Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Still the same behaviour. Anyway thanks. I will add style to all my popup cards. :pensive:
trying to change the background of the conditional-chips in the top right corner kinda like in the screenshot
if i use --chip-background: whatever color it obviously only colors the single chips, but i want it to like like a bar/area.
maybe someone got an idea
type: vertical-stack
card_mod:
  style: |
    ha-card {
        background: none;
        --ha-card-box-shadow: 0px;
        --ha-card-border-radius: 0px;
cards:
  - type: horizontal-stack
    cards:
        card_mod:
          style: |
            ha-card {
              background: none;
        icon: |-
          {% set mode = states('sensor.personhome') %}
          {% if mode == '1' %}
          mdi:account
          {% elif mode == '2' %}
          mdi:account-supervisor
          {% elif mode == '3' %}
          mdi:account-group
          {% else %}
          mdi:account
          {% endif %}
        entity: group.home
        badge_icon: >-
          {{ 'mdi:home' if is_state(entity,'home') else
          'mdi:home-export-outline' }}
        badge_color: '{{ ''green'' if is_state(entity,''home'') else ''red'' }}'
        icon_color: '{{ ''white'' if is_state(entity,''home'') else ''disabled'' }}'
        tap_action:
          action: navigate
          navigation_path: person
      - type: custom:mushroom-chips-card
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-background: none;
              --chip-box-shadow: none;
              --chip-spacing: -5px;
              --chip-border-radius: 10px;
        chips:
          - type: conditional
            conditions:
              - entity: binary_sensor.lueften
                state: 'on'
            chip:
              type: template
              icon: mdi:water-percent
              icon_color: red
              tap_action:
                action: navigate
                navigation_path: humidity
          - type: conditional
            conditions:
              - entity: vacuum.roborock_vacuum_s5
                state_not: docked
            chip:
              type: template
              double_tap_action:
                action: none
              icon: mdi:robot-vacuum
              icon_color: green
              hold_action:
                action: none
          - type: conditional
            conditions:
              - entity: sensor.hacs
                state_not: '0'
            chip:
              type: template
              double_tap_action:
                action: none
              icon: fas:store
              tap_action:
                action: navigate
                navigation_path: /hacs
              hold_action:
                action: none
              icon_color: orange
          - type: conditional
            conditions:
              - entity: binary_sensor.home_assistant_versions_update_available
                state_not: 'off'
            chip:
              type: template
              double_tap_action:
                action: none
              icon: mdi:package
              icon_color: orange
              hold_action:
                action: none
              tap_action:
                action: navigate
                navigation_path: /config/dashboard
          - type: conditional
            conditions:
              - entity: sensor.devices_with_low_battery
                state_not: '0'
            chip:
              type: template
              icon: mdi:battery-alert
              icon_color: red
              tap_action:
                action: navigate
                navigation_path: batteries
          - type: conditional
            conditions:
              - entity: fan.ventilator
                state: 'on'
            chip:
              type: template
              double_tap_action:
                action: none
              icon: mdi:fan
              icon_color: green
              tap_action:
                action: none
              hold_action:
                action: none
          - type: conditional
            conditions:
              - entity: switch.adguard_filtering
                state: 'off'
            chip:
              type: template
              double_tap_action:
                action: none
              icon: mdi:shield-alert
              icon_color: blue
              tap_action:
                action: navigate
                navigation_path: raspberry-pi
              hold_action:
                action: none
          - type: conditional
            conditions:
              - entity: switch.mase_pc
                state: 'on'
            chip:
              type: entity
              icon_color: blue
              content_info: none
              icon: mdi:monitor
              tap_action:
                confirmation:
                  text: PC ausschalten?
                action: call-service
                service: hassio.addon_stdin
                  addon: core_rpc_shutdown
                  input: Mase-PC
              hold_action:
                action: none
              double_tap_action:
                action: none
var() is for when you want to use the value of a variable. For assigning a value to a variable you would just use --rgb-state-media-player: 72, 133, 237;.
I’ve been quietly following the development of the Mushroom Cards in addition to the beautiful community adaptations available in this thread. Beautiful work, truly.
I’ve ran into an issue. I wish to use a dashboard in kiosk mode and hide the header, but have the possibility to edit the dashboard. I wish to emulate the following button with a Mushroom chip.
I’ve noticed the URL changes when you press the button and have tried to create an Action chip with the URL, but I still wont be in Edit Dashboard mode unless I manually refresh the page after pressing the chip. I’ve looked at the process via Inspect Element and seen that some classes get added to the dashboard when I press the original Edit Dashboard button. Any way to emulate these with card mod or similar?
Hi
Thank you. I actually got it working eventually by looking at @Cadster post just after your post about badges on chip cards but your way above is alot cleaner. So thank you and sorry for delay, I will go with your way moving forward :slight_smile:
Its amazing what you and the community can do.
Many, many thanks for your help!!
Hello
if you can wait a few days i am working on a similar card. I am developing a work that I have done before, especially for android tv. This new card will be a remote control card. You will be able to see and control all the images playing on your TV.
for that i am happy to wait … the mockups look great
Does anyone know how to remove those spaces ?
type: custom:vertical-stack-in-card
cards:
  - type: conditional
    conditions:
      - entity: sensor.plex_lauflix
        state: '0'
    card:
      type: custom:mushroom-title-card
      subtitle: >-
        {% set cnt = states("sensor.tautulli_watching") | int(0) %}{% if cnt >=
        0%}🎦{{ states.sensor.tautulli_watching.state }} {{ 'personen kijken' if
        cnt> 1 else 'persoon kijkt' }} naar plex{% endif %}
      subtitle_tap_action:
        action: navigate
        navigation_path: /nieuwe-dashboard/plex
  - type: custom:mushroom-title-card
    subtitle: >-
      {% if states.update | selectattr('state', 'eq', 'off')
      |map(attribute='entity_id') | list %}Er is een update beschikbaar!{% endif
      action: navigate
      navigation_path: /nieuwe-dashboard/updates
  - type: conditional
    conditions:
      - entity: light.all
        state: 'on'
    card:
      title: ''
      subtitle: >-
        {% if states.light | rejectattr('attributes.entity_id', 'defined') |
        selectattr('state', 'eq', 'on') | list | count != 0 %}{% set light_count
        = states.light | rejectattr('attributes.entity_id', 'defined') |
        selectattr('state', 'eq', 'on') | list | count %}{% if light_count == 1
        %}💡1 Lamp staat aan {% else %}💡{{ light_count }} Lampen staan aan {%
        endif %}{% endif %}
        action: navigate
        navigation_path: /nieuwe-dashboard/lampen
My variation of your idea @rhysb. Sticky header and media player with popup.
Like always good job. Many thanks. I do not use node red so it is based on your previous version.
Question about this part (I used variables to have different colors in dark and light mode):
mmp-progress$: |
  paper-progress {
    --paper-progress-container-color: rgba(var(--progress-bar), 0.08) !important;
    --paper-progress-active-color: rgba(var(--progress-bar), 0.6) !important;
and theme file:
Mushroom:
    # Nothing here as it's the default HA theme since 2022.11
    modes:
        light:
            progress-bar: 0, 0, 0
        dark:
            progress-bar: 255, 255, 255
Is it any way to do that just in card mod?
I use the mushroom entity card with waze integration. Previously, like the default entity card, it used to give the travel time and units. For example “13 min”
However, ever since some update, it now gives it as HH:MM:SS - so instead of saying “13 min” it says “13:00”
Any ideas of how to change this back?
how did you manage that the mediaplayer at the bottom used the full screen width?
Waiting on this … awesome work!
mind sharing your navigation bar?
type: custom:stack-in-card
mode: horizontal
cards:
    chips:
      - type: back
      - type: template
        icon: mdi:home
        tap_action:
          action: navigate
          navigation_path: home
        hold_action:
          action: none
        double_tap_action:
          action: none
      - type: template
        icon: mdi:lan
        tap_action:
          action: navigate
          navigation_path: network
        hold_action:
          action: none
        double_tap_action:
          action: none
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          --chip-height: 42px;
          --chip-border-width: 0px;
          margin-left: 10px;
    chips:
      - type: conditional
        conditions:
          - entity: sensor.epson_xp_760_series
            state_not: unavailable
        chip:
          type: template
          icon_color: disabled
          icon: mdi:printer
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
          card_mod:
            style: |-
              @keyframes blink {
                50% {opacity: 0;}
              ha-card {
                {% if is_state("sensor.epson_xp_760_series", "printing") %}
                  animation: blink 1s linear infinite;
                {% endif %}
      - type: conditional
        conditions:
          - entity: switch.desktop
            state: 'on'
        chip:
          type: template
          icon_color: |-
            {% if is_state("input_boolean.home_mode", "off") %}
              red
            {% else %}
              disabled
            {% endif %}
          icon: mdi:desktop-classic
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
          card_mod:
            style: |-
              @keyframes blink {
                50% {opacity: 0;}
              ha-card {
                {% endif %}
      - type: conditional
        conditions:
          - entity: sensor.glances_cpu_load
            state_not: '0'
        chip:
          type: template
          icon: mdi:nas
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
      - type: conditional
        conditions:
          - entity: binary_sensor.rpi_power_status
            state: 'off'
        chip:
          type: template
          icon: mdi:home-assistant
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
      - type: conditional
        conditions:
          - entity: switch.adguard_protection
            state: 'on'
        chip:
          type: template
          icon: mdi:shield-check
          tap_action:
            action: none
          hold_action:
            action: none
          double_tap_action:
            action: none
    alignment: end
    card_mod:
      style:
        mushroom-template-chip:
            mushroom-chip {
              cursor: default !important;
          ha-card {
            --chip-spacing: 0;
            --chip-padding: 0.4em 0 0 0 ;
            --chip-height: 30px;
card_mod:
  style: |
    :host {
      position: sticky;
      top: var(--header-height);
      z-index: 1;
    ha-card {
      background: rgba(var(--rgb-card-background-color), 0.6);
      backdrop-filter: blur(5px);
      -webkit-backdrop-filter: blur(5px);
      padding: 4px 0 4px 0;
      box-shadow: 0px 0px 10px 0px rgba(0, 0, 0, 0.6);
      border-radius: 0px;
      border-width: 0px;
      margin: -8px -8px 0px -8px;
      border-bottom-width: 1px;
I’m trying to build my “custom vacuum”-card to select a specific room to be cleaned for my neato botvac.
I’m trying to add an select card on top of the vacuum card which is probably the wrong way because the pop-up is not overlayed :slight_smile:
Using the select-card its a real pop-up.
Currently i’m using this code.
cards:
  - type: custom:mushroom-vacuum-card
    entity: vacuum.robbi
    commands:
      - start_pause
      - return_home
      - stop
    icon_animation: true
    tap_action:
      action: none
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          --ha-card-border-width: 0;
        }a
  - type: custom:mushroom-select-card
    entity: input_select.robbi_raume
    icon_type: none
    secondary_info: none
    primary_info: none
    tap_action:
      action: none
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 0px;
          right: 0px;
          width: 50%;
  - type: custom:mushroom-entity-card
    icon: mdi:texture-box
    icon_color: red
    primary_info: none
    tap_action:
      service: neato.custom_cleaning
        mode: 2
        navigation: 2
        category: 4
        zone:
          '[object Object]': null
        entity_id: vacuum.robbi
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 0px;
          right: 0px;
          width: 13%;
Any idea what to do? Or maybe someone created such a mushroom-style-card.
Might not be quite what you want, but what I do is have a helper switch on the dashboard which toggles on/off the kiosk mode hide function. That way I can use hidden and when I want to edit, hit the toggle, top bar shows, edit away, then toggle to hide again.
The hide function is a feature of kiosk mode. Like this
kiosk_mode:
  entity_settings:
    - entity:
        input_boolean.hide_sidebar: 'on'
      hide_sidebar: true
      hide_header: true
hello @rhysb
I asked this question a while ago but then did not go further with this question. Hopefully this can be realized?
thanks in advance!
hello first of all very nice that you have made this media player very nice and handy i have adjusted it a bit to my taste now i have a question is it possible if i use my sonos for tv sound then i get black in the screen where normally the picture comes from the song would it be possible to do this based on everything the media title is on TV is this status so know it but just don’t know how to add it? thanks in advance!
cards:
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-media-player-card
        entity: media_player.sonos_beam
        icon: mdi:play
        use_media_info: true
        use_media_artwork: false
        show_volume_level: true
        media_controls:
          - play_pause_stop
          - previous
          - next
        fill_container: false
        card_mod:
          style:
            mushroom-state-info$: |
              .primary:before {
                content: "{{ (state_attr(config.entity, "friendly_name")) }} - ";
              mushroom-shape-icon {
                display: flex;
                {% set media_type = state_attr(config.entity, 'media_title') %}
                {% if media_type == 'TV' %}
                  --card-mod-icon: mdi:television-classic;
                  animation: flicker 1s linear infinite alternate;
                {% else %}
                   --card-mod-icon: mdi:music;
                   animation: beat 1.3s ease-out infinite both;
                {% endif %}
                {{ 'animation: none;' if not is_state(config.entity, 'playing') }}
              @keyframes flicker {
                0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
                32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
              @keyframes beat {
                0%, 60% { --icon-symbol-size: 21px; }
                5%, 17%, 57% { --icon-symbol-size: 22px; }
                10%, 20%, 51% { --icon-symbol-size: 23px; }
                25%, 45% { --icon-symbol-size: 24px; }
                30%, 39% { --icon-symbol-size: 25px; }
                33% { --icon-symbol-size: 26px; }
              ha-card {
                .primary:before {
                  content: "{{ (state_attr(config.entity, "media_artist")) }} - ";
              ha-card:before {
                transform: translate3d(0,0,0);
                -webkit-transform: translate3d(0,0,0);
                content: "";
                background: url('/local/images/idle.png') center no-repeat;
                {% if not is_state(config.entity, 'idle') %}
                  background: url( '{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
                {% endif %}
                background-size: contain;
                margin: 4px 4px 16px;
                filter: drop-shadow(4px 4px 6px rgba(0, 0, 0, 0.5));
                border-radius: var(--control-border-radius);
                {% set media_type = state_attr(config.entity, 'media_content_type') %}
                {% if media_type == 'music' %}
                  aspect-ratio: 16 / 9;
                {% elif media_type == 'movie' %}
                  aspect-ratio: 2 / 3;
                {% else %}
                  aspect-ratio: 1 / 1;
                {% endif %}
      - type: conditional
        conditions:
          - entity: media_player.sonos_beam
            state_not: 'off'
            state_not: idle
        card:
          hide:
            icon: true
            runtime: true
            source: true
            power: true
            state_label: true
            volume: true
            info: true
            progress: false
            controls: true
          more_info: false
          type: custom:mini-media-player
          toggle_power: false
          group: true
          card_mod:
            style:
              mmp-progress$: |
                paper-progress {
                  {{ '--paper-progress-container-color: rgba(var(--mush-rgb-indigo, 63, 81, 181), 0.2) !important;' if is_state(config.entity, 'playing') }}
                ha-card {
                  margin: 0px 12px 12px;
                  --mmp-progress-height: 12px !important;
                  height: var(--mmp-progress-height);
                  --mmp-accent-color: rgb(var(--mush-rgb-indigo, 63, 81, 181));
                  --mmp-border-radius: 12px !important;
    card_mod:
      style: |
        ha-card:before {
          content: "";
          position: absolute;
          height: 100%;
          width: 100%;
          background: url('/local/idle_art.png') center no-repeat;
          {% if not is_state('media_player.sonos_beam', 'idle') %}
            background: url( '{{ state_attr('media_player.sonos_beam', "entity_picture") }}' ) center no-repeat;
          {% endif %}
          filter: blur(150px) saturate(200%);
          background-size: 100% 100%;
        ha-card {
here are the possible if sonos is on tv source
playing
source_list: TV
group_members: media_player.sonos_beam, media_player.sonos_ra
volume_level: 0.04
is_volume_muted: false
media_content_id: x-sonos-htastream:RINCON_48A6B83ABBD601400:spdif
media_content_type: music
media_title: TV
shuffle: false
repeat: off
queue_size: 1
icon: phu:sonos-beam
friendly_name: Sonos Beam
supported_features: 981567
source: TV
So if the source TV is there will be an image of TV that I have in the www folder, so if you did that, if nothing is playing, but it won’t work, hopefully you get it now?
I tried to add a radial bar for valve opening to a climate card. I cannot find what to use for the icon background color. Currently i get the card background, but i want the colored icon background.
Which variable is the correct one?
climate
type: custom:mushroom-climate-card
entity: climate.thermostat_kueche_climate
fill_container: true
show_temperature_control: true
collapsible_controls: true
hvac_modes:
  - auto
  - heat
  - 'off'
layout: horizontal
icon: bha:thermostat
tap_action:
  action: more-info
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent 75%),
        conic-gradient(rgb(var(--rgb-orange))
        {{ (states('sensor.thermostat_kueche_valve_state') |  float) | round(0) }}% 0%,
        var(--card-background-color) 0% 100%);
        transform: rotateY(180deg);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
        background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
Second try was to add the valve bar to an climate card modified to show the temperature rather then the icon.
I managed to show the bar, but it was not correctly centered.
icon: none
hvac_modes:
  - auto
  - heat
  - 'off'
layout: horizontal
tap_action:
  action: more-info
card_mod:
  style:
      .shape:after {
        content: "{{ states('sensor.t1_temperature') }}°";
        font-size: 14px;
        position: absolute;
      .shape {
        {% set mode = states('config.entity') %}
        --shape-color: var(--rgb-
        {%- if mode == 'heat' -%}
          orange
        {%- elif mode == 'off' -%}
          blue
        {%- else -%}
          grey
        {% endif %}), 0.2);
      mushroom-badge-icon:after {
        content: "{{ states('sensor.thermostat_kueche_valve_state') }}";
        position: absolute;
        display: flex;
        justify-content: center;
        align-items: center;
        background: rgb(var(--rgb-black));
        color: rgb(var(--rgb-white));
        font-weight: bolder;
        border-radius: 50%;
        top: 0;
        width: 100%;
        height: 100%;
        font-size: 0.8em;
If i try the same for a template card with adaptive background color i dont know how to combine them.
I want the bar to use the icon color on the icon background color.
type: custom:mushroom-template-card
primary: AZ {{ states("sensor.atc_t4_1b9d_temperature") }}°C
secondary: |-
     {{ states("sensor.thermostat_kueche_temperatur") }}°C - {{
        states("sensor.thermostat_kueche_valve_state") }}%
entity: sensor.thermostat_kueche_temperatur
icon: mdi:pot-steam
layout: horizontal
tap_action:
  action: more-info
icon_color: |
  {% set battery_level = states(entity) %}
  {% if battery_level < '15' %}
    blue
  {% elif battery_level < '17' %}
    teal
  {% elif battery_level < '18' %}
    green
  {% elif battery_level < '19' %}
    light-green
  {% elif battery_level < '20' %}
    lime
  {% elif battery_level < '21' %}
    yellow
  {% elif battery_level < '22' %}
    amber
  {% elif battery_level < '24' %}
    orange
  {% elif battery_level < '27' %}
    deep-orange
  {% else %}
    red
  {% endif %}
card_mod:
  style:
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(config.icon_color {{ (states('sensor.thermostat_arbeitszimmer_valve_state') |  float) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
      ha-card {
        {% set battery_level = states(config.entity) %}
          background: rgba(var(--rgb-blue),0.30);
          background: rgba(var(--rgb-teal),0.30);
          background: rgba(var(--rgb-green),0.30);
          background: rgba(var(--rgb-lime),0.30);
          background: rgba(var(--rgb-yellow),0.30);
          background: rgba(var(--rgb-amber),0.30);
          background: rgba(var(--rgb-orange),0.30);
          background: rgba(var(--rgb-deep-orange),0.30);
        {% elif battery_level == 'unknown' %}
          background: rgba(var(--rgb-secondary-text-color),0.30);
          {% else %}
          background: rgba(var(--rgb-red),0.5);
        {% endif %}
Maybe someone can help me :slight_smile:
icon_color is not defined in the mushroom-climate-card, so you can’t use {{ config.icon_color }}. Change it to background: var(--shape-color); instead.
