the original tablet, then from the ā€œbehavingā€ tablet) and it was still flailing at the cards regardless.
But everything appears to be working now, so I thank you and the others who took the time to respond and try to offer assistance!
sure, my example uses restriction card.
what I am looking for though is a little icon on the icon like with eg a heater
thx, that helps. Could have sworn I tried the action: toggle before, and then it asked for an entityā€¦
though still no lock icon on the badge ofc.
and the icon still shows an actionable handle, and moves when clicking. which is not very intuitive.
Compare that to custom:button-card, where action: none is really dead, no handle no motion.
must check the lock-card which I didnt know just yet, thanks for the link.!
though I now see that is what restriction card is also doing, and not really the tile/mushroom style of thing we need.
to be clear, I am looking for a lock, but then like
SchermĀ­afbeelding 2023-01-25 om 07.45.44
these little top right badges on the entity icon
I tried to adapt this code for my garage door but it isnā€™t working.
    icon_color: >-
      {{ 'red' if states.binary_sensor.paradox_z3_garage_door.state == 'off'
      else 'green' }}
When used in a mushroom cover card I simply get the default icon colours (grey when closed, blue when open) but in a mushroom entity card it completely removes part of the iconā€¦
Any ideas?
Also, in the mushroom entity card the icon does not change between an open or closed garage door but the cover card does. I take it we need to template the icon for the entity card in a similar way to the colour but Iā€™d like to get that bit working first.
not sure if this is causing your issue, but regular jinja rules strongly suggest you to use the below format:
      {{ 'red' if states('binary_sensor.paradox_z3_garage_door') == 'off'
      else 'green' }}
to prevent issues when the state is not known to the system. thereā€™s a warning sign in the jinja docs on this
Thanks for the tipā€¦ Itā€™s still not working though.
      - type: custom:mushroom-cover-card
        entity: cover.garage_door
        icon_color: >-
          {{ 'red' if states('binary_sensor.paradox_z3_garage_door') == 'off' else 'green' }}
Canā€™t see icon_color as an option for the cover card ? Maybe need to use card_mod
https://github.com/piitaya/lovelace-mushroom/blob/b664347715cfaabc16de880617095d6e8e2256df/docs/cards/cover.md
I have this working but only in the template card:
icon_color: "{{ is_state('person.xxxxxx', 'home') | iif('green', 'red') }}"
We have been discussing template card. I started suing template card more and more bc I am fully flexible what to show. Combine multiple entities ā€¦ what not. Requires you become fluent in jinja.
Perhaps something like this.
Mushroom Restriction Card:
type: custom:mod-card
card:
  type: custom:restriction-card
  restrictions:
    confirm:
      text: Do you want to proceed?
  card:
    type: custom:mushroom-entity-card
    entity: switch.coffee_machine
    tap_action:
      action: toggle
card_mod:
  style:
    restriction-card$: |
      ha-icon {
        display: flex;
        position: absolute;
        justify-content: center;
        align-items: center;
        top: 8px;
        left: 40.5px;
        background: rgb(var(--rgb-grey-color));
        color: rgb(var(--rgb-white-color));
        border-radius: 50%;
        --lock-icon-size: 0.9em;
        --lock-opacity: 1;
        width: 17px;
        height: 17px;
Restriction Card was easier to customize, so would recommend sticking with that :grin:.
o yes, that was what I had in mind indeedā€¦ though I would have hoped to leave card-mod/mod-card home when talking about mushroom/tileā€¦
but yes, that Is a very good setup. cool thanks!
we should loop Paul in , and hope he can make this available in core HA Tileā€¦
the badge icon is much bigger here though (because I have the some restriction variables set in my theme already):
    restriction-lock-row-margin-left: calc(100% - 25px) #95%
    restriction-regular-lock-color: red
    restriction-lock-opacity: 0.8
I tried to set it to:
                  --mdc-icon-size: var(--badge-icon-size);
but that is not recognized (I did not set it in my themes, and hoped it would be a system default variable, so I need to set the size to 14px (maybe even 16?)
SchermĀ­afbeelding 2023-01-25 om 11.21.28
its almost there (though the icon itself is a bit too big, and the badge circle seems a tad too tiny:
even on a regular Tile card (sorry if thats not allowed hereā€¦)
for comparison:
  - type: custom:mushroom-climate-card
    entity: climate.heater_library
    show_temperature_control: true
#     hvac_modes:
#       - auto
#     collapsible_controls: true
#     fill_container: false
    layout: horizontal
  - type: tile
    entity: device_tracker.google_home_library
  - type: custom:mod-card
    card:
      restrictions:
        confirm:
      card:
        type: tile
        entity: switch.espresso_keuken
        tap_action:
          action: toggle
    card_mod:
      style:
          ha-icon {
            --mdc-icon-size: 16px;
            display: flex;
            position: absolute;
            top: 8px;
            left: 40px;
            background: red;
            border-radius: 50%;
have to struggle with the var(ā€“lock-icon-size) that is used in Chrome, (where does that come formā€¦) while Safari immediately shows the size Ive set in the modā€¦
There are already some variable for this, --mush-rgb-state-cover-open & --mush-rgb-state-cover-closed. You can use these in card-mod or your theme.
card_mod:
  style: |
    :host {
      --mush-rgb-state-cover-open: var(--rgb-red-color);
      --mush-rgb-state-cover-closed: var(--rgb-green-color);
Itā€™s defined in :host.
 --lock-icon-size: var(--restriction-lock-icon-size, var(--mdc-icon-size, 24px));
So --restriction-lock-icon-size takes precedence over --mdc-icon-size.
For sizing I found it easier to use a Mushroom Template Card with a badge and overlay the lock badge over that with opacity 0.5.
Add some debugging to your Node Red flow to see where the issue is. Your sensor entities should have values like this:
the icon-size variable wont work in my mods unfortunately, and I need to set it via mdc-icon-size.
since this would be a mod to use throughout the config, I made a decluttering-template out of it:
card_mod:
  style:
      ha-icon {
        display: flex;
        position: absolute;
        top: 8px;
        left: 40px;
        background: blue;
        border-radius: 50%;
card:
  restrictions:
    confirm:
  card:
    type: '[[type]]'
    entity: '[[entity]]'
    tap_action:
      action: toggle
and used it like:
  - type: custom:decluttering-card
    template: badge_mod
    variables:
      - type: 'custom:mushroom-entity-card'
      - entity: switch.espresso_keuken
but look what happens:
the mod is not applied at allā€¦ same happening on a core tile card.
another reason for Paul to make this into core :wink:
uhm, please elaborateā€¦?
    primary: >
      {{state_attr(entity,'friendly_name')}}
    secondary: >
      {{states(entity)|title}}
# card does not default to the icon attribute if the set entity, so this requires yet another template
    icon: >
      mdi:{{iif(is_state(entity,'on'),'coffee','coffee-off')}}
    badge_icon: mdi:lock
    badge_color: red
shows the badge on the perfect spot indeed, and nicely margined and padded, just like it should.
but now how to get the active lock there?
SchermĀ­afbeelding 2023-01-25 om 13.02.52
btw, template state does not translateā€¦ always an issue somewhereā€¦
and for complete disclosure, I managed to get some of the restriction card variables in the styling:
          card_mod:
            style:
                ha-card {
                  --restriction-lock-icon-size: 14px;
                  --restriction-regular-lock-color: rgb(var(--rgb-white-color));
                  --restriction-success-lock-color: green;
                  --restriction-lock-opacity: 0.8
                  /*--restriction-lock-row-margin-left: 40px;*/
                  /*--restriction-lock-row-margin-top: 0px;*/
                ha-icon {
                  display: flex;
                  position: absolute;
                  top: 8px;
                  left: 40px;
                  background: red;
                  border-radius: 50%;
Hi all. Slowly changing over to mushroom cards, they look great. I have one card that currently changes the name through a template sensor. Is it possible to do this with the mushroom entity card?
Example of what I currently use:
    if (states['binary_sensor.home_assistant_versions_update_available'].state === 'off') return "Current";
    else return "Updates";
Itā€™s possible using the Template card! When migrating to Mushroom cards, I started using Entity cards but soon switched to template cards which are far more versatile. See the example below, where I show different icons based on an attribute.
{% if state_attr(entity, 'changePercent') > 0 %}mdi:arrow-up{% elif state_attr(entity, 'changePercent') == 0 %}mdi:arrow-right{% else %}mdi:arrow-down{% endif %}
There is a mushroom update card :
type: custom:mushroom-update-card
entity: update.home_assistant_core_update
had another check on my earlier effort for the decluttering card, and noticed now I made a small but sgnificant mistake:
card:
  card_mod:
    style:
        ha-card {
        ha-icon {
          display: flex;
          position: absolute;
          top: 8px;
          left: 40px;
          background: red;
          border-radius: 50%;
  card:
    restrictions:
      confirm:
    card:
      type: '[[type]]'
      tap_action:
        action: toggle
does the trick.
always open the decluttering cards with a
card:
  type:
allowing this to be used like:
          template: badge_mod
          variables:
and with some more tinkering:
card:
  type: custom:config-template-card
  entities:
    - '[[entity]]'
  variables:
    id: states[ '[[entity]]' ].attributes.friendly_name
  card:
    card_mod:
      style:
          ha-card {
          ha-icon {
            display: flex;
            position: absolute;
            top: 8px;
            left: 40px;
            background: red;
            border-radius: 50%;
    card:
      restrictions:
        confirm:
          text: ${'Wil je ' + id + ' schakelen?'}
      card:
        type: '[[type]]'
        tap_action:
          action: toggle
we get a nice confirmation message based on the attribute selected to our liking
          template: badge_mod
          variables:
            - type: tile #'custom:mushroom-entity-card'
note I moved the conformation itself to the cinfig-template-card, because a decluttering-card by itself can Not evaluate templates.
Here the screenshot, after clicking on the volume button:
(I donā€™t use node-red)
EDIT:
find!
that was:
          ha-card {
            --ha-card-border-width: 0;
            --rgb-state-media-player: var(--album-art-color);  ## THIS ONE
            --control-icon-size: 32px;
            background-color: transparent;
            margin-top: 172px;
For the vol+ and vol-, i donā€™t know, maybe itā€™s a media_player limitation ?
