Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
You can using --mush-rgb-state-media-player, like this:
  - type: custom:mushroom-media-player-card
    entity: media_player.currently_playing
    icon_type: none
    primary_info: none
    secondary_info: none
    volume_controls:
      - volume_set
    card_mod:
      style: |
        :host {
          --mush-rgb-state-media-player: var(--rgb-green);
Have a look here:
Sure.
type: vertical-stack
cards:
  - type: custom:mushroom-title-card
    title: Theatre
  - type: custom:stack-in-card
    mode: horizontal
    cards:
        primary: Projector
        secondary: >-
          {{ states((entity)) | title }} {% if is_state_attr((entity),
          'current_activity', 'PowerOff') %} {% else %}
            - {{ state_attr((entity), 'current_activity') | replace('4K','') }}
          {% endif %}
        icon: mdi:television
        icon_color: '{{ ''disabled'' if is_state((entity), ''off'') else ''blue'' }}'
        entity: remote.theatre_room
        card_mod:
          style: |
            ha-card:active {
              background: rgba(var(--rgb-disabled), 0.1);
              transform: scale(0.985);
              transition: 0s;
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: switch.theatre_room_apple_tv_4k
            icon_color: green
            icon: mdi:apple
            content_info: none
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
                  --chip-background: rgba(var({{ '--rgb-green' if is_state(config.entity, 'on') else '--rgb-primary-text-color' }}), 0.1);
                  --icon-color: rgb(var(--rgb-white));
          - type: entity
            entity: switch.theatre_room_ben_pc
            icon_color: green
            icon: mdi:face-man
            content_info: none
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
          - type: entity
            entity: switch.theatre_room_boys_pc
            icon_color: green
            icon: mdi:one-up
            content_info: none
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
          - type: entity
            entity: switch.theatre_room_cast
            icon_color: green
            icon: mdi:cast
            content_info: none
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
        card_mod:
          style: |
            ha-card {
                --chip-box-shadow: none;
                top: 16px;
                width: -webkit-fill-available;
                right: 12px;
                position: absolute;
            .chip-container {
                right: 0px;
                position: absolute;
  - type: vertical-stack
    cards:
      - type: conditional
        conditions:
          - entity: sensor.theatre_activity
            state: Apple TV 4K
          - entity: remote.theatre
            state_not: idle
        card:
          type: custom:mini-media-player
          icon: mdi:apple
          artwork: cover
          source: icon
          info: scroll
          hide:
            icon: true
            power: true
            volume: true
            source: true
          entity: media_player.theatre
      - type: conditional
        conditions:
          - entity: remote.theatre_room
            state: 'on'
        card:
          mode: horizontal
          cards:
              primary: Volume
              secondary: '{{ (state_attr(entity, ''volume_level'') * 100) | round(0) }}%'
              icon: mdi:volume-high
              entity: media_player.marantz_sr5013
              icon_color: blue
              card_mod:
                style:
                  mushroom-shape-icon$: |
                    .shape {
                      background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ (state_attr(config.entity, 'volume_level') |  float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
                    .shape:after {
                      content: "";
                      height: 100%;
                      width: 100%;
                      position: absolute;
                      border-radius: var(--icon-border-radius);
                      background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
              icon_type: none
              primary_info: none
              icon_color: blue
              volume_controls:
                - volume_set
              card_mod:
                style: |
                  :host {
                    --mush-rgb-state-media-player: var(--rgb-{{ config.icon_color }});
hi, is it possible to use mdi:icon as shown by the arrow? (secondary info)
Fantastic!
I use that in a group, but when only dimmable lights are on it shows a white color.
Can you make it show yellow then instead?
Thanks so much for your help
Hi all!
I really want to remove the shadow on the sides of the chips. I have accomplished it with every card, exept op the chips. I use this code, can someone tell me what I do wrong?
style: |
  ha-card {
    box-shadow: none;
    border: solid 0px rgba(100,100,100,0.3);
    font-family: Arial, Helvetica, sans-serif
Is there a way to overwrite what is called when pushing the ā€œplayā€-button of a vacuum card?
I would like to call a script instead.
you can use template card and build buttons for everything you want, including ā€œPlayā€ with a sript
must have missed this somewhere above, but creating domain counters, I noticed that
{{states.air_quality|count}}'
whihc I dont have, but shows a fine 0 in dev tools:
results in an empty mushroom secondary line:
        layout: vertical
        primary: Air quality
        secondary: '{{states.air_quality|count}}'
        icon: mdi:air-filter
also, what would be the reason the var(ā€“primary-color)mis not supported ?
      - primary: Air quality
        <<: &mushroom_template
          type: custom:mushroom-template-card
          icon_color: var(--primary-color)
          fill_container: true
          tap_action:
            action: none
          layout: vertical
showing all black icons. Hope not the old color issue introduced some HA version ago?
no desire to have action we can set tap/hold_action to none, but that still shows the handle. so here we go, we need yet another card_mod:
          card_mod:
            style: |
              ha-card {
                pointer-events: none;
maybe I can set the primary-color to the icon too that way?
considering this is a template card, I tried
icon_color: "{{'var(--primary-color)'}}"
but that wont go either, where a plain color name is supported.
nasty bug there
Hello Iā€™ve been formating my mushroom cards with the following properties to get some white transparency and borderless:
    card_mod:
      style: |
        ha-card {
          --ha-card-background: rgba(255,255,255,0.05);
          --ha-card-border-width: 0px;
however this seems to not work my mushroom chips. Is there anything Iā€™m missing?
Hey rhysb,
I tried to make this collabsible when the entity is on or in use
my setup
            entity: sensor.washing_machine_status
            primary: ''
            secondary: |
              {% if is_state(config.entity, 'arbeitet') %}
                Wash
              {% else %}
              {% endif %}
            icon: mdi:washing-machine
            layout: vertical
            icon_color: red
            tap_action:
              action: none
            card_mod:
              style: |
                ha-card {
                  background: var(--card-background-color) !important;
                  box-shadow: var(--ha-card-box-shadow) !important;
                  width: 62px;
                  --spacing: 8px;
                  {{ 'padding-bottom: calc(var(--spacing) * 1.618) !important;' if config.secondary != '' }}
                  border-radius: calc(var(--ha-card-border-radius, 12px) * 2) !important;
                  margin-left: auto;
                  margin-right: auto;
            entity: switch.wohnzimmer_fernsehen
            primary: ''
            secondary: |
              {% if is_state(config.entity, 'on') %}
                TV
              {% else %}
              {% endif %}
            layout: vertical
            icon_color: cyan
            tap_action:
              action: toggle
            card_mod:
              style: |
                ha-card {
                  width: 58px;
                  --spacing: 8px;
                  margin-left: auto;
                  margin-right: auto;
but when entity is not in use it is not fully rounded do you have an idea?
If I want another item to change colour, for example this icon. How do I know which tag I should use? (you used --mush-rgb-state-media-player: var(--rgb-green); for the volume bar)
If I remember correctly, you must add a dot or comma (donā€™t remember which one) after the zero (i.e. the result of your template) in the mushroom secondary info, for a zero to actually show.
Did you try rgb(var(--primary-color))?
Did you figure this out? would like to use this for my RGB hue lights
Just remove the primary: ''. It is causing a padding-bottom to be added. :laughing:
As @ArenaCloser suggested add a , to show the 0:
primary: Air Quality
secondary: '{{ states.air_quality | count }},'
icon-color needs to be an RGB value. Fortunately there is a RGB value for Primary Color that we can use, --rgb-primary-color.
primary: Mushroom
icon: mdi:mushroom
icon_color: var(--rgb-primary-color)
You would need to inspect the CSS in your browser dev tools.
The --mush-rgb-state-media-player variable will change the color for the entire card. If you want to change them separately, then you would need to find the correct selector. For changing the Icon the selector is mushroom-shape-icon and the variable is --rgb-state-media-player:
show_volume_level: false
volume_controls:
  - volume_set
use_media_info: true
card_mod:
  style: |
    mushroom-shape-icon {
      --rgb-state-media-player: var(--rgb-green)
Not yet. Iā€™m not very good at this, so maybe someone can help us :grin:
Thanks!
Will add . Is that a bug btw? It should simply return the templates value .
On the colors: that is too bad really, my themes donā€™t use rgb valuesā€¦ I want to set something like var(ā€”icon-color-off) ā€¦
Maybe I need to add whole set of mushroom variables per themeā€¦ which beats the whole idea of these theme variables in the first place . Duplicating them .
Anyways, thanks for your continued support here , much appreciated
So this is causing my brain to itch. Same media player code but the player inside the stack-in-card seems to have the background set to transparent and I canā€™t work out where to override it.
screen
      - square: false
        columns: 2
        type: grid
        cards:
            cards:
                primary: template
                icon: mdi:new-box
                card_mod:
                  style:
                    mushroom-state-info$: |
                      .primary {
                        font-size: 20px !important;
                        position: absolute;
                        top: 0px;
                        left: 75px;
                        overflow: visible !important;
                        white-space: normal !important;
                      .shape {
                        left: -30px;
                        top: -0px;
                        {% if is_state('switch.template_tv', 'on') %}
                          --shape-color: rgba(var(--rgb-blue), 0.5);
                          --icon-color: rgba(var(--rgb-white), 1);
                        {% elif is_state('light.template_carriage_leds', 'on') %}
                          --shape-color: rgba(var(--rgb-orange), 0.25);
                        {% elif is_state('light.template', 'on') %}
                        {% endif %}
                      :host {
                        --mush-icon-size: 120px;
                        --primary-text-color: #a0a0a0
                      ha-card {
                        height: 75px !important;
                cards:
                  - type: conditional
                    conditions:
                      - entity: media_player.kodi_living_room
                        state: 'playing'
                    card:
                        icon: mdi:play
                        use_media_artwork: false
                        fill_container: false
                        card_mod:
                          style: |
                            ha-card {
                              {% if not is_state(config.entity, 'off') %}
                                background: rgba(var(--rgb-card-background-color), 0.6) url( '{{ state_attr(config.entity, "entity_picture") }}' ) center no-repeat;
                                background-size: cover;
                                background-blend-mode: overlay;
                              {% endif %}
                card_mod:
                  style: |
                    :host {
                      --ha-card-box-shadow: 0px;
                      --ha-card-border-radius: 0px
      - type: grid
        square: false
        columns: 1
        cards:
          - type: conditional
            conditions:
                state: 'playing'
            card:
                icon: mdi:play
                card_mod:
                  style: |
                    ha-card {
                      {% endif %}
