what is the right way of adding these so they arenāt clobbered with subsequent mushroom updates? Is it just to fork the theme into my own custom theme file? If so, wonāt that risk later missing updates in the main mushroom theme file?
Dropped your custom yaml into my dashboard not expecting it to work given we donāt have the same entities, etc. However, I have found this a good way to get started using someone elseās card to them customize from there.
However, the display of the card is broken and Iām trying to figure out what it isā¦ Itās not just the missing backgrounds (I obviously donāt have those) because the template code is showing in the frontend. Any ideas whatās wrong? I have the dependencies, including card mod installed afaik and other mushroom cards work.
The template is showing because you havenāt change the entity names in the yaml to use the ones you have. As soon as you do that, the values will appear and it will work except the pictures until you replace them.
Open the card up and change the yaml and you will be good to go, and just remove any template entities you dont need
Hi, all.
I need your help.
My code consist of 2 entities: climate.valvola_camera_da_letto and binary_sensor.finestra_camera
square: false
columns: 2
type: grid
cards:
- type: custom:mushroom-climate-card
entity: climate.valvola_camera_da_letto
collapsible_controls: false
show_temperature_control: true
hvac_modes:
- auto
layout: null
card_mod: null
style: |
ha-card {
margin-right: -250px;
- type: custom:mushroom-entity-card
entity: binary_sensor.finestra_camera
fill_container: false
primary_info: none
secondary_info: none
layout: null
card_mod: null
style: |
ha-card {
margin-right: 170px;
I would like to move the window icon to the right.
Itās possible?
Thanks in advance.
Hello
Looks great Itās my turn to design my cards and I would like to know how you did it with the light entities. Guess they are not chips but the normal icons, right?
Can you share the code? Would be cool.
Thanks.
The buttons in the photo are part of de default area cards.
Iād like to use a title-card where I could toggle an entity when title_tap_action but I canāt get it work as I donāt know where to place the entity.
When I run the code below, it says no entity was given.
Could someone confirm itās possible as I see the tap_action in the title card?
type: custom:mushroom-title-card
title: Etage
title_tap_action:
action: toggle
entity: light.etage
Iām trying to get a more compact set of cards to ideally have all my rooms on the main dashboard to reduce the amount of dashboard/view flipping I have to do.
As part of this, Iām trying to get a card working based on some previous examples and am getting close:
this is the yaml:
- type: custom:vertical-stack-in-card
cards:
- type: horizontal-stack
cards:
primary: ''
secondary: ''
icon: mdi:silverware-fork-knife
icon_color: blue
icon: ''
icon_color: ''
primary: Kitchen
secondary: >-
states('sensor.kitchen_sink_leak_sensor_temperature')|float|round(0)
+ 3 }} {{
state_attr('sensor.kitchen_sink_leak_sensor_temperature',
"unit_of_measurement") }}
layout: horizontal
- type: custom:mushroom-chips-card
chips:
- type: template
entity: switch.decent_espresso
icon: mdi:coffee-maker
icon_color: |-
{% if states(entity) == 'on' %}
amber
{% else %}
disabled
{% endif %}
tap_action:
action: toggle
- type: template
icon_color: |-
amber
{% else %}
disabled
{% endif %}
tap_action:
action: toggle
alignment: left
card_mod:
style: |
ha-card {
margin: 10px 24px 10px 10px;
--chip-background:
{% if states('switch.decent_espresso') == 'on' %}
rgba(var(--rgb-amber), 0.2);
{% else %}
rgba(var(--rgb-disabled), 0.15);
{% endif %}
--chip-box-shadow: none;
--chip-border-radius: 25px;
--chip-height: 42px;
--chip-padding: 10px;
What Iād love to do is get the room label and temp more left aligned like this:
Iām goign out of my mind figuring out what to change in the CSS. Any tips looking at the YAML iāve provided above?
Hi there,
is there a easy way for custom:mushroom-chips-cardt o change the color of an icon depending on the temperature range?
e.g.
< 2Ā°C , dark blue;
2Ā°C to 10Ā°C, light blue
10Ā°C to 25Ā°C orange;
>25Ā°C red
cards:
chips:
- type: menu
- type: entity
entity: sensor.1w_ds2438t
icon_color: orange
- type: entity
entity: sensor.1w_ds2438h
icon_color: indigo
Hi there,
Iāve seen a similar example to the YAML below, but mine does not appear to be working. Anyone have any idea? I have a Blink camera system and trying to use the Mushroom alarm card to arm/disarm based on current state.
Nothing happens when I tap.
cards:
- type: custom:mushroom-alarm-control-panel-card
entity: alarm_control_panel.blink_home
tap_action:
action: call-serivce
service: >
if (alarm_control_panel.blink_home == 'disarmed')
return 'alarm_control_panel.alarm_arm_away';
else
return 'alarm_control_palnel.alarm_disarm';
service_data:
entity_id: alarm_control_panel.blink_home
you would need to use a template chip
Something like this might provide you enough info to go in the right direction. Notice itās a template card:
chips:
- type: template
content: >-
{{ states(entity) | float }} {{ state_attr(entity,
entity: sensor.house_main_temperature
icon: mdi:thermometer
tap_action:
action: more-info
icon_color: |-
{% set state=states(entity)|float(0) %}
{% if state >= 75 %}
red
{% elif state >= 69 %}
orange
{% elif state < 69 %}
blue
{% else %}
grey
{% endif %}
Can this be done with the slider being just to the right instead of below?
e.g. how the light card layout can be set in horizontal?
Yes, like this:
type: custom:stack-in-card
mode: horizontal
cards:
entity: input_number.rhys_pc_volume
icon: |
{% set vol_level = states(entity) | float %}
{% if vol_level == 0 %}
mdi:volume-mute
{% elif vol_level > 0.66 %}
mdi:volume-high
{% elif vol_level < 0.33 %}
mdi:volume-low
{% else %}
mdi:volume-medium
{% endif %}
icon_color: indigo
primary: Volume
secondary: |
{{ ( states(entity) | float * 100 ) | round | int }}%
- type: custom:my-slider
radius: 12px
height: 42px
mainSliderColor: rgb(var(--mush-rgb-indigo))
secondarySliderColor: rgba(var(--mush-rgb-indigo), 0.2)
mainSliderColorOff: rgb(var(--mush-rgb-disabled))
secondarySliderColorOff: rgba(var(--mush-rgb-disabled), 0.2)
thumbHorizontalPadding: 0px
thumbVerticalPadding: 0px
thumbWidth: 0px
card_mod:
style: |
ha-card {
padding: 12px 12px 12px 6px;
#--mush-rgb-disabled: 189,189,189;
#--mush-rgb-indigo: 63, 81, 181;
Looks like the mushroom-alarm-control-panel-card does not support the templating. Just wrote a script instead.
lias: Arm or Disarm Blink
sequence:
- condition: state
state: disarmed
- service: alarm_control_panel.alarm_arm_away
data: {}
mode: single
icon: mdi:camera
any chance of the code?
Yer check the replies Iāve posted it in there.
can you share your code
Hi all,
thanks for the very good exampe, that helps me!
